| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #16 (permalink) | |
| Team-BHP Moderator ![]() Join Date: May 2004 Location: Bangalore
| Quote:
__________________ The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin | |
| | #17 (permalink) |
| Newbie Join Date: Mar 2008 Location: Mumbai
| Thanks Jaggu - will have the engine mounts checked at the next service . Hope this is not an expensive service job as i plan to sell off the car soon .
__________________ It is better to burn out than fade away - Kurt Cobain |
| | #18 (permalink) |
| Newbie Join Date: Apr 2008 Location: Cochin
| Hi Team-BHP This is my first post in this forum I have a 2004 model Santro Xing. The car has clocked around 35,000 Km. I had used only Xtra premium petrol from the day i purchased the car Around one month back the car engine started knocking. The service engineers couldn't find any issues with the engine, but they accepted that engine is knocking after the car reaches around 60Km/hr. They suggested that the problem could be because of the premium petrol I am using and asked me to change it to normal petrol. I am using normal petrol from then onwards, but the issue is still there. I have heard that usage of normal petrol could lead to knocking in the long run, but this is the first time I am hearing usage of premium petrol could lead to knocking. Can any of you guys advise me on this? Has any one faced similar issues? |
| | #19 (permalink) | |
| Newbie Join Date: Mar 2004 Location: Noida
| Quote:
I had used BP Speed right from the day one and couple of months back the pinging noise under the bonnet started. I could also feel the drop in power. The service station too gave the same explanation that it is caused by premium petrol. But, I reasoned that it should be a problem with other Santro's as well. My friend too have a 2004 model Santro Xing and he never faced this issue although he only fills up with BP Speed from the same gas bunk. Service station guys even cleaned up the petrol tank and filled up petrol from the gas bunk they visited regularly, but still the problem persisted. Resetting the ECM did not help either. I insisted that it appeared to be a problem with the ignition timings and they swap ECM from another Santro to rule out the problem with ECM. On swapping the ECM from the donor car the pinging problem did not reoccurred and pickup appeared normal. However, on plugging back my ECM the problem did not resurface either! The service guy could not explain this behaviour. The pinging problem resurfaced after a couple of weeks. This time I switched to normal petrol and have not experienced pinging problem since then. Couple of my friends had a similar problems with their cars - 1999 carb Maruti 800, 2004 WagonR when they switched to BP Speed. Reverting back to normal petrol solved the problem for them. However, I still do not have an answer why it works fine in my friend's 2004 model Santro Xing? | |
| Thread Tools | |
Similar Threads | ||||
| Knocking Sound in Santro | Vys De BlUR | Technical Stuff | 0 | 5th March 2008 17:38 |
| Sound from Engine Bay of Swift VDI (DDIS) - what would be the cause of this sound? | DieselFan | Technical Stuff | 4 | 25th January 2008 17:31 |
| Sound Advice For Santro | kamikaze_713 | Ask the Gurus | 79 | 29th May 2007 12:39 |
| Knocking sound from the rear of my Santro | psynaps3 | Technical Stuff | 7 | 20th April 2006 02:07 |
| Knocking | SLK | Technical Stuff | 18 | 2nd June 2004 13:29 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
