Old 7th March 2008, 16:40   #16
Jaggu's Avatar
Thanked: 8,687 Times
do an italian tune up, helps most often
Old 7th March 2008, 17:02   #17
DirtyDan's Avatar
Thanked: 776 Times
Originally Posted by gemithomas View Post
Started. And i see the rpm meter dancing between 2500rpm and 500 rpm.!!! I drive away and this dissappears. Never expereienced that again. Lucky Me!!
What could that be.??
Was the tachometer dancing or was the motor also fluctuating? A momentary electrical fluctuation will cause a tach to dance all over the place. If it starts happening regularly have someone check your battery and alternator.
Old 9th March 2008, 21:09   #18
gemithomas's Avatar
Thanked: 138 Times
Well. I dont see any competent italiano indiano around-o town-o.
Had the same issue today morning also. The rpm meter moved from 2.5 to .5 mark. (just as a KSRTC Bus would do when kept at idle) The engine stalls when i try to move. Had a 100km trip. Ripped her for some time. Now she seems to be perfectly fine. Will wait for the next time she feels like dancing.
Old 9th March 2008, 23:47   #19
Thanked: 17 Times
Hello!
Twingo, tango and 100kmph doesn't go well together always. So, be careful before you try to rip into her.
Old 10th March 2008, 09:00   #20
gemithomas's Avatar
Thanked: 138 Times
Originally Posted by speedzak View Post
Hello!
I was just trying the "FLush OUt" all those Blistering barnacles out of those throttle bodies...
Old 10th March 2008, 09:20   #21
Thanked: 17 Times
As long as I know, what you tried to do would've only FLushed In those blistering barnacles. And that is more bad. My thoughts.
Get in touch with some experts soon in this department. (Oh! I forgot. You're stuck with the wrong car. You'll hardly find an expert for it na!) LOL.
Old 10th March 2008, 11:29   #22
gemithomas's Avatar
Thanked: 138 Times
Thanks a lot for the reassurances.
Old 10th March 2008, 12:44   #23
spadival's Avatar
Thanked: 16 Times
Did the adventure come with the "Drive By Wire" thingy?
If so, could be a problem with that causing the fluctuating RPM.
spadival is offline   Reply With Quote
Old 10th March 2008, 13:42   #24
gemithomas's Avatar
Thanked: 138 Times
No it think its the FIAT Diesel that came with Drive By Wire.
Old 10th March 2008, 16:30   #25
Jaggu's Avatar
This IS italian tune up Yes it sometimes really help, if the case is that of minor clogging and all.
Wait and see, if issue reappears head for a good mech with proper tools.
Old 11th March 2008, 10:29   #26
harmon_bro's Avatar
Please remove your plug wires and put them back on. Also check when was the last time you had your plugs replaced...
harmon_bro is offline   Reply With Quote
Old 11th March 2008, 10:48   #27
hellspawn's Avatar
Infractions: 0/1 (10)
Same problem had cropped up once in my siena,drive it like a madman and rip her through every gear and the problem will get sorted out.Most probably you might have tanked up from a bad petrol station.Bad fuel can cause this problem.
hellspawn is offline   Reply With Quote
Old 11th March 2008, 10:49   #28
gemithomas's Avatar
Thanked: 138 Times
The car has done just 18.5K. When should i change the spark Plugs?
Old 11th March 2008, 11:45   #29
Jaggu's Avatar
20 k kms is a good time to replace the plugs.
Help with Rpm vs Speedo Speed viper Technical Stuff 39 20th January 2013 20:49
Is Fuel efficiency strictly a function of RPM or is it speed+gear+RPM? Astleviz Technical Stuff 54 25th November 2011 09:22
Ikon 1.6L jerking & rpm fluctuating issue ghostrider Technical Stuff 12 4th October 2009 09:17
HELP-How to connect RPM meter in SWIFT tabrez02 Modifications & Accessories 28 11th April 2007 14:25
rpm below idle rpm tortoise Technical Stuff 12 2nd April 2007 00:51
