Thread Tools
Old 10th March 2008, 15:36   #1 (permalink)
sunster's Avatar
Default New Optra Magnum Diesel driving tips
Hi All,
I recently bought the Optra Magnum Diesel LT. Its done 1200 kms already on the ODO and Im keeping speeds strictly under 60km/h and rpms in the sub 2k range. My qn is that Im gng to Pune and would like to take the car but on the expressway where i would travel 100 km/h plus, would it be ok to speed up the car upto 100Km/H or should I wait until the car does 5000Kms and then increase my driving speed. Please help!!
SUNNY
sunster is offline   Reply With Quote
Old 10th March 2008, 15:50   #2 (permalink)
n_aditya's Avatar
Consult the owners manual on how to "run in" your new car safely.
Check this linky : http://www.team-bhp.com/forum/owning...r-new-car.html (ARTICLE: How to Run-In your new car)
__________________
RIP Tootie !!! Missing you terribly.
Old 10th March 2008, 15:53   #3 (permalink)
akshay1234's Avatar
it should be about run in by now. i suggest stick below 3k rpm and dont go above 120kmph. also dont keep a steady speed for long i.e. if your crusing at 100 then slow down to 80 for a while then you can go back to 100 or 120 for a while.
akshay1234 is online now   Reply With Quote
Old 10th March 2008, 16:03   #4 (permalink)
mobike008's Avatar
As long as you dont cross 3K RPM, you should be just fine. Below 3K RPM's it is possible to do 100kmph or over.
__________________
[b][i]The nail that sticks out gets hammered !!!
Old 10th March 2008, 16:04   #5 (permalink)
Super-Admin
Hi Sunny
Its not the speed (100 kph) but the rpm that you must keep an eye on. For a brand new diesel, I would restrict to 2000 - 2400 rpm over the running in period. In 5th gear, that should give you over a 100 kph in the Optra.
The expressway would not be the ideal place to take a brand new car, as a new engine should have "varying" rpm levels. Chances are that you will spend most of your expressway time at one cruising speed and hence, at a steady RPM level.
To read TSK's excellent article on running-in, click HERE (ARTICLE: How to Run-In your new car).
__________________
Change the way you think, and watch the world change around you.
  • Please don't PM for support. Use the Contact Form instead.
  • Please read the *NEW* Team-BHP FAQ section for all your queries.
Old 10th March 2008, 16:56   #6 (permalink)
sunster's Avatar
Default Thanx for the inputs
I want to thank you for all these valuable inputs. I referred to the manual and it says to take care for the first 1000 kms. Should I go by this?
SUNNY
Old 10th March 2008, 18:12   #7 (permalink)
mobike008's Avatar
SUNNY
Thats what the manual means, taking care means running in your engine properly. So just keep the rev limits below 3k rpm and u are good to roll
__________________
Old 10th March 2008, 18:13   #8 (permalink)
akshay1234's Avatar
SUNNY
its better you wait until at least 2k kms before you floor it fully. though if your manual says you can do what you want after 1000kms then floor it man.
Old 10th March 2008, 18:32   #9 (permalink)
airfoil's Avatar
Since you have already done more than the recommended 1000kms keeping it under 2k, your run- is pretty much complete.
However, before going pedal to the metal, I suggest you take things up a notch at a time, that is, add 500-750 rpm for every 500km done on your way to the redline.
airfoil is online now   Reply With Quote
Old 10th March 2008, 19:11   #10 (permalink)
A car's dynamics are very different at high speed. I mean the way a car will corner and take on a rough patch of road at high speed. So increasing the speed gradually helps you learn about the cars behaviour.
Bomi is offline   Reply With Quote
Thread Tools
Optra - Petrol 1.6 v/s diesel 2.0 EDIT : Now booked Magnum Diesel manaa45 Sedans 33 13th June 2008 17:16
ICE Ugrade for OPTRA Magnum diesel sahadevb Ask the Gurus 3 14th May 2008 13:16
Optra Magnum diesel LT or Laura Elegance ?need help anant.arora Sedans 74 31st October 2007 14:51
Optra Magnum diesel madan80 Sedans 3 28th August 2007 10:24
optra magnum diesel recalled saketnagpal The Indian Car Scene!! 9 22nd August 2007 19:53
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446
