Thread Tools
Old 13th February 2008, 12:01   #1 (permalink)
shuvc's Avatar
Default Baleno FE drop post flood repairs
As some of you would know, my car went through a pretty bad patch during last years monsoons. It got half submerged in the garage.
I got the car back around early November. Since then I've done around 5000kms with 12 tank top-ups. The general trend I'm observing is, FE has dropped by 1 to 1.5 kmpl (under both AC, non-AC conditions)
Let me clarify some obvious queries upfront.
1. Driving style has remained same
2. Driving route has been the same for the past 2 years
3. Car has done 28K+ kms now
4. It's been 5K + kms since the last service and there is no perceptible difference in the driving experience. It's same as earlier.
5. FE comparision done with same XtraPremium from the same station as earlier. Comparison is with FE figures over 2 yrs.
6. I always top up after using around 40-45 litres
7. Tyre pressure is maintained at 29psi and checked every fortnight.
Flood repair summary
1. ECM was not damaged and hence not replaced
2. All climate control dash electronics were replaced. Otherwise AC was fine.
3. Water did not enter the engine. Engine oil was replaced as a precaution.
4. Clutch was damaged. Whole clutch assembly was replaced.
5. Air filter, Oil filter was replaced
6. Gear oil was changed
7. Coolant changed
8. Spark plugs were changed and when I went with the FE complaint a month later, Maruti workshop cross checked the plug gaps, said they were not ok and altered accordingly. No improvement still.
9. Water in the exhaust was drained. As per Maruti, catcon is fine.
I was trying to think of what else has changed since the last time I got normal FE. ICE . The flood happened a week after installing the ICE.
Any pointers on possible explanations for the FE drop? Clogged injectors? Decarb required?
__________________
PIGZILNKILJBSCOMB
Old 13th February 2008, 12:35   #2 (permalink)
suman's Avatar
What about the acceleration per se? Has that dropped as well?
Maybe you should have the injectors cleaned out & give it a shot?
__________________
Land's end, journey's beginning - Safari Dicor VX 3.0L 4x4
Old 13th February 2008, 13:24   #3 (permalink)
shuvc's Avatar
Have not noticed any difference in acceleration. Neither in overall driveability.
Although post clutch change, I can now feel that the earlier one was not fully fit. I can now inch in first gear smoothly with the left foot on the footrest.
__________________
PIGZILNKILJBSCOMB
Old 13th February 2008, 13:48   #4 (permalink)
Team-BHP Moderator
Jaggu's Avatar
Get a complete readings done for the engine parameters. Clutch shouldnt cause mileage drop since any loss due to slip would have been eliminated.
Check for emission also, this should help you understand the health of your exhaust system also.
__________________
The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin
Old 13th February 2008, 14:00   #5 (permalink)
shuvc's Avatar
So what exactly should I ask the Maruti guys to do? In their terms/language ie.
Got it checked a month ago. Readings were pretty normal IIRC. But good point. Let me see if I still have the earlier PUC certificate and then compare the readings with the current one.
__________________
PIGZILNKILJBSCOMB
Old 13th February 2008, 16:31   #6 (permalink)
VJ_MAVRICK's Avatar
I suspect due to the flooding and your baleno getting submerged, the exhaust system might have gone for a toss and get a second opinion from another MASS about the catcon being fine.
Due to clogged catcon the mileage drops and how is it responding @ different rpm's when you push the gas pedal as compared to earlier? I read in somewhere long back that partially clogged converters limit the rpm's.
Again this is just a thought and am not sure about it, but i suspect the mileage drop to do with the exhaust system after it swam quite a long time drowned in there. Other gurus on the forum might add value to their suggestions on your queries though.
__________________
Every SAINT has a PAST and Every SINNER has a FUTURE
VJ_MAVRICK is offline   Reply With Quote
Old 13th February 2008, 16:33   #7 (permalink)
BlackPearl's Avatar
hmmm.... time to get an ffe
__________________
Don't quit when the hill is steepest, for your goal is almost nigh; don't quit, for you are not a failure until you fail to try
BlackPearl is offline   Reply With Quote
Old 13th February 2008, 16:41   #8 (permalink)
shuvc's Avatar
LOL ..
