Thread Tools
Old 4th March 2008, 20:00   #1 (permalink)
Default Major Service
Guys, I tried to put this question is other thread http://www.team-bhp.com/forum/techni...ecklist-3.html (Maintain the car yourself. A service checklist?)
However haven't got any response there, I would be getting the work done tomorrow, as I need to head out of town this weekend, so just opening this thread so that it catches more eye*****.
I made a list from the above mentioned thread and went to my neighborhood work shop...apart from the regular stuff, this what I was told about the checklist..
Please provide some feedback, as I have got the stuff, however will get it serviced tomorrow..
Esteem Type 1 - 97, Carb.
1. Engine Oil - I have got Mobil Super. Dealer told me that its at par with Shell Helix ultra, not sure about it. Secondly the packing date is March 2007, its almost a year old, does it impact the quality ? is there a good before date ? as none is mentioned on the pack.
2. Radiator Flush & Coolant - 2 lt, Golden cruiser, recommended by the dealer again.
3. Gear Oil - 2.5 Ltr, HP Gear Drive - EP 90
4. Spark Plugs - Champion, 10 YC
5. Injector and Fuel Pump Cleaning - Workshop guy says that only MPFI cars, in carb the fuel pump is fixed and cannot be cleaned. is it true ?
6. Clean/Adjust Throttle - Again only in MPFI
7. Timing Belt - Saying Rs.550 is the labour charge for the same. The belt is Rs.270
I also got a product i.e. called System G, its a petrol additive, Rs.220 for 200 Ml..has anyone actually used it ? is it recommended ?
Shashank.A is offline   Reply With Quote
Old 4th March 2008, 21:28   #2 (permalink)
Xehaust's Avatar
Have got an 98 Astra and am thinking on all the same things mentioned here.
Xehaust is offline   Reply With Quote
Old 5th March 2008, 21:46   #3 (permalink)
So, I got all the work done today, it took me 7 hours at the workshop..
1. Got gear oil and engine oil changed infront of myself, topped the brake fluid. (Rs.50 service charge + cost of lubes)
2. Got all three filters changed.
3. Timing Belt and bearing changed (belt Rs.270, Bearing Rs.400 and Service Charge Rs.550)
4. Tappets/Rockers Adjusted, engine tuned by computer (Service Charge Rs.275)
5. got radiator flushed, it was sent to a third part workshop, Rs.250 for the flushing and Rs.150 service charge of the workshop who removed, sent for flushing and fitted it back), also added new coolant.
6. Got all the belts and hose pipes changed.
7. Water Pump/water body was also changed.
Old 6th March 2008, 06:20   #4 (permalink)
Xehaust's Avatar
Great! So how does the car feel and what were the total expenses?
Old 6th March 2008, 07:41   #5 (permalink)
it has become quite, smoother, pickup has gone up...
Old 6th March 2008, 19:34   #6 (permalink)
Xehaust's Avatar
Could you also mention what were the total expenses incurred?
Old 6th March 2008, 21:04   #7 (permalink)
Oops...I am sorry didn't mention that last time...Rs.1400 was total labour charge..and all the parts and lubes costed Rs.3500..included all the hose pipes, all the belts including the timing belt, brake oil, gear oil, engine oil, water pump/body, timing bearing, return pipe, battery box, clamps, air filter, fuel filter, oil filter...
I hope I haven't missed anything...but now if I look at it, it was really cheap..and everything was 'genuine' i.e. OEM or stock...except for the battery box, Maruti one was Rs.400 and local was Rs.60, I went for local one, as it doesn't have any role in the car except for holding the battery...
That is the beauty of Maruti product...but yours is Opel, I am sure you will bleed a lot more than me..
Old 7th March 2008, 00:45   #8 (permalink)
Xehaust's Avatar
Nice!!! All that in 5K. I wonder what its gonna cost me and when will i get around to it. Too busy right now but have been wanting to do this major service since a long time even thought the car is working just fine.
P.S.- Have you noticed that this thread is only about a conversation between you and me
Old 10th May 2008, 08:59   #9 (permalink)
Now its couple of months since I got this done, have driven it around 6k, got it checked couple of weeks back and all the oils were fine..
However will get it checked today itself.
Can someone tell me, if the Engine oil seems to be good, can it be used or it still has to be changed.
Thread Tools
Major Scratches on the Windshield PatienceWins Accessory/Parts Reviews 32 27th September 2007 10:06
Pune: 2 major accidents zakaaaaasss Street Experiences 20 27th August 2007 23:26
MAJOR CONFUSION .. help needed !! khaadu75 Sedans 27 15th June 2007 22:44
Major Cruisers always_dui Shifting gears 1 12th May 2007 16:37
My first major accident...! veyron1 Street Experiences 34 31st May 2006 20:34
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
