Thread Tools
Old 18th April 2008, 02:30   #16 (permalink)
abhik's Avatar
Infractions: 0/1 (5)
Do make sure if you are going in for aftermarket coolants other than OE then you buy a good quality brand like Motul, Castrol, Valvoline etc and not local ones and use them as mentioned in their respective packs as some mechanics would misguide you saying use full coolant instead of mixing it with water when the pack would mention just 1part to 3parts of water in which case it might be harmful and not perform cooling operation as required.
__________________
ABHIK
<<<If everything seems under control, you're just not going fast enough>>>
abhik is offline   Reply With Quote
Old 18th April 2008, 14:08   #17 (permalink)
Default Hi!
Gauges can be misleading !
My gauge usually indicates at the 50 % (1/2) mark. I was advised to check the the car checked in case it goes to the 75%(3/4) mark - thumb rules of mechanics - I guess.
I was also told that the thermostat would operate at around this point to bring the radiator into the cooling circuit - something about a signal to the ECM to go into the close loop mode. Is it correct?
dashoin is offline   Reply With Quote
Old 18th April 2008, 15:42   #18 (permalink)
Originally Posted by abhik View Post
If you are driving the car out on a hot summer day and in traffic then 1/2 on the temp guage is fine as the same happens to me because the air around the car is hotter in traffic due to the heat from other vehicles in close viscinity thus the air sucked in is also hot resulting in the higher temperature but it should fall down a bit once on an open stretch. So i guess nothing to worry about but anything more than that then do get the coolant changed or check for leaks, sometimes it might not be a visible leak and the coolant might be trickling away slowly somewhere unnoticed.
i believe it is 1/2 even on an open stretch. having said that it is also quite hot these days. let's see - i guess if i notice it rising above that then i will get it checked. if not then i'll have it replaced/checked in the next service.
silver_shadow is offline   Reply With Quote
Old 18th April 2008, 19:40   #19 (permalink)
abhik's Avatar
Bro dont worry about it too much, if ever it goes more than 1/2 and stays there in normal conditions then you need to worry.
Just get leaks checked and coolant level up to prescribed limit, thats it!
Drive with a "COOL" head and that will keep your ride cool!!
__________________
ABHIK
Old 18th April 2008, 19:55   #20 (permalink)
abhik's Avatar
I thought the cooling circuit was already a closed loop one.
__________________
ABHIK
Old 19th April 2008, 09:25   #21 (permalink)
Whoops - guess I didnt put it clearly!!
The cooling system is a closed loop one - the radiator comes in the cooling path after the engine reaches a preset temperature. The thermostat bypasses the radiator till this temperature is reached.
( Did this research after my Dad complained that the engine gets heated up fast - his 96 esteem supposedly does not have this !!! Saw all the cooling paths after my diverter valve failed and I had to get it bypassed.)
From what I`ve read and been told, the ECM would go into the closed loop mode after this thermostat operates. That is what I meant by closed loop operation.
Old 19th April 2008, 19:58   #22 (permalink)
abhik's Avatar
Sorry!
Ya i guess that how all the newer models function now.
__________________
ABHIK
Old 20th April 2008, 12:15   #23 (permalink)
snaronikar's Avatar
Guys, the Ford dealer supervisor here said that we never have to use other coolant other than Ford recommended lubricant as it will affect the ECM. He has flushed out the green lubricant which I had filled in and then he filled it with ford recommended lubricant and said he will give a guarantee of 20k kms (till then coolant replacement is not required). Need to check this anyways...
__________________
Love your job but Never love your company
because you never know when your company
stops loving you-NRN
snaronikar is offline   Reply With Quote
Old 20th April 2008, 12:25   #24 (permalink)
snaronikar's Avatar
I think it is a nice drive. You are right. These volvo guys drive very fast and whenever I will be driving in night I make it a point that never to give chance to these guys to overtake as we will never know when these guys will apply brakes and if they do, these buses tend to stop completely. The people behind will have a hard time brajing their vehicles.
__________________
Old 20th April 2008, 19:42   #25 (permalink)
abhik's Avatar
I was told the same thing, but i figured out it was just another excuse for them to add on Rs900 to the bill and their coolant did'nt last me 5000Kms.
__________________
ABHIK
Old 25th April 2008, 21:19   #26 (permalink)
i checked the coolant level today and it was PRETTY low. the last few days she was heating up pretty quickly with just a few mins of driving with no traffic even in the night. now everything's ok. i went to the office this afternoon in scorching heat and the gauge was showing just around 1/4 which i guess should be normal most of the times even when it's a bit hotter.
Old 26th April 2008, 17:35   #27 (permalink)
Jaggu's Avatar
A) It will not affect ECM, yeah maybe for indian condition ford might be using a diff/better grade coolant. Color is diff if i remember correct, but that doesnt mean it will affect ECU, rather car might run a lil hotter.
B) Regular coolant change interval is 20k kms or more, with top ups in between if required.
__________________
The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin
Thread Tools
Ford Ikon mod - fiesta head on ikon block? madhunm Modifications & Accessories 2 2nd July 2007 09:24
Ford IKON ??? kick.throttle Technical Stuff 6 18th September 2006 11:14
the ford ikon 1.6 le_doctor Modifications & Accessories 13 5th May 2006 23:01
anyone want a FORD IKON? karthik247 Shifting gears 12 12th April 2005 00:09
Ford Ikon 1.6 at 5.4? RX135 Sedans 3 12th January 2005 18:30
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
