Old 1st March 2008, 14:47   #1
Default Lesser Power. My engine don't like me no more?!
Hi Guys!
I have a Fiesta 1.4ZXI pertol, bought five months ago, which has done about 10,000 kms now. I have been experiencing lesser power in the top gears for a while. Earlier it used to pull magnificiently in the second gear and reach upto 50 kmph with the tacho somewhere between 3000-3500 rpm. Now I can barely manage to get it upto 30-35 kmph and the needle is already registering 4000 rpm!
I did a 4500 km run just after the second service (3 months, 3900 km) from Delhi to Goa and have been experiencing this 'powerlessness' since. Have a scheduled 10,000 km service tommorrow. I was wondering if I could get some advice or pointers to take up with the service guys tommorrow.
Thanks a lot!
EngineOil is offline   Reply With Quote
Old 1st March 2008, 19:33   #2
Well tell them your problems , in detail.
I say its your spark plugs , air filter , oil condition etc. Possibly poor Quality petrol too.
Ask them if they can and if they recommend an engine decarb.
PS:Are you a high performance driver?
cyneverdie is offline   Reply With Quote
Old 1st March 2008, 19:45   #3
DirtyDan's Avatar
Thanked: 776 Times
Default Symptoms?
Any other symptoms like maybe your fuel average going down?
Old 1st March 2008, 19:46   #4
amitpunjani's Avatar
Thanked: 101 Times
Don't really that Engine Decarb would be a good idea, when the car has clocked just 10,000 kms.
Amit
amitpunjani is offline   Reply With Quote
Old 1st March 2008, 19:50   #5
Pankaj401's Avatar
Clutch?
Seems like if rpm for given speed is higher than it should be.
Pankaj401 is offline   Reply With Quote
Old 1st March 2008, 20:04   #6
DirtyDan's Avatar
Thanked: 776 Times
Default Clutch
Originally Posted by Pankaj401 View Post
Clutch?
Sounds like clutch but it is so new it should not be. But then it is so new it should not be anything else either.
I would tell them the symptoms and tell them to check the clutch, the entire drive train and the motor mounts. Its probably the clutch and it will be under warranty.
Old 1st March 2008, 20:13   #7
DirtyDan's Avatar
Thanked: 776 Times
Default Oil leak
One other thing, you may want to check and see if you have an oil leak that is dripping on the clutch and causing it to slip. This seems at least possible since it started after an oil change?
Old 1st March 2008, 20:22   #8
Akshay1234's Avatar
Thanked: 7,240 Times
seems like theres a problem with your clutch. but it shouldnt worn so early.
Old 1st March 2008, 21:44   #9
toiingg's Avatar
Thanked: 84 Times
I would second that. Was there a chance of an overfill ? We had a thread about that just recently.
toiingg is offline   Reply With Quote
Old 1st March 2008, 22:50   #10
Rehaan's Avatar
Thanked: 25,038 Times
If this ^ description is accurate (and both speed / rpms are mentioned for second gear), then it HAS to be a clutch problem, and cannot be anything else.
Do you get any burning or rotten egg smell while driving?
cya
R
Old 1st March 2008, 23:06   #11
TARUL's Avatar
.Its probably the clutch and it will be under warranty.
Isn't the clutch a wear & tear part?I am sure you don't get warranty on those.
TARUL is offline   Reply With Quote
Old 2nd March 2008, 03:58   #12
DirtyDan's Avatar
Thanked: 776 Times
Default oil
Look for oil dropped on the clutch.
Old 2nd March 2008, 07:18   #13
chetanhanda's Avatar
Thanked: 44 Times
Hi Guys!
Thanks a lot!
like everyone over here mentioned ..looks like a clutch thing based on ur description..
chetanhanda is offline   Reply With Quote
Americans driving lesser, using public transportation more AUTO_CRAZY The International Automotive Scene 4 17th August 2013 15:57
Pics of forgotten/lesser known remains of our history darklord Shifting gears 1 9th May 2009 20:34
Why palio is lesser priced? pradeepdayanand The Indian Car Scene 48 8th August 2008 12:39
What technologies you don't like in modern cars? sbasak Technical Stuff 15 18th January 2007 11:31
Why I don't like Maruti? prkothan The Indian Car Scene 12 17th August 2005 21:55