@VJ,
I haven't felt any such issue with response across the RPM range and across the speedo range upto 170kmph. But then maybe I'm not able to perceive the difference if any. However, I do think the car is using up a lot more fuel if revved hard, that what it used to earlier.
If the catcon is at fault then is there are way to repair it? A replacement costs 17K !! So if that is the option then @BP's comment does come into the picture !
A cheaper option this Maruti workshop took for a friends car (6+ yrs old Baleno) was to remove the catcon material !
__________________
PIGZILNKILJBSCOMB
Old 13th February 2008, 16:46   #9 (permalink)
BlackPearl's Avatar
Originally Posted by shuvc View Post
LOL ..
@VJ,
or I can lend you mine at a monthly rental
__________________
Old 13th February 2008, 16:51   #10 (permalink)
VJ_MAVRICK's Avatar
@shuvc ..Then go for a FFE if you dont have a problem and i still feel the mileage drop is due to the exhaust itself with you stating that there was no water inside the engine. Honestly on a baleno FFE would be music to me.
I would suggest get a second opinion from another Maruti Servicing guys.
__________________
Old 13th February 2008, 16:54   #11 (permalink)
gigy's Avatar
shuv, i think your car is absolutely fine. since you have been tracking the FE so regularly till the ICE was installed, and after that the floods damaged your car. i believe you have a good ICE setup and it does take atleast 10amps of current minimum.(sorry didnt check your setup). where is this power coming from? from the alternator-from the engine -from the fuel. we all ignore but its a universal fact.(energy can neither be created nor destroyed). 1kmpl for your ICE.so you have answered the cause in your first post itself.
__________________
Suzuki Baleno
Old 13th February 2008, 16:55   #12 (permalink)
suman's Avatar
Gigy, I guess this is if he's keeping his ICE on continuously, right?
__________________
Old 13th February 2008, 17:01   #13 (permalink)
VJ_MAVRICK's Avatar
well! i missed on the ICE update and gigy might be partly right as it requires power to run the same. However, it does baffle me as to ..you keeping the ICE continuously...
__________________
Old 13th February 2008, 17:15   #14 (permalink)
shuvc's Avatar
75.4 JBL. Not sure how much current that pulls. I actually had 2 amps running till Nov/Dec. The other was the active Soomoku sub. This was taken out in Jan 1st week. But pre-post Soomoku, FE is similar.
ICE can contribute to 1kmpl drop ??
@Suman, that I do. ICE is almost always on. And pretty decent volumes 60-70% of the time.
Come to think of it, I got the worst FE right after I took the delivery of the car around Nov 1st week. It dropped to a 8.2 kmpl with 100% AC and this on a NH-2 Santiniketan trip! I used to easily get 11-12 on such trips.
FE started picking up a bit from December. Did another 400km sedate NH-2 trip around Christmas. Got 12.7 with zero AC. Here again it was around 2kmpl short.
Now it seems to have settled down to a 1-1.5kmpl drop.
__________________
PIGZILNKILJBSCOMB
Old 13th February 2008, 17:21   #15 (permalink)
suman's Avatar
I think its something other than the ICE but I could be wrong because I'm no Baleno expert.
Get the Catcon checked & yes, perhaps the injectors too.
__________________
Thread Tools
here comes the drop-out BillGates Introduce yourself 11 6th November 2007 20:50
Drop in an ocean arunkumar_rec Introduce yourself 2 23rd August 2007 15:33
Post Flood Repairs problem..BHPians advise/opinions required srasania Technical Stuff 10 11th November 2005 10:24
Drop it like its HOT! nitroxx Modifications & Accessories 9 24th October 2005 20:47
Baleno- Drop in Pick-up vivaid Technical Stuff 4 5th August 2005 21:34
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
