| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Jul 2007 Location: Delhi
| Hi People, My Maruti Esteem 2002 has clocked about 25,000 kms. Since yesterday, the Check Engine Light has been constantly been blinking and indicating code 12 (Blink ones and stops for while and the blinks twice again before repeating the cycle). As per the manual the code 12 indicates Normal engine functioning. But what makes me wonder if the engine is normal then, why this check engine light is coming on. I have not noticed any drop in performace or F.E of the car. few days back i had a problem with the central locking (fitted from outside), that its fuse was blown up. I gave it my to my mechanic and it was rectified there and then. Any suggestion please. Many thanks Amit |
| | #2 (permalink) |
| BHPian | Why don't you take it to the service station and get it checked before you could land up into bigger problems.Since the manual indicates the engine is functioning normally,may be it's just an electrical failure since one of the fuse blew up.
__________________ Forget two things in life. The good you do to others & bad done by others to you. |
| | #3 (permalink) | |
| Newbie Join Date: Dec 2007 Location: PATNA
| HI, the light which is blinking is called malfunction indication lamp.In your vehicle the fuse box located near the accelerator peddal under the dash has a slot which is marked as (DIAG) On the cover of the fuse box . by mistake your technician has inserted a fuse in this slot. Fuse in this slot is inserted by workshops on temporary basis to identify the fault codes stored in the memory of the ECU.Just identify and remove this fuse your probelem will be solved. After you have completed start the car and confirm that the M.I.L blinking has stopped. and to end it all please disconnect your batt. negative (-) terminal for about 45 seconds and reconnect. Mind u guys the same provision is there in Gypsy MPFI. allso. Quote:
| | #5 (permalink) | |
| Quote:
Hi, The blinking light is displaying code no 12. This code as per Esteem manual indicates that the engine is normal. But in any case in day or two i will take it to MASS and will keep you guys updated. Many Thnaks Amit | |
| | #6 (permalink) | |
| Quote:
Thanks, will surely try this today and will come back to you. Cheers Amit | |
| | #7 (permalink) | |
| Quote:
Your advised really worked . THANKS A TON!! for your suggestiion. Your kind advice not only saved my money but hassel i would encountred if i would have gone to MASS.Cheers Amit | |
| | #8 (permalink) | |
| BHPian | Quote:
great troubleshooting man. salute you. u have indeed helped amit.
__________________ " I dont Drive Fast , I Fly Slowly " | |
| | #9 (permalink) |
| Senior - BHPian Join Date: Feb 2005 Location: Chennai
| Check engine light is on in my relatives 2005 Maruti 800. While driving I did not find any issues other than high rev when I shift from 1st to 2nd gear. Took it to a workshop and found that issue was with Code 13. An issue with wiring kit leads to TBC has been identified and fixed. Even then the light was on and was told that TBC needs to be replaced. How much it will cost? What if the light does not go even after replacing the TBC? |
« Noise and vibration in Baleno engine
Service manuals for Indian cars - top secret? (Available for download here!) »
| Thread Tools | |
Similar Threads | ||||
| 1999 Baleno - Check Engine Light | ecurb_jm | Technical Stuff | 5 | 11th February 2008 13:44 |
| Rear engined, twin cam engine Maruti 800. Check out the video. | mclaren1885 | Modifications & Accessories | 10 | 5th October 2007 21:20 |
| "Check Engine" Light! | adman77 | Modifications & Accessories | 22 | 31st July 2007 15:44 |
| Maruti Esteem petrol engine to Diesel Engine | mituadas | Modifications & Accessories | 24 | 23rd May 2007 12:42 |
| Check engine light mystery | gbpscars | Technical Stuff | 7 | 4th December 2006 22:12 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
