Old 7th April 2009, 08:35   #31
I have Blue coolant filled this time.It says Non amine in maruti bill.Its not green but light blue in colour.They added no water,I made sure it was 100% coolant?
binoyjude is offline   Reply With Quote
Old 20th July 2009, 21:38   #32
rajivanoj's Avatar
Thanked: 45 Times
I bought TVS ezcool coolant, but it meets ASTM standards, i dont know whether it is specific for japanese, american, korean cars. But i have used it in lancer diesel last week, after an flush by wynns cooling flush.
rajivanoj is offline   Reply With Quote
Old 13th November 2012, 10:37   #33
searchingheaven's Avatar
Thanked: 1,356 Times
Default Re: Ford Ikon Used different coolant.
My ikon 1.3 petrol' coolant is less viscous than it originally was. Ford has recommended changing it, but they charge 1.3k for it. I believe that it is too much. I want to use the green one. Can i do so? Also, how much does the green one cost? And if i dont use the car more than 40km a week, that too in winter temperatures. Should i change the coolant?
searchingheaven is offline   Reply With Quote
Old 13th November 2012, 17:27   #34
blackfire_9's Avatar
Thanked: 187 Times
Ideally, you should use an HOAT/OAT because that's what Fords have used for quite some time now. And Ford's own genuine HOAT is a light green coloured coolant, while the OAT is orangish-red. Check the manual & let us know the Ford specification it calls for & that can help in ascertaining the exact nature of the coolant.
The problem, however, is that Ford OEM fluids are not available in the aftermarket & thus, you may just have to stick with an ASC or try asking them for over the counter sale.
Also, 1.3K is a decent charge because I believe the coolant capacity for the Ikon 1.3 is close to 5 liters & a liter should cost around INR 210-225. Please correct me if wrong.
blackfire_9 is offline   (1) Thanks Reply With Quote
Old 13th November 2012, 23:30   #35
Catalyst_delhi's Avatar
Thanked: 148 Times
1.3k is very cheap. Go original for Ikons coolant , Very very important. The normal Green ones are not compatible with the original HG , seals and a few other components.
Catalyst_delhi is offline   Reply With Quote
Old 25th November 2012, 10:47   #36
Can anybody specify the exact coolant capacity of the ford ikon 1.3 in litres?
Old 25th November 2012, 18:04   #37
Thanked: 148 Times
It is around 5-6 litres.
Old 3rd December 2012, 09:15   #38
Thanked: 148 Times
correction : as per manual it is 9.8 litres for 1.3 and 1.6 ikon and 12 litres for the diesel. Thanks Ramzsys
Old 6th January 2013, 08:07   #39
Mod Note : Please use the EDIT or MULTI-QUOTE buttons instead of typing one post after another on the SAME THREAD! To know how to multi-quote, click here (How to MULTI-QUOTE (when replying to a thread) on Team-BHP).
Does ford provide green coloured coolant for their ikon models nowadays?
Originally Posted by nitrous View Post
Ok, I just remembered.
I've been using Castrol Protector JIS-K-2234 Class II,IS:5759 in my ikon for the last 3 months/3,000 kms.
Ratio and total amount of coolant used? Also, whats the update now? Any issues/problems with it?
Last edited by GTO : 7th January 2013 at 13:34. Reason: Please use the EDIT or MULTI-QUOTE buttons instead of typing one post after another!
Old 6th January 2013, 09:08   #40
nitrous's Avatar
Thanked: 282 Times
Sold the car over 3 years ago.
But, it was doing ok with the change. No issues.
Different Service Schedules for Different Cars Vishesh Technical Stuff 22 15th August 2012 17:07
Is the immobiliser technology different in different cars? n.devdath Technical Stuff 3 12th November 2009 18:59
Mixing different coolant brands greenhorn Technical Stuff 21 7th October 2009 16:08
How different fuel brands work on different cars-Fifth gear video nitrous Technical Stuff 2 18th March 2007 12:05
Different Speaker Brands = Different sound for same/similar music ? normally_crazy In-Car Entertainment 10 29th August 2006 12:05
