Old 10th March 2008, 15:03   #16
ece2k2's Avatar
Thanked: 271 Times
Default clarification about some noise
Guys,
I am hearing a short low volume "wishhhhk" kind of sound (as if some air is escaping from the tires) when the front tires goes over speed breakers. Is this a problem or a normal scenario. This happens with the front tires at different air pressures (28 or 30 or 32 psi), so does not seem to be an issue due to the tire pressure.
- Karthik.
ece2k2 is offline   Reply With Quote
Old 10th March 2008, 16:09   #17
Jaggu's Avatar
Thanked: 8,674 Times
Its the car shokies working
Old 10th March 2008, 16:16   #18
binz's Avatar
Thanked: 412 Times
Originally Posted by ece2k2 View Post
Guys,
- Karthik.
Its normal,..suspension is doing its job.Nothing to worry about.
Old 10th March 2008, 17:19   #19
ece2k2's Avatar
Thanked: 271 Times
thanks Jaggu and binz - that is comforting. I got concerned about this because I have never heard this sound from my Swift Vxi. I could not hear this kind of noise from my Swift LDi's rear tires either. So looks like a different front suspension setup for Swift Diesel for the engine weight!
Old 21st March 2008, 09:30   #20
Thanked: 13 Times
I was running 30 / 28 for the front and rear combo and it does eat into the mileage a fair bit.
Iv been getting 13ish with a combo of bumper to bumper traffic and also some late night 4000rpm shifts. Wasnt a 100% A/C person but now gotten accustomed to it :-|
Old 21st March 2008, 11:02   #21
Jaggu's Avatar
s0uljah: in your case the air pressure might be just about ok since you are running 205's on 15 inch, right?
Old 21st March 2008, 11:14   #22
RufRoc's Avatar
Thanked: 9 Times
I upgraded my Swift LDi tires to Michelin XM1+ Energy 185/70/R14 mated with Lenso 14" alloy rims
To my knowledge (when I last checked) Lenso didn't have alloys in 14" . Which model is yours?
Btw, hope you've found your sweet spot in terms of handling and ride comfort.
RufRoc is offline   Reply With Quote
Old 21st March 2008, 19:48   #23
Thanked: 13 Times
Yep Jaggu, 205/55/15 it is. 32/30 combo can get hella bumpy and uncomfy.
Is the stress on alloys with the 2 psi difference negligible or is there a serious amount of stress transfered ?
Old 21st March 2008, 21:29   #24
Jaggu's Avatar
what i know is, as the width increases and the profile decreases, psi can be dropped marginally without much impact on tyres or the alloys. So a 2 pound drop shouldnt be big deal. I would rather worry about those unsuspecting CRATERS at high speeds, for which a 2 psi diff might not really help.
Old 21st March 2008, 21:57   #25
PatienceWins's Avatar
Thanked: 284 Times
Congrats!!
The price you have got seems good. I was quoted 3600 for a XM1+ 185/65/ R14 for my Getz by Sai Iyengar, Lal Bagh Road.
My belief is that that XM1+ is comfort oriented tyre with decent grip. No tyre noise. I plan to upgrade to XM1+ once the stock tyres are done.
How do you find the ride and handling with XM1+?
PatienceWins is offline   Reply With Quote
Replaced No-name alloy wheel nuts with Gorilla wheel nuts. Sankar Tyre & Alloy wheel Section 36 21st February 2013 12:34
Does a Tire/Wheel Upgrade Damage Wheel Bearings?? Epic Technical Stuff 40 19th September 2012 15:29
Wagon R tire upgrade, inner tire wall touching suspension Wind splitter Tyre & Alloy wheel Section 36 6th August 2012 20:43
Problem with my Baleno's spare (alloy) wheel ron_9191 Tyre & Alloy wheel Section 8 6th July 2011 14:13
