Old 6th March 2008, 13:35   #1
greenhorn's Avatar
Thanked: 1,519 Times
Default Queries On The Indica Dicor's Footwear
I've been wondering about this for a while.
They are 165x65R14, apparently the same as the turbo, but the manual recommends higher air pressure for them.
Similarly, the height and some other specs are a bit different for the dicor. I think the body is the same , which leads me to suspect the wheels again.
Can someone please Throw some light on this
greenhorn is online now   Reply With Quote
Old 6th March 2008, 13:40   #2
dinu2506's Avatar
Thanked: 351 Times
I have also been apprehensive of this. My Indigo (2003) model owners manual specifies 26 psi pressure which I feel is too low. I understand the recent model specifies a higher pressure.
dinu2506 is offline   Reply With Quote
Old 6th March 2008, 16:13   #3
iraghava's Avatar
Thanked: 156 Times
I don't think that you have 165/65 R14, it should be 175/65 R14.
Old 6th March 2008, 19:48   #4
kpzen's Avatar
Thanked: 1,655 Times
Ishan, I think Indica Dicor comes with 165/65-14 Bridgestone S322.
Old 6th March 2008, 21:36   #5
greenhorn's Avatar
can someone confirm that ?
Old 6th March 2008, 23:44   #6
rider60's Avatar
Thanked: 47 Times
Indica V2 Dicor: Specification
here this says its 165/65-R14
for the dicor.
rider60 is offline   Reply With Quote
Old 7th March 2008, 08:01   #7
adityamunshi's Avatar
What is the recommended tyre pressure ?
For my DLG TC (2007) its 28 front 24 rear.
adityamunshi is offline   Reply With Quote
Old 7th March 2008, 12:02   #8
kpzen's Avatar
I think 24psi is way too less for an Indica.
Old 7th March 2008, 22:19   #9
greenhorn's Avatar
aight. here are the specs , straight out of the manual.
NA- 165/65 R13 Tyres, 30 psi front, 28 psi rear
Turbo-165/65 R14, 28 psi front, 24 psi rear
Dicor- 165/65 R14, 36 psi front, 28 psi rear
Track front : 1400 for NA/TC, 1380 for dicor
Track Rear: 1380 for NA/TC , 1374 for DiCOR
overall height: 1485 for NA/TC, 1500 for DiCOR
GC : 166 for NA/TC, 165 for DICOR
ok, now here is the spec, can anyone say why they are different for what is essentially the same car
PS: my DLG has Bridgestone S322's
Old 31st May 2008, 13:09   #10
Thanked: 27 Times
Default tyre pressure..
I have the same doubt. The owners manual suggested 28psi front and 24psi rear for my DLX turbo Indica.
When I went to the tyre shop and switched to tubeless tyres, the guy really gave a weird look when I asked him to put 28/24.. he whined a couple of times and said 'tata motors will say anything saar, tyre pressure should be 32psi else FE will be very bad'..
after some talking he agreed to put 30psi for all tyres.. nothing less than this..
why is the recommended tyre pressure so difference for these models? and what is the correct tyre pressure for indica turbo dlx, front and rear?
GenuineOptimist is offline   Reply With Quote
Old 31st May 2008, 16:33   #11
greenhorn's Avatar
DLX/DLG has 14" tyres as opposed to the others which have 13" Maybe that's why
Ideal footwear for driving... balashome The Indian Car Scene 95 19th November 2013 16:45
Tata launches New Indica, Indigo CS, Indica V2 DICOR, Sumo Grande, Xenon. Details.... ashutoshb The Indian Car Scene 102 19th December 2008 22:53
Buy Indica DLG or wait for Indica Dicor??? gags12 Hatchbacks 6 9th October 2007 13:01
Indica TCIC vs. Indica DICOR hell_rider The Indian Car Scene 11 13th March 2007 21:22
New footwear for my Lancer Rodeo Tyre & Alloy wheel Section 9 2nd May 2006 12:35
