Old 16th March 2008, 12:15   #1
Dragonov's Avatar
Thanked: 30 Times
Unhappy Gear engagement problem.
Recently I have noticed that in the mornings when I start my Safari Dicor 3.0L and try to engage the second gear after the first, there is quite a hardness in the gear engagement (i.e I need to exert more force manually) and then the same thing happens when I downshift from the 3rd to the 2nd gear. The issue is that this happens only when I initially start off in the mornings or even in the evenings.
The point at issue is that after driving the vehicle for sometime the gears engage properly. Please help as I am not able to understand what the problem could be because earlier this issue was not there, further to this my safari has done about 41K and had its clutch plates changed at 35K.
Dragonov is offline   Reply With Quote
Old 16th March 2008, 12:21   #2
Shan2nu's Avatar
Thanked: 89 Times
Get the transmission oil level/circulation checked.
Shan2nu
Old 16th March 2008, 12:45   #3
Dragonov's Avatar
Thanked: 30 Times
Thanks Shan2nu, have given it to the workshop people and asked them to check the transmission oil circulation checked. Lets see what they say...
Old 16th March 2008, 14:52   #4
Thanked: 655 Times
Its there in every Safari I have driven. Its only in the morning, 1st few shifts right?
jyobeb is offline   Reply With Quote
Riding the Way of Life - Suzuki GS150R A proposal, The Engagement and the Marriage AlphaKilo Motorbikes 51 6th March 2016 08:04
From Bangalore to Shillong with an engagement ring JoeMichael Travelogues 21 13th June 2011 09:59
Swift 2nd Gear Problem EDIT: Now first gear problem BUSA Technical Stuff 85 2nd September 2009 18:47
Top Gear in 'Top Gear' (3 veyrons offered for shoot) SumitB Shifting gears 8 4th August 2008 13:22
