Old 8th March 2010, 17:58   #61
renney.varghese's Avatar
Thanked: 16 Times
Yes, Sanden .. that was the other name. I tried to call up the Subros guys and even send them emails enquiring about the fitment. Still await answers. Do these guys fit the unit as well? Would this cause any later problems with Maruti?
renney.varghese is offline   Reply With Quote
Old 8th March 2010, 22:10   #62
Thanked: 137 Times
Why don't you follow this link
http://www.team-bhp.com/forum/techni...uti-800-a.html
I have a 24000km, non AC, 2001, mpfi Maruti 800. I too plan to get an AC fitted soon. Yet to make up my mind. The toss up is between Sanden and Subros.
Please keep the forum posted on your actions.
skdking is offline   Reply With Quote
Old 16th March 2010, 22:03   #63
IQBAL VEERJI's Avatar
Thanked: 291 Times
Default Replaced AC Compressor with 507 in Maruti 800
Hi. I would like to ask GURUS about AC compressor in my Maruti 800.
It is a 2002 model and come with original compressor which due to aging lost the PUMPING and I was told to replace it with a new one. I was told by my mechanic to replace it with 507 compressor which is large capacity and will give superier cooling, since same was given as original in earler old shape Maruti DX in 1985. I had used this model of car earlier and was very happy with the cooling in those days.
Finnally I got 507 compressor along with bracket for the compressor , Pipes,Engine pulley etc as I was told all these will also have to be changed since erlier original compressor was small in size and had different fixing system of pipes to compressor ,cooling coil,condensor.After getting the replacement done now the cooling is superb,even at noon time the cooling is fantastic, and I dont feel any extra load on the engine it is same as it was with earler compressor,Request with GURUS to say a word or so regarding my modification and to give thier comments will it be of any harm to the engine, I am not worried for any minor extra fuel consumption if any and also since I have FFE installed no extra load or strain is felt on the engine,neither the engine is getting heated up, all signs are same as earlier compressor.
tra load on the engine is felt.
IQBAL VEERJI is offline   Reply With Quote
Old 16th March 2010, 22:43   #64
Awaiting Email Confirmation
Thanked: 319 Times
Default The 507 Sanden is the best small capacity comp for the price.
I concur with your decision to go for the 507. It is no doubt the best small capacity compressor in the market barring none. It has been the work horse for umpteen retro fits from Amby's to Padminis of yesteryears. I plan to put the same unit for my Junkindica sometime next month which requires a bit of metallurgical work. That compressor should outlast your car if you take care not to rev your engine too high with the compressor engaged. That unit is capable of making ice in your back seat.
There will be a slight strain on your engine but if you keep your radiator and cooling fan and fan relay in top condition I foresee no trouble with your car for years to come on account of the 507.
drpullockaran is offline   Reply With Quote
Old 3rd April 2010, 16:06   #65
sumeethaldankar's Avatar
Thanked: 1,153 Times
hello,
what was the cost for the 507 comp?
sumeethaldankar is offline   Reply With Quote
Old 3rd April 2010, 22:30   #66
Thanked: 291 Times
Originally Posted by sumeethaldankar View Post
hello,
I paid 2500/- for a second hand one at chor bazar mumbai but it has started giving problems now with noise after driving for about 30 to 40 kms the compressor starts grinding noise , I plan to show it to the hor bazar guy from whom I brought it but it seems that chap is avoiding me by all tantrums. BEST is go for a new but chinese copy it is costing 5500/-.
Old 4th April 2010, 12:11   #67
suzuki san's Avatar
Thanked: 346 Times
Fit the 507 compressor and to make your 800 an icebox, fit a SuperKing blower as well. I had done this a few years ago on my 800 and the cooling was amaaaaazzzing. Better than a lot of the newer cars I've had. Without a doubt, the best A/C I've had in a car. The downside is that you lose your HVAC system on the dashboard.
Just my 2c
SS
suzuki san is offline   Reply With Quote
Old 28th April 2010, 14:40   #68
Thanked: 16 Times
After a lot of research and follow up, I got the Subaros model fit into my M800. Tested this on my drive back from Nasik and it performed well. The mileage is something which i need to test now. A big thanks to everyone here who helped me out. I shall eventually post reviews about the same in this forum
Old 30th April 2010, 21:37   #69
Default Restoring a/c for the dx 800
I have a 97 model 800 Dx version with a/c.Now my a/c died 3 years ago when i fitted the car with a FFE .I had got it fixed before the FFE twice but every time it kept dying so i let it be.I know the gas that would be filled in a/c is no longer "legally" available now.I want to get my a/c going again, so can anyone tell me what components i should go for a change.
Should i change the entire compressor and condenser unit with a brand new one or shall i try to use existing one.I have changed some of the a/c pipes before with new ones so i can rule out that but i am not sure about the comp as it was unused for 3 years.So help me out guys,thanks.
Old 30th April 2010, 23:38   #70
Thanked: 152 Times
you can use r134 in r12 system .I have seen it working in a sanden setup in delhi.It was good enough .
Trust_In_Thrust is offline   Reply With Quote
Old 1st May 2010, 14:35   #71
Are you saying i can use the new kind of gas in my old compressor without any modifications?
Old 2nd May 2010, 04:40   #72
Thanked: 152 Times
Atleast this is what i saw and it was working fine.The guy had a 507 compressor and superking blower cum cooling coil .
I know technically we need top change a lot as R12 and R134 work at different pressure but i have seen it to work fine enough.
I would say get the R134 filled up may cost around 700-800 Rs .Check if you are happy why spend thousands.
Old 2nd May 2010, 08:02   #73
scorpian's Avatar
Thanked: 232 Times
Infractions: 0/1 (5)
yes u can fill 134a in replacement of your r12,thats what most of the a.c techs around the country ared doing,Just did the same to my uncles zen and it works great,no change,no mods just replaced the compressor oil with 134a compatible oil,flushed with nitrogen,checked for leaks and then filled 134a...thats it.
Go to MASS and they would tell you buy new compressor,piping and crap for the same conversion,somehow iam happy that our indigenous roadside guys find a solution for every problem.
scorpian is offline   Reply With Quote
Old 6th May 2010, 22:36   #74
If you live in mumbai can you direct me to the garage who did the change for your uncle's car.
thanks
Old 17th May 2010, 16:07   #75
Thanked: 16 Times
Finally I got a Subaros kit into my 800. The complete setup was done at the MAS and it has been over 15 days now, with two long drives between Mumbai and Nashik. The AC has responded quite well during these extreme temperatures. There is a slight load on the engine, but not too noticible during the drive. The fuel consumption has increased by 2 points. To counter that I use the ON / OFF method of the AC on the slopes and Climbs, which saves fuel and the load on the engine. I had a long waiting time for the kit, as MAS say that they do not keep such kits in stock, and hence had to procure it from the Subaros outlet at Andheri. I shall let you know of more of my experiences. The whole fitment took approximately 7 hours including a complete road test.
Which home/office AC (air conditioner) to buy ? adityapd Gadgets, Computers & Software 5957 7th July 2018 11:26
Automotive air conditioner servicing & maintenance vebmetal Technical Stuff 210 25th June 2018 16:34
Advice on fitting an air-conditioner in the Mahindra Thar DHABHAR.BEHRAM 4x4 Technical 318 27th November 2013 15:01
Correct refrigerant level of a automobile air conditioner Sang Technical Stuff 6 15th May 2009 10:26
Best ROOM Air conditioner Max Shifting gears 2 3rd April 2006 09:52
