| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| Senior - BHPian | i had a query.When a manufacturer states that the car has been detuned from 180 to 150bhp(taking an octavia's example),what kind of parameters are changed when detuning?Also,if we use a chip or a remap to increase the power,wouldnt that be harmful because the manufacturer has actually detuned the car due to India's bad fuel,climate conditions.
__________________ The trouble with life is there's no background music |
| | #2 (permalink) | |
| BHPian | Quote:
In case of turbocharged engines which use solenoid-actuated boost control, the boost map is modified to open the wastegate so that manifold absolute pressure (MAP) is kept to a safe limit with a very wide margin before knock onset. If a traditional wastegate actuator is used, the boost is calibrated by changing the spring tension of the actuator. Usually OEM's do not exceed 1.75 bar MAP on gasoline vehicles for lack of a wide enough margin before knock onset. Even then, the use of 93 RON fuel is mandatory. Testing is also done with 87 RON fuel whereby the ECU retards the timing based on closed-loop operation (knock sensor and PPP detection via ion sensing). When a recalibration is done for lower octane fuel, a more conservative spark advance map is used. The engine is also run leaner (yes, leaner) to keep the EGT within the operating limits of the turbine impeller material, specially when the spark is retarded by large amounts to control knock. This is the complex answer to your question. The simple answer is, the spark advance and MAP are the main controlled parameters for what is commonly called "detuning".
__________________ Miata Turbo Is GO!! Last edited by Rehaan : 23rd February 2008 at 04:27. | |
| | #3 (permalink) |
| Senior - BHPian | So does this hold true for Naturally aspirated engines as well. And when we go ahead and get custom code remaps etc(not targeting custom code but thats the only name i know ) for turbocharger petrol/diesel engines,we are basically running a more aggressive map reducing the margin of safety.Doesnt this harm the engine?
| | #6 (permalink) | |
| Team-BHP Support ![]() Join Date: Mar 2007 Location: Bangalore
| Quote:
!!!Maybe you could explain the driveability map to complete the picture? And how to account / cater for the different gearbox ratios?
__________________ Never believe it cannot be done - it's only that you haven't found out how!!! | |
| | #7 (permalink) |
| Team-BHP Support ![]() | Decreasing the compression ratio will actually "reduce" the FE, not increase it, but with poor quality fuel(low octane + adulteration) having a high compression ratio would cause excessive knocking and lead to engine damage.
__________________ Reclaiming.....! |
| | #8 (permalink) | |
| Team-BHP Support ![]() Join Date: Feb 2004 Location: Bombay / New York
| Quote:
What about running the engine leaner (as you mentioned) causing it to run a lot hotter, would that cause slow damage to the engine, or is the change negligible? cya R
__________________ The memory of you will ride by our side forever. | |
| | #9 (permalink) |
| BHPian | Unless the thermal limits of the valves or the pistons are exceeded, I doubt there would be significant degradation of engine life. However I wont speculate because......see my signature LOL. And I said that they run it leaner to keep the EGT (exhaust gas temperature) within limits to offset the retarded ignition. The principle is LEANER = lower EGT, RETARD = higher EGT. @tsk1979, reduction of compression ratio is an old trick. No one does that anymore. The same safety margin can be achieved only through an ECM re-calibration. Reducing compression ratio does not make economic sense for the manufacturer. Look at most Indian cars and their overseas counterparts. The compression ratio is equal or within +/- 0.5:1.
__________________ Miata Turbo Is GO!! Last edited by ananthkamath : 25th February 2008 at 20:41. |
| | #10 (permalink) |
| BHPian Join Date: Mar 2006 Location: Pune/Bangalore
| I had asked the same question to RD Karthik some time back and his reply matches Ananth's description. The ignition timing is backed off, and considering that no hardware fidgeting is needed for the same, a conservative timing map does the trick without increasing costs. For turbocharged engines, manufacturers can play with the boost threshold depending on the market and the fuel widely available. |
| | #11 (permalink) |
| BHPian Join Date: Sep 2006 Location: Back to Delhi from Bangy
| Hi ananth, how does retarding the ignition advance increase exhaust gas temperature and then how does making the mixture leaner decrease EGT ? Shouldn't both the aforementioned techniques lead to the same consequence, that is an increase in exhaust gas emission due to slightly ineffecient combustion now (since the engine is basically producing less power now). P.S-is the increase in EGT due to an increase in the exhaust gas emissions ?
__________________ The journey is more important than the destination Living life@8500 RPM Last edited by revvedup : 26th February 2008 at 17:09. |
| | #12 (permalink) |
| BHPian | EGT is different from emissions. EGT will increase if you retard the ignition because the ignition process starts a little later in the cycle. That is, the in-cylinder temperature is higher when the exhaust valve opens. Ergo, EGT is higher. Its not accurate to say that leaner equals less power. Its also absolutely wrong to say leaner equals more emission. Too many other factors are involved. Actually my previous statement that leaner = lower EGT is not fully correct, it should be modified to leaner than stoichiometric = lower EGT. This strategy is implemented at cruise conditions and small throttle openings to extend the turbine impeller's life. In an NA engine EGT is generally not an issue.
__________________ Miata Turbo Is GO!! |
| | #13 (permalink) |
| BHPian Join Date: Mar 2005 Location: Minneapolis
| .. it also depends on which side of the AFR u are on. initially leaner = higher EGT till a particular AFR depending on fuel after u go too lean u get drop in EGT. And usually the power is to be made when the relation of leaner = higher EGT is valid. we cant make a blanket statement that leaner = lower EGT Last edited by chetanhanda : 26th February 2008 at 22:01. |
| | #14 (permalink) | ||
| Quote:
Another Query In diesel engines, how do we reduce detonation ?
__________________ The journey is more important than the destination Living life@8500 RPM Last edited by revvedup : 26th February 2008 at 22:55. Reason: typo | ||
| | #15 (permalink) | |
| BHPian Join Date: Mar 2004 Location: Ludhiana
| Quote:
Plus the fact that we Indians are total morons when it comes to mechanical abilities. A very small example is looking around to see how many people will warm up the car or wait patiently for 30sec or so after starting the engine to help the engine oil work up, how many will blip the throttle hard and immediately turn off the engine. You will be surprised to count the number. Especially in cases of turbo charged engines. No Manufacturer is happy honouring more and more warranty claims just because they wanted to give the "Real Deal" to the public. A detuned engine is cheap insurance.
__________________ Punjabi for Life. | |
| Thread Tools | |
Similar Threads | ||||
| What Fuel Type do you use for your Indian Cars "Normal OR Premium" | dadu | The Indian Car Scene!! | 40 | 3rd June 2008 13:34 |
| Indian Hockey Thread: "Chak de India" | greatDrive | Shifting gears | 20 | 19th May 2008 12:23 |
| What makes some cars the "winners" and others the "losers" ? | mithun | The Indian Car Scene!! | 1 | 13th June 2007 06:55 |
| Audi RS5 "M3 beater?" to be launched early next year "PICS" | highwayblaze | The International Automotive Scene | 9 | 18th May 2007 01:59 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
