Old 11th March 2008, 07:11   #1
Thanked: 96 Times
Does anyone have a part # for this? I'd like to pick up the Denso part (or close enough) from the US.
Will the O2 sensor for a D15B7 engine work for the OHC?
B
71Convertible is offline   Reply With Quote
Old 11th March 2008, 08:22   #2
ananthkamath's Avatar
Thanked: 63 Times
This should work:
AutoZone.com | Shopping | Parts | Product Detail - Oxygen Sensor
Its from an OBD-I (pre-95) civic 1.5L engine. I'm not a 100% on that though. This is based on a purely anecdotal report of what the sensor looks like from my friend who has a City back in India.
ananthkamath is offline   Reply With Quote
Old 11th March 2008, 09:14   #3
Thanked: 10,821 Times
It should do - same engine D series
Old 11th March 2008, 09:28   #4
Thanked: 96 Times
I think I'm going to buy this -- uses the same socket is 4 wire and was used on the 1.5L engines (actually was used on most engines of the 90s)
Denso 234-4099 - Denso First Time Fit Oxygen Sensors - JEGS
My reference:
Online Catalog at DENSO Aftermarket: Performance Aftermarket Automobile Parts
B
Old 11th March 2008, 09:45   #5
Thanked: 63 Times
Are you sure its a 4-wire? If so I was wrong then. That's a great price. JEGS is fast on shipping too. Go for it!
Old 11th March 2008, 10:15   #6
Thanked: 96 Times
Yep, it's 4 wire (confirmed on another site).
B
Old 11th March 2008, 11:01   #7
Pankaj401's Avatar
Should be 4-wire heated sensor.
Pankaj401 is offline   Reply With Quote
Old 11th March 2008, 11:08   #8
narayan's Avatar
Thanked: 1,324 Times
awesome price !! the honda A.S.S. sells it for around Rs12-15k
i bought one in the grey market for around Rs3.5 k - THIS IS STILL CHEAP for a original part
narayan is offline   Reply With Quote
Old 13th March 2008, 14:46   #9
four_tire's Avatar
Thanked: 21 Times
Default Which one is the right o2 sensor
Of the following o2 sensors... which one is would fit for OHC vtec.. can any one please confirm this..
Part: Oxygen Sensor Universal
Part #: C5010-126014
Brand: Bosch
Part: Oxygen Sensor OE Connector
Part #: C5010-88818
Brand: Bosch
Part: Oxygen Sensor
Part #: C5010-62878
Brand: NTK
Part: Oxygen Sensor OE Type
Part #: C5010-100896
Brand: Denso
four_tire is offline   Reply With Quote
Old 22nd March 2008, 11:49   #10
hi
if your car is non vtec its ok if you have a vtec it will not work you will have to check lamp
Note from Mod : Please take the time to type out your posts in full words as per Team-BHP rules. Avoid the use of SMS language (u = you, ur = your, etc), and please take the time to re-read your post for typos before submitting.
Last edited by Rehaan : 22nd March 2008 at 23:18. Reason: Please see note in post.
armotosport is offline   Reply With Quote
Old 10th October 2008, 10:15   #11
ssjr0498's Avatar
Thanked: 120 Times
Brand: Bosch
Attachment 1098
Part #: C5010-88818
Brand: Bosch
Attachment 1096
Part: Oxygen Sensor
Part #: C5010-62878
Brand: NTK
Attachment 1095
Brand: Denso
Attachment 1097
Hi KSM,
Any idea on how much does the last one ( DENSO C5010-100896) cost?
This is the one that comes stock from the factory.
Shrey
ssjr0498 is offline   Reply With Quote
Old 16th October 2008, 14:43   #12
the VTEC guy's Avatar
Thanked: 138 Times
Brand: Bosch
Part #: C5010-88818
Brand: Bosch
Part: Oxygen Sensor
Part #: C5010-62878
Brand: NTK
Brand: Denso
I have a 2002 VTEC with O2 sensor not working. Can Experts please provide right part details or a link to the product will be great. Have a friend coming back from US next week need to order the sensor soon.
the VTEC guy is offline   Reply With Quote
Old 16th October 2008, 15:56   #13
Thanked: 138 Times
part no. or model no. that I can see on my VTEC is
ns6 Denso 234000-2320 05d29
I tried out looking for this on google, ebay motors, amazon and autozone but couldn't identify a exact match..
Old 17th October 2008, 10:11   #14
Thanked: 138 Times
experts please comment. I am going through multiple older threads on this but could not find any conclusive solution/suggestion. please advice.
Old 7th July 2009, 19:59   #15
Hey Friends,
I need to change my oxygen sensor for my Hyundai Accent 1.5
Currently, it has a malfunctioning 2 wire sensor. Can i fit a universal 4 wire sensor with the 2 heating wires connected to the ignition? because i know that upgrading to a pre-heated 4 wire sensor will improve fuel efficiency and combustion.
I am told from the around the corner section of the forum that it would cost me Rs. 3000 approx (NTK brand).
The technical question is whether are all the oxygen sensors of the same fit and size, such that a universal sensor can do the job? or do i have to go in for something which is specifically made for a Hyundai Accent 1.5? Coz my mech says that the oxygen sensors come in a universal size and i can buy any model which preheats at 12 Volts. The universal bosch sensor in this thread seems to me like a great buy to me, provided the size etc is not an issue.
Can you please confirm this?
Thanks! I plan to get this fixed by Saturday, hence please respond ASAP. You can call me at 9900239781 if you wish!
Cheers!
Harsha
harsha.cs1 is offline   Reply With Quote
Suzuki Baleno (Type-III/Euro-III) Oxygen Sensor Info sarbashishb Technical Stuff 12 17th September 2015 09:26
Oxygen sensor for Indica Xeta Deeps Technical Stuff 1 2nd December 2009 23:08
Cam Sensor-Crank Sensor-TDC Sensor. Are They The Same Thing? genesis Technical Stuff 8 5th October 2009 11:17
WANTED: Oxygen sensor (Lambda probe) for OHC VTEC gbpscars Modifications & Accessories 5 7th July 2009 14:30
Oxygen Sensor - Malfunction Need Help Firestarter Technical Stuff 15 23rd February 2006 07:06
