Old 17th May 2010, 17:30   #76
Guys, around the year 2000, we had a Maruti Suzuki 800 DX and it had a Subros AC system. So, IMHO, Subros is the best option b'coz in DX models, Subros AC system comes factory fitted.
thorpe is offline   Reply With Quote
Old 18th May 2010, 11:07   #77
Thanked: 132 Times
Default price of ac in M800?
Can someone give the expenditure he incurred any time recently for fitting a/c kit in his non a/c M800?
skdking is offline   Reply With Quote
Old 18th May 2010, 11:28   #78
anujmishra's Avatar
Thanked: 338 Times
Default AC WorkShop in Bangalore
Where in Bangalore best AC workshop available? I want to service AC of my 800. I feel cooling is reduced little bit, but I am not sure, it may be my assumption. Experts should able to check and verify. Never serviced AC for last 7 years so far. It is giving uninterrupted service and no trouble.
anujmishra is offline   Reply With Quote
Old 18th May 2010, 14:23   #79
renney.varghese's Avatar
Thanked: 16 Times
Well, the price (Including endorsement in the Insurance) went to approximately 30K. Completely hassle free as MASS had the right expertise into this area, including the insurance part. The kit itself costs around 24 K, additional costs include, labor charges, gas costs and wirings. They also did a performance test on the engine and also checked the clutch plate, fan belt and pulley for wear and tear before they started.
renney.varghese is offline   Reply With Quote
Old 18th May 2010, 18:30   #80
Thanked: 658 Times
that is indeed very expensive at 30k.
If you have done it from outside it would have been cheaper as they are not using MGP but from OEM subros.
Cost of compressor as MGP is 14k.
But if you buy directly from subros. Its 10500/- MRP on box. so you get more discount on MRP.
Old 18th May 2010, 18:38   #81
blackstallion76's Avatar
Thanked: 11 Times
Can we fit a similar Subaros to Alto LX model?
blackstallion76 is online now   Reply With Quote
Old 18th May 2010, 23:41   #82
Thanked: 658 Times
Ofcourse we can! Find a AC guy in your city or you can do directly to M.A.S.S.
Old 19th May 2010, 10:50   #83
sumeethaldankar's Avatar
Thanked: 1,022 Times
Originally Posted by renney.varghese View Post
I had a long waiting time for the kit, as MAS say that they do not keep such kits in stock, and hence had to procure it from the Subaros outlet at Andheri. I shall let you know of more of my experiences.
Renney seems to have got the kit from Subros themselves.Can we know the price of the subros.
thanks
sumeethaldankar is offline   Reply With Quote
Old 19th May 2010, 11:18   #84
Thanked: 658 Times
I got a brand new compressor from Subros couple of months back for a friend for 9800/- for a Zen. Which will also fit on a ALto i am sure.
It comes in a proper Box. MRP is stickered properly by Subros.
Old 19th May 2010, 11:35   #85
Thanked: 11 Times
For fitting A/C for Alto, MASS is asking 28K. But, i am sure its much less if we go aftermarket.
Can anyone provide me the contact of Subaros in Bangalore or any website?
What would be the approx cost?
Old 19th May 2010, 11:44   #86
Thanked: 132 Times
Default sanden or subaros?
Well, the price (Including endorsement in the Insurance) went to approximately 30K. Completely hassle free as MASS had the right expertise into this area.
Is it true that MASS fits only Subaros compressor? And not Sanden.
I have been told that Sanden gives superior cooling.
What's your recommendation?
Old 19th May 2010, 20:39   #87
Thanked: 658 Times
some batches of ALTO and ZEN (old one) did came with sanden systems
SirAlec is offline   (1) Thanks Reply With Quote
Old 22nd May 2010, 18:28   #88
Thanked: 16 Times
I believe Sanden has a bigger compressor compared to the Subros, which possibly puts a higher load on the engine. seem to have read this in some post on this forum. Guess i had a very very pricey deal with MASS
renney.varghese is offline   (1) Thanks Reply With Quote
Old 23rd May 2010, 00:12   #89
Thanked: 658 Times
a bit of correction. Smallest sanden compressor is 80cc, where as smallest that subros make is of 117 cc.
Also I guess that largest subros makes is 175cc used in tata safari and sumo.
Old 30th May 2010, 12:58   #90
i got my busted a/c fixed from Gomes at Santacruz.It cost me 4300 bucks, 2000 for labor + gas + leak test,1800 for servcing compressor servicing and 900 bucks for a busted valve.
The a/c seems to be running fine and i would like to mention the guy was able to run the compressor using the now available gas as he mentioned it runs fine even with old type compressor.
Keeping my fingers crossed,hoping the a/c won't give me trouble as it had happened before.The only slight problem is the a/c idle speed is at 1400 rpm which is too high and will get corrected next week when the garage has asked me to bring in the car for a inspection again.
Which home/office AC (air conditioner) to buy ? adityapd Gadgets, Computers & Software 5554 9th December 2017 03:32
Automotive air conditioner servicing & maintenance vebmetal Technical Stuff 169 20th November 2017 14:39
Advice on fitting an air-conditioner in the Mahindra Thar DHABHAR.BEHRAM 4x4 Technical 318 27th November 2013 15:01
Correct refrigerant level of a automobile air conditioner Sang Technical Stuff 6 15th May 2009 10:26
Best ROOM Air conditioner Max Shifting gears 2 3rd April 2006 09:52
