| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Aug 2007 Location: New Delhi
| Hi Guys! I am a little confused about the factory fitted Turbo which comes in diesel engines (Swift 1.3 Multijet, Indica Turbo V2, Scorpio etc). *Are these turbos "Soft Turbos"? i.e they are electronically limited to a particular boost range(eg. 5-7psi or lesser) which is a compromise between economy and power. *If the above is answered "YES" then can the stock ECU be remapped for a higher boost range(eg.7-9psi or more) or a stand alone one would be required. *Can the factory fitted Turbo be replaced by an after market turbo.(brands like Garett etc.) *Are turbos used for petrol engines the same as the ones in diesel, i understand that their operation is based on the same principles of induction.
__________________ ABHIK <<<If everything seems under control, you're just not going fast enough>>> |
| | #3 (permalink) | |
| BHPian Join Date: Mar 2008 Location: Minneapolis, MN/Hyderabad
| Quote:
So in theory, yes, you should be able to up the boost and remap your tune to make more power. However just about every car/manufacturer controls boost in a different way, so you have to figure out the system being used on your particular car and then we can find the best solution to upping the boost and retuning to compensate. In general, you would be disconnection the way the manufacturer controls boost and would be controlling it yourself. Unless you are able to make that change in the stock ECU and have it accept the change. And yes, any/all turbos can be replaced with another. However, availability of turbos that will fit your stock manifold depends on the flange style being used on your car. In general, most people will have a new manifold made, in which case you can use whatever turbo/flange you would like. In this case, all new intake piping, intercooler piping, and downpipe piping would have to be fabricated as well. And yes, diesel and gas/petrol turbos function the same way and are technically interchangeable. However, they can have some differences in build strategy. Some of the diesel turbos are build more sturdy for higher pressure situations and can handle higher boost thresholds(like 60 - 80 lbs of boost in very extreme setups). For lower power applications, turbos designed for diesels may not be the ideal setup for a gas/petrol car not looking for high hp/boost levels(which need a stronger turbo which can take the abuse, I'm talking over 40psi etc), as the shaft and components are generally heavier and could/would affect spool up(slower). I hope this makes sense, if not, just ask me to clarify whatever is not clear. | |
| | #4 (permalink) |
| BHPian Join Date: Mar 2006 Location: goa
| the term "soft turbo" is related to the use of turbo with very low boost , it is mainly when a turbo charger is used without an intercooler [ like in the tevera, seina ,old trax]. The turbos on most of the Indian cars have mechanical wastgates [spring loaded for boost control] so that there is no over boost. they can be changed to any brand with proper engineering nohow, they should match the engine properly. one can use electronic boost controller for the turbos but ,these are mainly used where the engine can handle overboost with out destroying itself, so the scorpio and other cars mention by abhik should be that well engineered and also the clutch,gearbox and diff have be be able to handle the increase in power.... |
| | #5 (permalink) |
| But there is a vacuum line attached to the wastegate actuator correct? From the sounds of it, it is a normal wastegate. There are internal wastegates and external wastegates. Most stock turbo applications have internal wastegates and have an actuator and a vacuum line attached to it. Upstream the vacuum line is attached to the boost control device(whichever style is used). And from there the boost control device is sourcing vacuum/boost probably from somewhere on the intake manifold. No car can handle "over boost", otherwise known as boost spikes. All cars need to be tuned for the boost levels they are running, thus the need for boost control/wastegates etc. Same goes for the clutch/gearbox etc, that applies to all cars. |
| | #6 (permalink) |
| BHPian Join Date: Sep 2006 Location: Bangalore
