| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| Newbie Join Date: Sep 2007 Location: Trivandrum
| I own a 2000 model santro. I recently got it tuned by a company mechanic. After that some times in 2nd or 1st gear the car sort of jumps forward and stalls. Then a mettallic knocking sound is heard from under the dash. Please help me sort this out guys. ![]() |
| | #4 (permalink) | |
| Team-BHP Moderator ![]() Join Date: Feb 2004 Location: Bombay / New York
| Quote:
Is it more of an erratic clicking sound ( a faulty relay ) ? cya R
__________________ The memory of you will ride by our side forever. | |
| | #6 (permalink) |
| Team-BHP Moderator ![]() Join Date: May 2004 Location: Bangalore
| Is it engine pinging? Slightly OT: Yday i drove my Managers Getz 1.3 and boy oh boy once heated up with AC on, its a pain to move the car at incline (even in I gear) without pinging. Have observed other Hyundai cars with the same phenomenon.
__________________ The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin |
| | #8 (permalink) |
| Senior - BHPian | There is a aircon pipe which is attached to the body dividing the enginebay and cabin. The pipe is clamped onto the body, if loose will rattle and make you feel as if something is rattling inside the dashboard. Check it out.
__________________ Remember, its a machine |
| | #10 (permalink) | |
| Senior - BHPian | Quote:
At Sanjay Hyundai, apart from routine service (which presumably includes engine tuning) they also changed my tail pipe and did clutch overhaul. So I am not sure what exactly is the cause of the slight stall at lower speeds. E.g. if the speed comes down below 15-20 kmph in second, the car tends to stall a little. At Sanjay Hyundai they said this is normal, but I did not observe this earlier. I am now routinely using Speed 97 and I must say the car has excellent pickup. I am ignoring the slight tendency to stall at lower speeds and I have made the adjustment needed in my driving style. My suggestion is to try one or two tankfulls of Speed 97 and see if the knocking sound disappears (due to the higher octane rating). Poor quality fuel could be one possible reason. | |
| | #11 (permalink) | |
| Senior - BHPian Join Date: Oct 2005 Location: Currently at Chennai. Originally from Blore.
| Quote:
I had a similar issue a year or so back. For more info : http://www.team-bhp.com/forum/techni...ing-noise.html (Pinking noise...) | |
| | #13 (permalink) |
| Thanks dudes for your suppport!! The problem is finally solved!! It was a problem with the DISTRIBUTION SYSTEM. I got it replaced. They also did do somethimg with the relay. But the bottom line is car's fine now, though i'm not!! 9.5k 4 the whole deal!!!! ![]() |
| | #15 (permalink) |
| Newbie Join Date: Mar 2008 Location: Mumbai
| Need your help - My zen for the last 1 year has this peculiar knocking sound ( its like a wooden knocking ) sound that comes from the drivers side fron from below the bonnet . Its a Thud - thud sound and its very very irritating . I have visited 3 different Maruti service centres with this problem NO ONE has found a solution - Now heres what happens This sound is heard ONLY during summers ( afternoons , heavy traffic in evening sessions ) , no sound at all through winters , rainy season only during summers . This happens after i have driven about 8 Kms + and the engine is sufficiently hot , once the engine cools there is no sound and begins once again after reaching a particular temp . I know its something to do with expansion of some part on heating - but neither me ( given my limited technical knowledge on cars ) nor the service guys ( shame - given their experience in this field ) are able to sort out the issue . anyone who has faced a similar issue -pls respond so that i can pin point the problem to service guys and get rid of it.
__________________ It is better to burn out than fade away - Kurt Cobain |
| Thread Tools | |
Similar Threads | ||||
| Knocking Sound in Santro | Vys De BlUR | Technical Stuff | 0 | 5th March 2008 17:38 |
| Sound from Engine Bay of Swift VDI (DDIS) - what would be the cause of this sound? | DieselFan | Technical Stuff | 4 | 25th January 2008 17:31 |
| Sound Advice For Santro | kamikaze_713 | Ask the Gurus | 79 | 29th May 2007 12:39 |
| Knocking sound from the rear of my Santro | psynaps3 | Technical Stuff | 7 | 20th April 2006 02:07 |
| Knocking | SLK | Technical Stuff | 18 | 2nd June 2004 13:29 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
