Old 26th February 2008, 16:46   #16
Thanked: 34 Times
Originally Posted by Blue Thunder View Post
If it anywhere above 0, the engine is on
OK. I concede . Sometimes I forget that 800 > 0...
deepakhon is offline   Reply With Quote
Old 26th February 2008, 17:48   #17
Thanked: 103,570 Times
Originally Posted by aravindwarrier View Post
Some cars Do have in built protection against accidental cranking, while the engine is running,
Newer cars? Heck, my '97 Classic had this double start protection.
Old 26th February 2008, 18:29   #18
Thanked: 63 Times
Not in swift, Or Am I missing something
lambuhere1 is offline   Reply With Quote
Old 26th February 2008, 21:18   #19
Restarting never happened on the Ikon, because of its loud silent engine noise and clear engine vibration which makes its presence.
But then, when we got our Santro, that very same day, I restarted the engine accidentally eeek! The Santro's engine is so silent compared to the Ikon. Engine vibration was hardly felt.
Shouldn't be a problem at all as long as it happens once in a blue moon.
cya
A
Absar is offline   Reply With Quote
Old 26th February 2008, 21:22   #20
toiingg's Avatar
Thanked: 85 Times
Why not just blip the throttle, just to check before cranking ?
toiingg is offline   Reply With Quote
Old 26th February 2008, 23:05   #21
funkydevil's Avatar
Thanked: 93 Times
hey, iv heard that pressing the throttle often when the car is switched off can lead to unburned fuel comming out of the tail pipe. Is this true???
funkydevil is offline   Reply With Quote
Old 26th February 2008, 23:12   #22
rr_zen's Avatar
Thanked: 268 Times
One more way of preventing this is to check the oil, battery, brake fluid indicators on the instrument panel. Ideally, once the engine has been started, these lights go off.
rr_zen is offline   Reply With Quote
Old 27th February 2008, 10:10   #23
four_tire's Avatar
Thanked: 21 Times
I second that rr_zen, battery light indicator will turn off if engine is in running mode....
four_tire is offline   Reply With Quote
Old 27th February 2008, 10:41   #24
shazikon's Avatar
Thanked: 19 Times
ikon has a nice mechanism for the igniton key.. one has to completely go back that means switching off the engine if already on in order to start an engine. from a on state you cannot turn key clock wise and start.
shazikon is offline   Reply With Quote
Old 27th February 2008, 11:06   #25
manziee_crusier's Avatar
This happened to me many times as novice user.But you can feel it from gear stick so just before starting feel the engine from gear stick(put it to 1st and see)
manziee_crusier is offline   Reply With Quote
Old 27th February 2008, 15:21   #26
Thanked: 149 Times
My wagonR has no double cranking protection.
When double cranking, you are in danger of causing damage to the starter motor's teeth and the teeth of the flywheel.
When a running engine stalls, the indicators on the dash do not light up. (Hmm... will have to check up, will get back with more info on this later)
BaCkSeAtDrIVeR is online now   Reply With Quote
Old 28th February 2008, 09:22   #27
Thanked: 821 Times
No problems with the Palio.
<Joins the Safari guy on the floor rofl>
It does makes its presence known. For which I, a partially heavy-metal-induced-hearing-impaired man, am thankful for. Thank you Fiat, for making a rumbler of a car!
Mad Max is offline   Reply With Quote
Old 28th February 2008, 19:23   #28
Thanked: 149 Times
Ok. I was wrong on the above. The indicators - battery, oil, check engine, etc. light up when the engine stalls.
Old 29th February 2008, 19:21   #29
Post
My friend, who drives NHC, shared this with me. Few days back he sat in the car, slotted into 1st gear and pressed the gas pedal. But the car didn't move . He then realized the car was not turned ON (he had got used the silent NHC engine ).
diabloo is offline   Reply With Quote
Old 29th February 2008, 20:09   #30
Thanked: 13 Times
Am i missing something? for one, the palio is having protection against double cranking. If the engine stalls accidentally, u have to bring the key back to initial position and then crank again!
And also, i feel a stock Palio, is much more silent (at least in cabin) compared to ZEN(Now why dragged poor ZEN into this?, Well i guess ,its because some where i read that ZEN stands for Zero Engine Noise)
aravindwarrier is offline   Reply With Quote
"Check Engine" light also indicates ECU "relearning" ? anandpadhye Technical Stuff 28 19th August 2017 09:54
Manza - Bluetooth restarting the Stereo dhondusaxena In-Car Entertainment 17 17th June 2013 20:38
Tadoba Tiger Resrve - Restarting explorations with a Bang !! abheekg Travelogues 48 7th August 2011 22:17
