Old 12th February 2008, 11:16   #1
anachronix's Avatar
Thanked: 1,294 Times
Default Electrical Problem with my Ikon!
Frens,
I have a 2004 model Ikon 1.6.
These days i have a wierd problem in my car. The horn sounds well initially when in the start of the day and as i drive it around in the traffic the horn sound changes to a very weak tone (Somthing like its getting less power). Also when i brake and honk at the same time the horn will go really dull and sometimes it cuts out too!
I assume this to be an electrical problem. I need to get this fixed guys. Please help!
anachronix is offline   Reply With Quote
Old 12th February 2008, 11:27   #2
benbsb29's Avatar
Thanked: 4,281 Times
I may be wrong here, but is it something to do with a weak battery?
Old 12th February 2008, 11:30   #3
snaronikar's Avatar
Thanked: 23 Times
Have you checked the wiring. Is the battery getting charged enough. When did you last change the battery? Check these poins and it may be of help.
snaronikar is offline   Reply With Quote
Old 12th February 2008, 11:50   #4
Thanked: 294 Times
It only happens in two cases
1) Extra load -> it is like ICE, Fog lights, 100 Watts Headlamps
2) Weak Battery -> how old is your current car battery
Old 12th February 2008, 11:51   #5
anachronix's Avatar
I changed the battery only an year back! I doubt that it could be weak!
Old 12th February 2008, 14:08   #6
VC12's Avatar
Though the batttery may be good, check for the earthing of the battery, this may casue the battery drain and create less power.
Also, at times the horn may have water /moisture thus hampering the sound....
VC12 is offline   Reply With Quote
Old 12th February 2008, 16:17   #7
wolfinstein's Avatar
Have a similar issue in my lancer- Battery is SF one year old, I changed the horns from Roots to Bosch Symphony problem went away but now again recurrs occassionally by sounding weak.
The Mech here said problem could be with the new horns, so will change them under warranty and update.
wolfinstein is offline   Reply With Quote
Old 12th February 2008, 20:20   #8
Hey, always the tone of my OEM horn is different. If cruising on the highway its how it should be. In traffic times it has vari-tone . Battery voltage seems to be varying above 12.5-12.8v tho.
Are you using the OEM horn?
cya
A
Absar is offline   Reply With Quote
Old 12th February 2008, 20:41   #9
Jaggu's Avatar
Thanked: 8,694 Times
your horn might be getting conked/out of tune with age. am not sure tuning is an option with iKON OE horns.
Old 13th February 2008, 12:49   #10
anachronix's Avatar
Can someone help me with a good wiring technician in chennai. I dont want to take it to the dealer and waste my time again. I have already informed the dealer about this problem and he has no answer for that!
Old 13th February 2008, 17:34   #11
You haven't answered if its your OEM horn thats playing around or its an aftermarket horn.
cya
A
Old 13th February 2008, 19:07   #12
tsk1979's Avatar
Thanked: 16,422 Times
Get your horn tuned. Looks like it acts up when heated.
The mechanic will take a screwdriver and tune your horn. Once your horn is tuned, this problem should go away.
I doubt its a weak battery issue, because if that was the case even your lights would go dim etc.,
I presume only your horn is acting up.
Old 14th February 2008, 14:56   #13
anachronix's Avatar
cya
A
@Absar: its the OEM horn, but i also have a 2nd horn which is installed with proper wiring done. Its a stebel nautilius and that dims out too rarely!
'Strange'st electrical problem in Fiat Palio 1.2 extreme_torque Technical Stuff 30 21st May 2011 14:14
Strange Electrical Problem on P180 Fountainheader Motorbikes 17 13th March 2011 22:57
Ikon peculiar electrical problem - Help! kaynmantis Technical Stuff 7 7th July 2009 01:51
Scorpio : Weird electrical problem forbhaskarm Technical Stuff 4 7th January 2008 11:16
