Old 5th May 2008, 09:40   #16
Shan2nu's Avatar
Thanked: 86 Times
I just got my suspension stiffened this weekend and boy has it made a difference. It handles brilliantly with minimal body roll, but whats even more surprising is that the ride quality has improved over the stock setup.
I'v gone for a semi street setup which is slightly stiffer than stock.
Shan2nu
Old 5th May 2008, 10:28   #17
lohithrao's Avatar
Thanked: 163 Times
Hi Narayan, As Shan2nu mentioned even i got my suspensions stiffened a year back and am very happy with it!
lohithrao is online now   Reply With Quote
Old 5th May 2008, 10:46   #18
Thanked: 88,942 Times
What exactly did you get done? What parts were used?
Old 5th May 2008, 11:15   #19
Shan2nu's Avatar
Thanked: 86 Times
No parts were replaced. I think they increase the fluid inside the suspension to reduce travel.
It only costs about 1000 bucks per suspension and can be done in a days time.
The degree of stiffness can be set according to the customers requirements. My car has a mild street setup while Wolf's suspension is rock solid (which he needs for drag events).
Shan2nu
Old 5th May 2008, 11:49   #20
manveet's Avatar
Thanked: 585 Times
Originally Posted by ankitahuja View Post
Estimate of prices:
Munjal-Shawa Shocks - umm.. about 3-4k?
Can you confirm the price for above mentioned you posted ? Why the "ummmm .. ." ???
Shantanu mentioned 2100/- per Munjal Showa shocks, and you're saying 3-4k?
Did you replace 2 or 4 shocks ?
manveet is offline   Reply With Quote
Old 5th May 2008, 12:03   #21
Shan2nu's Avatar
Thanked: 86 Times
????.........I hope you're talking about some other Shantanu.
Shan2nu
Old 5th May 2008, 12:41   #22
narayan's Avatar
Thanked: 1,157 Times
Shan2nu
surprised the ride improved after stiffening the springs..doesnt that defy conventional logic ?
what profile tyres are u guys running ?
Shan2nu - did u change any other parts apart from just stiffening the shocks ?
thanks..
narayan is offline   Reply With Quote
Old 5th May 2008, 12:50   #23
iraghava's Avatar
Thanked: 153 Times
When I had my car's suspension overhauled the front chocks cost me 3750 for the set & rear's were 3200.
Old 5th May 2008, 12:54   #24
Psycho's Avatar
Thanked: 95 Times
I don't think they said that they had stiffened the springs but just the shocks. Also increasing just the quantity of oil does not harden the shocks and if that is what is done it will put extreme stresses on the internal valves and seals which could then fail. Would not recommend this till the person who is doing it knows what needs to be done.
Another thing the rear springs of the City are naturally weak and need improvement and so does the roll bar. Have seen great improvement in handling post adding braces both front and back.
Old 5th May 2008, 13:19   #25
narayan's Avatar
true...thanks for pointing that out..but still with lesser movement in the shocks...wont the ride worsen, assuming all other things being left untouched..?
rear springs !! good u raised that point...there definetly is a kind of thud sound from the rear left side over even small bumps...
did the ride improve by any chance after the braces ? am more inclined to the ride than handling ( very unlike a OHC owner - i know ! )
Old 5th May 2008, 14:12   #26
manveet's Avatar
Thanked: 585 Times
Shan2nu
Oh,Sorry .. my bad.
It was four_tyre who mentioned it.
http://www.team-bhp.com/forum/techni...tml#post740679
Old 5th May 2008, 15:20   #27
ankitahuja's Avatar
Thanked: 46 Times
That's because I can't remember how much we paid, I bought them a while back and will have to hunt for the price.
I replaced only 2 front shocks, have sent you a PM.
Old 5th May 2008, 15:25   #28
Shan2nu's Avatar
Thanked: 86 Times
They prob just replace the fluid with another one with a diff viscosity. U can get the details from Sanjay.
Shan2nu
Old 22nd October 2008, 21:30   #29
Mpower's Avatar
Thanked: 1,682 Times
Guys. My dad's reporting that our OHC suspension is making some louder 'thud' noises as she goes over potholes. 2003 model with about 55k on the Odo.
Has anybody replaced the strut mounts that sit on top of the front strut? Its a rubber piece that sits between the strut and the body... wears out and makes noises.
Old 22nd October 2008, 22:09   #30
Ford Rocam's Avatar
Thanked: 16 Times
Can your dad inspect visually signs of oil leaks from strut? could be that too as i had similar problem once. as oil leaks the damping effects goes for a toss resulting thud kind of sound.
Ford Rocam is offline   Reply With Quote
Maruti 800 Suspension Overhaul Cost jramprakash Technical Stuff 37 17th February 2017 21:17
Suspension overhaul for Zen skidrock Technical Stuff 18 16th December 2015 11:55
Baleno Suspension overhaul:any good & reasonable mechanic in South Delhi/Noida kannyrocks Technical Stuff 16 12th December 2011 13:15
Advice on my old Maruti 800 after suspension and brake overhaul amitk26 Technical Stuff 4 9th January 2009 00:09
