Old 25th February 2008, 16:07   #1
mobike008's Avatar
Thanked: 8,319 Times
Default Stalling/Stopping issues with Accent Viva CRDi
I am facing a very strange problem with my Accent Viva CRDi since the past few weeks. It's run about 20K kms. When i start the car in the morning to go to work, i find that when i am in 2nd gear, when i press the accelerator, the car instead of moving forward, it stops for a second ( i notice that the rpm needle stops at 1k and refuses to budge forward even if i am stomping on the gas pedal) and when i release my foot of the accelerator and press again, it moves forward, all this while i am still in motion. Or, if i immediately change it to 3rd gear it moves forward and after a few feet the story repeats.
This weird problem troubles me very badly during the first 5-6km and then it slowly disappears ( still if i press the gas hard, it stops for a few sec and moves forward) but i still have to drive quite slowly and to the entire left of the lane. On a friend's suggestion, tried moving out after sufficient idle time and it was ok for a few days, and then again this morning it re-surfaced
Strangely, this problem completely disappears for a few days and then again re-surfaces after say a week or so. I am due for my 4th service in less than a month, if this continues, will get it done this weekend before time. I'm not sure if this problem is due to :
a) Fuel contamination
b) Dirt in oil/air filter
Inputs will be appreciated
Old 25th February 2008, 17:54   #2
amitwiz1's Avatar
My cousin had a somewhat similar problem in his Scorpio trubo. (Car would stall but start moving when only when the gas pedal was depressed to a point but nothing above that) Serviced and found that it some fuel injection issue. No idea if would be the same in your case.
amitwiz1 is offline   Reply With Quote
Old 25th February 2008, 18:52   #3
Thanked: 7 Times
@mobike008:
from your comments, looks like it could be fuel-related.
This is interesting. Do you, by any chance, remember if this coincides with the fuel level in the tank? I mean, is it so that, this occurs during the days your fuel level is low, and once you tank up this problem vanishes for a few days?
jagan0677 is online now   Reply With Quote
Old 25th February 2008, 23:29   #4
rohan_fonseca's Avatar
Sounds like a fuelling issue. Maybe contamination but get the fuel filter, pump and injectors checked as well.
rohan_fonseca is offline   Reply With Quote
Old 25th February 2008, 23:36   #5
Jaggu's Avatar
Thanked: 8,682 Times
first check air fliters, then move to fuel filter and then to pump, injection etc.
hunch, its due for service and that should sort it, so rush to your a.s.s soon
Old 25th February 2008, 23:46   #6
rider60's Avatar
Thanked: 47 Times
like i told you before please drain the water of the fuel filter if any, have the air filter checked and please take it to the A.S.S. if this is some kind of injector or fuel pump problem they may void the warranty for taking the vehicle to the garage so late!
rider60 is offline   Reply With Quote
Old 26th February 2008, 13:05   #7
mobike008's Avatar
Well, i finished my last tankful of diesel and re-topped it up from a different station this morning. And, it was driving like a breeze. I reckon, i will get it serviced this weekend for sure.
Old 26th February 2008, 13:08   #8
Jaggu's Avatar
double the reason why you should clear the pump of water or any other contamination
Old 26th February 2008, 13:14   #9
tsk1979's Avatar
Thanked: 16,421 Times
Make sure you get the diesel filters replaced in the service, and get the fuel tank checked for any debris.
Sometimes bad adulterated fuel leads to deposits in the fuel tank.
Old 12th April 2008, 13:32   #10
Exclamation
Hi,even i have a similar problem with my 2005 viva run 33k. The car runs fine in the morning, once it runs 10kms and odd the car is sluggish in 2nd & 3rd gears. Then after sometime it comes to normal but last few days the problem is too bad that even in 1st gear though the RPM is at 4-5k the car response is bad.
Have given it to access hyundai bugger said clutch gone and changed it, again same problem so left it again now hes saying drives shaft gone.. Any suggestions??.
Beacon is offline   Reply With Quote
Old 12th April 2008, 14:09   #11
Awaiting Email Confirmation
Thanked: 20 Times
this is the best, most structured approach to the problem.
Old 19th April 2008, 11:27   #12
mobike008's Avatar
My car was due for service during that time and when i went to A.S.S and service advisor took a long drive and strangely those symptoms didnt crop up and i just gave it for normal service and since then i didnt face that problem again. Weird but, that's how it is
Old 19th April 2008, 12:21   #13
Thanked: 146 Times
Recollect a trip from Trichy to Coimbatore on a 118NE. No pull and had to slog in each and every gear. A long drive and one particular 'close shave' while overtaking, reached CBE and had it checked at a A.S.S. Turns out that the air filter had a hell lot of dust (a lot!). A quick cleaning of that and voila, vehicle is running smooth as a 118NE!
HappyWheels is offline   Reply With Quote
Accent / Viva CRDi: Issues & Solutions manishk83 Technical Stuff 61 13th April 2015 14:00
hyundai accent viva crdi lamborghini The Indian Car Scene 35 25th May 2006 19:28
Accent CRDi or Accent Viva CRDi Looks abhibh The Indian Car Scene 4 8th November 2005 17:43
Accent CRDi or Accent Viva CRDi abhibh Sedans 16 8th November 2005 05:58
