Old 18th December 2013, 23:05   #16
IndigoXLGrandDi's Avatar
Thanked: 160 Times
Default Indigo Dicor Alternator Belt gets corroded on its own.
Originally Posted by wanderernomad
Wont it be better if you changed to a thicker/bigger belt so that the grip is onto the sides and not rub against the pulley's bottom?
Could you suggest the belt similar to 5PK730? 5 denotes Five Grooves and 730 denotes length of Belt.
God the words make the line sound as soft porn
IndigoXLGrandDi is offline   Reply With Quote
Old 29th December 2013, 18:55   #17
Thanked: 160 Times
Default Required Indigo XL Dicor's Alternator Belt Pulley
Today I got removed the Alternator from the vehicle for replacing the Alternator Pulley as the local spare parts dealer told me that the alternator pulley is available with him.
But after taking the alternator to him for sample purpose, he told the pulley is unavailable.
I took snaps of the pulley which are as below--
Indigo : Alternator Belt-dsc_0135-resized.jpg
Indigo : Alternator Belt-dsc_0136-resized.jpg
A red box is used to highlight the polished bottom of the grooves. The bottom of left two grooves are dull finished (I know it is not clearly visible). That means the Right Two Grooves are eating the belt.
Indigo : Alternator Belt-dsc_0137-resized.jpg
Can someone please help me sourcing the Alternator Pulley (please quote the price too)? The Alternator is of Lucas-TVS Make. It is 5PK model.
Old 30th December 2013, 14:10   #18
greenhorn's Avatar
Thanked: 1,318 Times
Default Re: Indigo : Alternator Belt
I've changed the belt at 20kish intervals because i could not put up with the infernal noise.
Not sure about the pulley though
Old 30th December 2013, 16:42   #19
Thanked: 75 Times
I have faced the same problem of premature belt failure & till date no one has been able to find a solution. I have a Palio 1.9 & till about 2 years back the belt used to last for around 15000 kms which also is way too lesson. The A/C compressor of the car failed and I got an aftermarket compressor installed & my problem started, the belt would not even last 1500 kms and break every month. I got everything changed right from the crank pulley to the PS pulley & even the alternator pulley but to no avail. In this case the replacement OEM belt is not cheap & everytime the belt fails two bearings namely belt strecher & tightener have to be changed & the whole exercise costs around 6000.
trinity0114 is offline   Reply With Quote
Old 4th January 2014, 15:49   #20
Thanked: 160 Times
I have placed order at Local Lucas Spare Parts Shop at Solapur for the Alternator Pulley of our Indigo XL Dicor. The Lucas Part No. is 26217342. The Price is around 855/- (as per the Lucas Shop at Karve Road, Pune). Lets see what happens after replacing pulley with new one.
EDIT: -
The Top of Grooves of old pulley are not straight (uniform- smooth). I guess it is due to this that the belt gets worn.
IndigoXLGrandDi is offline   (1) Thanks Reply With Quote
alternator belt damages timing belt??? jalsa777 Technical Stuff 21 8th March 2015 10:52
Help Faulty Indigo Alternator saki76 Technical Stuff 4 12th May 2010 23:22
Indigo LX or Indigo Marina LX windsurfer Sedans 10 23rd January 2007 14:03
Indigo Marina conv to Indigo Advent vivek.singh.73 Modifications & Accessories 1 27th August 2005 09:26
