Old 27th November 2015, 19:49   #16
VeyronSuperSprt's Avatar
Thanked: 1,664 Times
Default Re: Techinical differences between Skoda vRS and 1.8TPI ?
Maybe then i wonder why it didn't fit??!!
Skoda is right if they told you Indian vRS is not running the same suspension setup as the euro vRS which has the sport suspension.
Oh is it? Maybe then i should ask the 75 year old doctor who was previous owner of my car whether he has been to Petes
So Skoda India has developed a unique suspension for the India spec vRS which is different from the 1.8 TPI Rider and from the international vRS???
And you are using the colour codes of your spring to arrive at your part number????
And you have 4 different dampers and don't know what to do with them???
This is a good story. One that the VW group might find interesting (humorous at least) in these troubled times.
It's obvious that you need to brush up your knowledge about how spare part supplies are handled by the VW group. There is no need to discuss the colour codes and the part numbers of your dampers a la Maruti.
Relevant Part numbers (or different if applicable) are indicated once the specific VIN number of a car is given. So there can never be a confusion based on the colour of your springs or the part number of your dampers. And you don't tell the ASC what part to order because something doesn't fit !!! (Sorry, run out of icons!!)
Unless you've got the only vRS in India with a different suspension - a one off made for you and your doctor. And the age of your doctor is not a reason to assume that his car's suspension has not been modified when he bought one in the first place.
The reason that the parts didn't fit is a no brainer - but I'll leave you to figure that one out.
Note from Mod - VeyronSuperSprt, if you have points to make, put them forth in a respectable manner.
This kind of tone is not something that helps productive discussions, and it isn't tolerated on Team-BHP.
Last edited by Rehaan : 28th November 2015 at 16:29. Reason: Please see the note at the end of your post.
VeyronSuperSprt is offline   Reply With Quote
Old 27th November 2015, 19:57   #17
Akshay1234's Avatar
Thanked: 7,244 Times
Didn't they do that for the Laura vRS?
Old 27th November 2015, 20:08   #18
Yes, there were some changes to the knuckle etc. The dampers were the same.
Old 27th November 2015, 20:11   #19
Sankar's Avatar
Thanked: 4,657 Times
But i need to discuss colour codes because VAG does Maybe they didn't listen to you? This is what ETKA (not your EKTA) in a Skoda ASS shows for my VIN.
Attachment 1444343
See ^^ colour codes?? VAG has mentioned colour codes, not just Maruti. Yeah they have colour codes for the springs. Rider 1.8 and other Octavia different colour code. Not vRS colour code. Tell VAG if you think springs should be flat black without any Bindis.
Last edited by GTO : 30th November 2015 at 10:38. Reason: Sorry, but we cannot allow such rude posts. Please keep it polite
Old 28th November 2015, 19:26   #20
Attaching images from ETKA showing that the front and rear dampers of the vRS and even the 1.9 TDI were the same. The 1.8 TPI Rider and the 1.9 TDI had the same suspension too.
This post is just so that you don't attempt to rewrite history. Again.
And in case you have a doubt about the source, look at the logo in the top right hand corner.
Techinical differences between Skoda vRS and 1.8TPI ?-tmbagf1u56a009736alh.png
Techinical differences between Skoda vRS and 1.8TPI ?-tmbelm1u85a035182dl3caj7010.png
VeyronSuperSprt is offline   (3) Thanks Reply With Quote
Old 28th November 2015, 20:28   #21
Sankar's Avatar
Now how about posting the details of the springs too? With the colour code, as mentioned in ETKA? For the 1.9 as well as the Rider 1.8.
Will decide on history after that.
Sankar is offline   (1) Thanks Reply With Quote
Old 1st December 2015, 17:27   #22
Rehaan's Avatar
Thanked: 25,043 Times
@ Sankar - How about you upload pictures of the 8 dampers, and also show the part numbers.
@ VeyronSuperSprt - Please share screenshots from ETKA of the springs (1.9 TDI, vRS & Rider).
Hopefully we can get to the bottom of this.
Old 9th December 2015, 21:27   #23
Thanked: 11 Times
@ Sankar
Could you please confirm if vRS has 16" wheel, four wheel disc brakes? Thanks
Naveen
naveenmani is offline   Reply With Quote
Huge differences in prices between cities Zappo The Indian Car Scene 36 28th October 2013 18:20
Differences between Army & Civilian Versions Live To Jive 4x4 Vehicles 38 13th October 2010 11:16
Differences between RE Electra X and the New Electra Twinspark bornin70s Motorbikes 18 17th May 2010 19:23
How much would it cost to Mod a Skoda 1.8TPi to vRS? HAFI Modifications & Accessories 43 28th December 2008 11:57
