Thread Tools
Old 11th February 2008, 22:42   #1 (permalink)
Default Steering behaving strange after alignment of Tata Safari
Hi Guys,
Been facing this strange problem for the past one week now. Got the wheel alignment done for my Safari (with OEM alloys) about a week back. The alignment chap used the "computerized" method to align the wheels. On mounting the sensors to the wheels, the screen showed the camber and toe to be out of the specified range for the safari. He adjusted both of them and brought them within the range. My steering wheel that was slightly off-centre also got "kind of centred".
After this alignment, the steering wheel has become very imprecise. it moves left/right even on the slightest undulation in the road, and when trying to change direction suddenly(from going left to suddenly changing the direction of steering to right), it feels as if the steering wheel is moving a lot to cause a small amount of change in direction.
Is this because the play of the steering has increased? Also there is a very "loose feel" to the steering as compared to the earlier "tight feel".
Strangely though, the alignment is okay.
Can the correction in toe or camber have resulted in this behaviour?
I recently showed it to two A.S.S (Dhingra in gurgaon and vivek automobiles) and both of them say everything is OK. But i can feel that something (maybe small) is not okay.
Please help!!.
-Nitin
__________________
Where there is a wheel, there is a way...
trance_nut is offline   Reply With Quote
Old 12th February 2008, 00:02   #2 (permalink)
1100D's Avatar
Was you car earlier running on excessive toe?
Why I ask this is that it seems that you have a steering linkage issue here. But prior to alignment your car was tight. Maybe due to excessive toe any wearout of the steering system bushes might have been negated.
__________________
________________________
Every Ferrari is always a Fiat
1100D is online now   Reply With Quote
Old 12th February 2008, 09:55   #3 (permalink)
Thanks for the reply 1100D.
It wasnt excessive, just marginally out (as indicated by the alignment software).
During the first 1000 km, there was an issue with the steering pump (oil leakage), and it was changed under warranty. While connecting the steering linkage back, they connected it such that the steering was off centre by about 20 degrees from the vertical.
Thereafter n number of efforts had been put in to centre the steering (just by taking out the steering and trying to align it to the centre). However after the alignment, the steering seems to have been centred, but the feeling is very "soft".
How can the linkage issue be detected? Also is there any other symptom that indicates a linkage issue?
Nitin
__________________
Old 12th February 2008, 14:44   #4 (permalink)
Hey finally i find someone whose problem matches mine.
I experienced a problem like this when my driver told the A.S.S (Sanya
Motors) to lighten the steering, without my knowledge, i drove the car and
the steering was completely imprecise and Sh*tty, i could feel a lot of play,
after showing it to another A.S.S they told me if they tighten the steering
there would be a risk of the car toppling over at high speed (A-One Motors), i
was completely shocked at this statement and told him not to do anything, at
another instance i again asked the service station guys to check steering
play and he simply told me it was because of worn out tyres, my car is lying
unused and under covers since because of it feeling unstable waiting for a
tyre change, let's see what happens.
abhishek2 is offline   Reply With Quote
Thread Tools
Tata Safari For Sale streetdreams Shifting gears 0 20th January 2008 20:16
Strange Tata Truck at ARAI. sajo Shifting gears 12 1st December 2007 21:12
Tata Safari 2.2 kdeepakk The Indian Car Scene!! 2 8th December 2006 09:08
Safari 2.0 TD - Bad Brakes & Steering Play abhishek2 Technical Stuff 4 19th February 2006 09:49
Tata Safari - Petrol adityapd The Indian Car Scene!! 12 22nd April 2004 16:14
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
