Old 15th March 2008, 20:21   #1
Awaiting Email Confirmation
Default Help needed !! Is Lpg conversion of AVEO suggested ?
Hey guys,
I just want to know, is LPG kit recommended to Chevy Aveo ? I heard from a guy that, LPG kits does not suit Chevy engines ! He also said that, It would HAMMER the Engine Performance . I want to know if this is TRUE ? Are they any Aveo owners who had Lpg kits installed ?
Well.... how about converting it into Cng ? Please guys, do suggest me some solid solution.
Moderators: please do transfer my thread to appropriate section.
udaykars is offline   Reply With Quote
Old 16th March 2008, 12:48   #2
wolfinstein's Avatar
Aveo, Optra are running on CNG kits approved by GM, Infact Kingfisher Cars here in Delhi run on CNG- The authorised OEM is Shrimanker Bedinin- Closed Loop System with a GM specific Controller- So CNG is approved and documented performance approved by the company.
With LPG, you will have next to petrol performance, but the running costs are high specially when the FE output on LPG is lower compared to petrol FE and then add to it the High Fuel Costs of LPG.
wolfinstein is offline   Reply With Quote
Old 16th March 2008, 12:59   #3
snaronikar's Avatar
Thanked: 23 Times
Please check whether ARAI has approved LPG kits for Aveo before installing. The running costs are high when comapred to Petrol. You should also be prepared to visit the installer often till the tuning of kit is proper.
snaronikar is offline   Reply With Quote
Old 16th March 2008, 13:04   #4
phamilyman's Avatar
Thanked: 3,526 Times
Hyd had CNG only through bhagyashree gas (or something). Is it widespread now? That being said, CNG is THE way to go - reliance gas should flush AP within a few more months now
Old 16th March 2008, 17:31   #5
Hey thanks Guys,
This was the Break through i was waiting for ! well as LPG prices are touching the skies, it leaves me no option than CNG. But heard CNG kit is heavier and larger than LPG kit. is that true ? any one has any idea, like how much boot space does it take ? may be i also have to compromise even more on Performance !
Can someone throw little more light on this ?
Old 16th March 2008, 23:39   #6
phamilyman's Avatar
Please check the multiple CNG threads floating around.
Know about LPG Conversion.... sonycs Technical Stuff 173 17th April 2014 09:13
Aveo CNG/LPG Conversion Kush Agarwal Technical Stuff 20 20th May 2011 20:28
LPG conversion for a FORD 1.6 wannaplay Technical Stuff 4 2nd June 2006 04:34
Esteem 95 LPG conversion-Bangalore sriramraj Modifications & Accessories 3 23rd May 2006 07:09
