Old 11th March 2008, 12:37   #1
Default Power Steering fluid and ECU Zen Vxi
Hello BHPins,
Just wantd to know Does Zen Vxi Type II has a power steering oil ?, i read somewhere in the net it has but when i chked with my local Mechanic he clearly said no it doesn't uses any oil for Power Steering,
Also wanted to know where is the ECU fitted in Zen Vxi ? is it somewhere on the engine ? i was planning to get engine cleaned ( washed ), If i gets engine cleaned will my ECU get wet and have a problem ?
Jitendra
nicejits is offline   Reply With Quote
Old 11th March 2008, 13:53   #2
amitpunjani's Avatar
Thanked: 101 Times
Originally Posted by nicejits View Post
Hello BHPins,
Jitendra
HI
To best of my knowledge, Petrol Zen never came with the hydrualic power steering, it always came electronic power steering which requires no oil at all.
The ECU is installed inside the cabin underneath the dashboard of the Co driver side
Amit
amitpunjani is offline   Reply With Quote
Old 11th March 2008, 14:14   #3
rohan_fonseca's Avatar
Yup the old zen has EPS and does not require PS oil. The ECU is under the dash glove box side.
rohan_fonseca is offline   Reply With Quote
Old 11th March 2008, 14:45   #4
Thx for your replies guys, I am getting Engine ( e-bay ) cleaned ( Diesel washed ), shd I cover any part with plastic ? any care to be taken ?
Old 11th March 2008, 15:02   #5
Thanked: 101 Times
Hi
Are new Zens equipped with Hydro PS?
Amit
Old 11th March 2008, 15:17   #6
spadival's Avatar
Thanked: 16 Times
Yes.. Cover the air intake. Not sure if Zen has an airbox. If so then, I think its sufficiently water proof, but no harm in covering it up with plastic. Also, cover the fuse boxes if any.
spadival is offline   Reply With Quote
Power Steering in Swift VXi dead rowhun Technical Stuff 21 9th December 2015 14:04
Driving without power steering fluid sumannandy Technical Stuff 25 20th December 2011 10:37
Maruti Esteem - Non Power Steering to Power Steering udit78 Modifications & Accessories 14 4th May 2011 13:29
Power steering to manual steering? ramzsys Technical Stuff 18 11th August 2010 23:16
Electric Power Steering Vs. Hydraulic Power Steering joseph5600 Technical Stuff 3 19th November 2007 20:56
