Thread Tools
Old 12th February 2008, 22:50   #1 (permalink)
Default civic - gear shift noise
I have noticed the it is bit hard to shift the gear in Civic and feels as if it rubs some metal part while shifting. That is gear stick is rubbing against some unknown contact.
I have a new civic S MT, which is just 400km.
swageo is offline   Reply With Quote
Old 13th February 2008, 16:47   #2 (permalink)
Absar's Avatar
Usually when the car is new, it will be a bit rough. As you gather up kms on the odo, it'll smooth out.
Other Honda Civic owners can comment about the feeling of rubbing against metal part point.
cya
A
__________________
Ford Ikon 1.6 Nxt ZXi, 2005
I cried because I had no VTEC, until I met a person who had no 1.6 ROCAM.
Absar is offline   Reply With Quote
Old 13th February 2008, 17:20   #3 (permalink)
Surprised that no other Civic owner has replied to this post. Well I have an AT so can't comment.
Are you depressing the clutch fully. Sometimes floor mats can get in the way and could cause the gears from changing correctly.
__________________
Everyone is born right-handed, only the gifted overcome it.
This is my car and I have my wife's permission to say so.
csentil is offline   Reply With Quote
Old 13th February 2008, 22:52   #4 (permalink)
I made sure floor mat is not getting stuck in between. If I press the clutch fully, this issue is more compare to half clutch. I guess clutch is set to its tip such that you don't have to fully declutch.
Day by day I am finding new issues
There is one more issue, which I will post it separately.
Old 13th February 2008, 23:01   #5 (permalink)
ramie2400's Avatar
I TD'ed a Civic Last to Last sunday,even i noticed that the gears are real hard to shift(reminded me of my Sumo) but the car is real butter smooth.I feel the gears take a prominent position and gets lock until next gear is shifted.. suerly there is no vibration in gear.. same stuff happenes in the Hyundai Verna CRDi
__________________
"Whenever I find the key to success,..... someone changes the lock.
ramie2400 is online now   Reply With Quote
Old 13th February 2008, 23:59   #6 (permalink)
iraghava's Avatar
Swageo - Are you a finicky kind of a customer?? (Don't mind this as I'm not taking a personal dig at you). From the problems you seem to describe it seems that most of them seem to happen because you seem to be quite particular about things that might not even exist in the first place.
Anyway for this problem the only solution I can suggest is that when you go in for your next service try a couple of other cars & see whether the problem is only in your car & that's how the gearshift is in all cars.
__________________
There is a very fine line between "Hobby" and "Mental Illness".
iraghava is online now   Reply With Quote
Old 14th February 2008, 00:10   #7 (permalink)
ramie2400's Avatar
As what i have notices all huge cars have stiffened gear shift (don't know the reason behind it)I have a 06'accord the gears are pretty stiff to change.Even my boss's BMW 3series(manual) 2002 model makes noise while shifting as if the gears are stuck up.
If someone can throw some light over this issue.. or its just me who have felt this in different higher segment cars..
ramie
__________________
Old 14th February 2008, 11:52   #8 (permalink)
I don't admire a things just because I bought it. In my earlier thread I described the Civic's slant towards right side, though it turn out to be expected. Now with the gear. Try changing the gear from 2nd to 1st while car is at less that 10kmph. It is really hard.
Why should a 12+ lakhs Japanese car gives these issue when my ikon/santro does not.
Thread Tools
Baleno Gear Shift Problem guruji Technical Stuff 6 5th August 2008 00:44
Gear-shift lever vibrations girishab Technical Stuff 12 10th June 2008 13:48
GEAR shift pattern - is this right? shapath Technical Stuff 7 12th October 2007 13:21
Peculiar problem-gear shift rod shbhrao Technical Stuff 11 10th January 2007 10:07
Auto Guage RPM with Gear Shift for Swift..!!! shuhaib Modifications & Accessories 2 1st June 2006 14:33
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
