Old 15th March 2008, 19:27   #1
vibhu_f430's Avatar
Thanked: 67 Times
Lightbulb Is car performance without safety systems better - due to less load on ECU?
hi ,
Let me take the Getz as an example ,
In the Abs version of the car , the ecu keeps monitoring the different components that form the ABS for wheel lock-up right ?
And this keeps happening every few Milli seconds,
So,in the non ABS version, Is the ABS part of the ecu is disabled ?
If yes then the processor is not burdened by the safety system and so,the extra processing power can be used to make faster calculations ,like air-fuel ratio and the other stuff it normally does..
This also holds true for all other systems like the air bags , stability program etc..
Is there any performance benefit if the ecu is free-er ??
There should be some kind of benefit right ?
vibhu_f430 is offline   Reply With Quote
Old 16th March 2008, 18:03   #2
amitpunjani's Avatar
Thanked: 101 Times
HI
IMO, it all depends what is the capacity of the ECU. Over the period of time like the RAM of computers has increased like wise the capacity of ECU has also increased from 8 bit to 16 or 32 bits.
Quite an interesting topic.
Amit
amitpunjani is online now   Reply With Quote
Old 16th March 2008, 19:47   #3
Akshay1234's Avatar
Thanked: 7,239 Times
the abs has a separate control unit. at least thats what i think.
Old 16th March 2008, 20:34   #4
ananthkamath's Avatar
Thanked: 63 Times
i agree with akshay. ABS/traction control processor is completely different. Although it may communicate with the ECU if reduction of engine power is required.
ananthkamath is offline   Reply With Quote
Old 16th March 2008, 22:08   #5
ab1xlr8's Avatar
there will be no performance benefit in a car without abs+airbags than a car with it.
ab1xlr8 is offline   Reply With Quote
Old 16th March 2008, 22:17   #6
JayD's Avatar
Thanked: 2,008 Times
As said earlier, i think the ABS is a seperate module which communicates with the ecu as necessary. I don't think there will be any performance gain if the ECU has less tasks. If ever a car with more features needs more computing power, i think the manufacturers would equip a more capable ecu in that model.
Old 16th March 2008, 22:33   #7
binz's Avatar
Thanked: 412 Times
Of course there will!But nobody really cares about weight reduction nowadays
Old 17th March 2008, 00:04   #8
Rehaan's Avatar
Thanked: 25,038 Times
[to add]...purely due to load on the ECU.
Here is a similar thread that makes for interesting reading >
http://www.team-bhp.com/forum/techni...-ecm-make.html (What diference does the no of bits in an ECM make ?)
cya
R
Registration of a new car without any broker(without paying bribe) in Noida hdi_pro Indian Car Loans & Insurance 59 17th February 2018 21:40
Kumaon: roads less traveled and forests less visited nilanjanray Route / Travel Queries 21 11th January 2013 12:25
GM India - Hope less? or Aim less? or both? rnidumolu The Indian Car Scene 16 17th September 2012 15:12
Figo -How can I Reduce load on the engine due to AC? saurabhnanda Technical Stuff 33 17th August 2010 17:10
Superbike Security Systems - Disc Lock / Chain Lock / Alarm Systems gsferrari Superbikes & Imports 3 3rd July 2009 01:45