| Most turbos can support more than 5psi of boost. Excess boost could cause over heating and will need to be controlled using the intercooler and the wastegate ensures that the pressure doesnt exceed a particular limit. Typically the wastegates can be mechanical or programmed for a certain psi. It may be true that the amt boost may be regulated for optimum point on most cars but there defenitely is chance to increase the boost with carefull engineering so that there are no side effects to the increase in the boost. I guess the amount of boost is proportional to the compressor and cylinder capacity aswell |
| | #7 (permalink) | |
| Quote:
What type of overheating are you referring to? Of the engine, or the air going into the motor? Neither is good, but are caused by different things. Running turbos without intercoolers is not a good practice pretty much ever. Some manufacturers do this for cost cutting, but it's not a great practice. Wastegates are always mechanical, but the method of boost control(wastegate control) varies between mechanical or electronic. You can raise the boost on all cars, and the set boost from the factory is done so for many different reasons. Either longevity, power, economy, whatever the reason, it's not because it's "optimal". To raise the boost, you need proper fuel and ignition(timing) control, along with all the supporting cast: fuel system capable of keeping up, intercooler capable of keeping up, some sort of tuning capability, etc etc. It is not advisable to just turn up the boost without taking the proper precautions. The boost can technically be raised as high as you want on just about any turbo, but the size of the turbo will determine how efficiently it is working in the range of power and boost you want to run. The size of the turbo or cylinder has nothing to do with how much boost the turbo or motor can run. The state of the motor, and the strength of the motor, the fuel, etc, is what determines what boost can and should be run. | |
| | #8 (permalink) |
| BHPian | Here's where I disagree. My source in Holset tells me that shaft sizing in diesel applications is much less critical (and hence smaller) because there is less chances of compressor surge than a throttled gasoline engine. Also, OEM turbochargers for gasoline engines usually have a turbine impeller and turbine housing material capable of withstanding much higher EGT.
__________________ Miata Turbo Is GO!! |
| | #9 (permalink) | |
| Quote:
| | #10 (permalink) | |
| Quote:
| | #11 (permalink) |
| BHPian | Soft turboes may be another term for light pressure turbos. They don't create enough pressure to do big dia plumbing, big intercoolers, ecu upgrades etc. Replacing stock turboes with bigger turboes and upgrading the ECU alone won't work, if you are looking for more power from diesel engines. Everything associated need to be changed or alteast made sure won't fail. Theoretically performance turboes on petrol engines and light pressure turboes are same. But that's theory. The components, electronics and what not are different. When air is worked upon, ie, pressurised, it gets heated up, so needs to be cooled. When you extract work from pressurised air, air gets cooled. Disclamier:- all these are theories and may be wrong:-)
__________________ Rocket Science?? what is it? In theory, there is no difference between theory and practice. But in practice, there is. |
| | #12 (permalink) |
| guys thanks so much for the knowledge and your inputs. i wanted to asks that the mechanically controlled wastegates that most of ypu are talking about; would a blow off valve do the same and can a blow off valve be controlled(electronically or mechanically) to control boost pressure.
| | #13 (permalink) | |
| Quote:
*And does boost pressure vary for a diesel and a gasoline engine?(lets say for eg. if we have the same turbo charger for both engines)
__________________ ABHIK <<<If everything seems under control, you're just not going fast enough>>> | |
| | #14 (permalink) | ||||
| Quote:
These are street cars driven on the street. The craze for horsepower here is insane. We have tuned cars to over 45psi in street trim. A good friend of ours races his car at something like 65psi and about 1400hp. | ||||
| | #15 (permalink) | |
| Quote:
| Thread Tools | |
Similar Threads | ||||
| Car confusion! | Vayalam | Sedans | 33 | 31st July 2007 10:22 |
| conFUSION !!! | murlee | Hatchbacks | 31 | 31st March 2007 12:51 |
| Never Ending Confusion | udit78 | Sedans | 55 | 4th August 2006 20:56 |
| Confusion v/s Confusion | geek | Sedans | 32 | 7th July 2006 19:23 |
| Euro-3 Fuel - Confusion !! | normally_crazy | The Indian Car Scene!! | 24 | 8th September 2005 14:10 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
