Thread Tools
Old 15th March 2008, 16:54   #16 (permalink)
gd1418's Avatar
What do you mean by "wiped it clean"? Wiped with a cloth? How did they reach every nook & corner of the bay?
And what is this steam-cleaning? Details...
Originally Posted by Steeroid View Post
Gave it to the service centre to get the engine bay back to what it used to be and they did the following:
1. Sprayed the entire engine bay with WD40 and let it soak for a while.
2. Wiped it clean.
3. Steam-cleaned the entire engine and the stuff around it.
The vehicle came back with a squeaky clean, polished engine bay that wouldnt look out of place on a showroom car.
__________________
Royal Enfield Bullet 1962
All Black 1998 Safari 4x4
All Black 2004 Scorpio GLx
Old 15th March 2008, 18:04   #17 (permalink)
abdriver2000's Avatar
Besides being very expensive, isn't WD40 supposed to loosen bolts? I am afraid this can prove a bit dangerous.
abdriver2000 is offline   Reply With Quote
Old 15th March 2008, 18:19   #18 (permalink)
narayan's Avatar
thats true - imagine, leaving the engine bay sprayed with WD40 and you come back after a few minutes and every nut and bolt just falls down !!
maybe this is some other product of WD40 used for cleaning ?
narayan is offline   Reply With Quote
Old 15th March 2008, 18:38   #19 (permalink)
WD40 is only supposed to loosen rusted bolts and screws for easy removal, they dont fall off
amitwiz1 is offline   Reply With Quote
Old 15th May 2008, 17:27   #20 (permalink)
All those who said No...Hats Off... I was Pressure Washing my Hood for the last 5 years.. until some time last year my buddys NEW WagonR LPG got Dead after a wash a local car wash...Engine Started Misfiring, Backfiring, to an extent that the airfilter assly got blown clean away from the head..!! after weeks of trouble shooting, gave it RNS Bangalore, claimed warranty for both the (Distributors) I think..the 2 black boxes on the head that generate the spark... Whew.. close shave that one.. now the car is much ok...
i understand that the wagon r lpg comes with a closed loop kit including an lpg lamda sensor. if that gets wet, it goes for a toss since it is an electronic device made of various chips. this lamda controls the air fuel mixure. if this is spoilt, the above problems would arise, including misfiring and air filter related problems!
__________________
If you're incompetent you have to be honest, and if you're crooked you have to be clever.
harsha.cs1 is offline   Reply With Quote
Old 16th May 2008, 09:45   #21 (permalink)
vipul_singh's Avatar
It is not only about the impact of water on electrics/electronics.
I assume that most of us would have to drive the car to the car wash people, so the engine would be hot at the time of the wash. So, spraying the engin bay with cold(er) water would lead to stress on the head/block and may cause the head to crack.
So unless you are doing it on a cool engine, getting the engine bay washed can cause big problems.
vipul_singh is offline   Reply With Quote
Old 16th May 2008, 17:42   #22 (permalink)
Here is what I do with my Zen VXi. Every once in a couple of months, I take a water hose, and reduce the water spray to a fine mist. To do this I use a highly perfected technique from my childhood days. I insert my finger in the mouth of the pipe and then allow out just a small opening, so that the water comes out as a mist but under very high pressure. I spray the mist around the engine bay, taking care not to over drench the electricals, but just enough to let the dust trickle down with the water. I also spray a good amount (not mist) over the radiator to clean all the dust between the fins.
I keep the hood up for about an hour or so to let the water dry and then wipe any excess water over the engine cover, battery, and other electricals with a piece of clean cloth. For hard to reach spots, just roll the cloth into a thin pointed roll and insert in hard to reach nooks. The cloth will absorb most of the water, the rest will just evaporate with the heat of the engine.
newcoolgadgets is offline   Reply With Quote
Thread Tools
Noise from Under the hood in the Swift pjbiju Technical Stuff 9 25th June 2007 16:09
Accent Hood autopsyche Modifications & Accessories 32 18th June 2007 12:03
Carbon fiber hood adman77 Modifications & Accessories 28 26th March 2007 04:33
Dusting whats under the hood! SLK Technical Stuff 25 8th September 2004 16:15
under the hood of silver supra qwerty Modifications & Accessories 2 25th June 2004 15:58
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
