Old 7th October 2008, 12:34   #16
invincible7's Avatar
Thanked: 154 Times
I have a similar problem, but in my case there is no hissing sound and after driving for around 25-30 kms i see the white smoke like stuff from the a/c wents.. the a/c at this point is not cooling and if i turn off and back on the a/c it starts the cooling back again.
The cooling is perfect with no issues, and the a/c was serviced around 2 -3 months back.
invincible7 is offline   Reply With Quote
Old 7th October 2008, 13:06   #17
Android's Avatar
Guys Its only super cool air heavily loaded with Water Vapours. You will see this effect predominantly in the areas of high humidity or in on going downpour. The best way to avoid that is reduce the cooling of air conditioning and switch to inner air circulation mode. Also check your car AC water vent pipe, if clogged, the moisture will be there in the cooling cavity and can come out as vapours in case of super cooling. Another way of checking clooged tube is to check your car carpets in the foot well, if wet tube needs a thorough check up. And if AC is cooling nothing to worry about.
Android is offline   Reply With Quote
Elantra rare noise (hissing noise) Please help!! manne Technical Stuff 9 28th June 2010 09:24
Whatzatt Noise (Hissing sound) greenh0rn In-Car Entertainment 7 26th December 2009 15:04
Hyundai Elantra - Hissing noise Pranava VS Technical Stuff 11 12th May 2009 10:11
hissing noise from speakers when horn is blown gopz In-Car Entertainment 7 14th June 2007 13:40
K&N Filter hissing noise razor4077 Modifications & Accessories 4 6th November 2006 13:27
