Old 14th March 2008, 16:53   #16
Firebird's Avatar
Thanked: 61 Times
I had the FE drop in my Palio 1.6 for sometime before the 15K service.
The problem was one puctured tyre at rear. The FE dropped to as low as 7 kmpl. After fixing the puncture it climbed back to 9 kmpl.
After 15K service, it is in the range of 10.xx
Got the engine oil flushed and changed, injector cleaned, Air/oil/fuel filter changed.
I feel the engine flush and OEM oil (Penzoil), Injector cleaning, and Air filter have contributed in increasing the FE.
The fuel makes a big difference. The regular octane returns more FE than the Speed / power high octane fuel.
So you need to have all things working right and the correct combination will return good FE.
Firebird is offline   Reply With Quote
Skoda Yeti. 4.5 lakh repair bill! EDIT: Fuel system replaced under warranty Catamaran Technical Stuff 163 18th July 2018 12:59
Palio Stile MJD -- Technical Info needed on an Engine Part(Changed under warranty) funkykar Technical Stuff 10 20th September 2010 21:11
Looking for an HU under 12k yayaati In-Car Entertainment 53 6th May 2008 10:46
10400 kms and tyres replacement under warranty codemarauder Tyre & Alloy wheel Section 9 9th April 2008 14:04
