Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al).
Thread Tools
Old 16th March 2008, 20:56   #1 (permalink)
sreenivass's Avatar
Default Is this ECU learning affecting my FE ?
Gurus,
I have been driving a Petra for 3+ Yrs and have an interesting observation. For a good part of the 3 years I used to do early shift in city driving like shifting to 3rd at 28 KMPH, 4th around 40 KMPH 5th around 50 KMPH. Most of the time I used to get around 9.5+ to 11.5+ KMPL (more of it around 10 to 10.5 KMPL) in this driving style. Over the last couple of months I started shifting a bit late like: 35 KMPH to 3rd, 45-50 KMPH to 4th and around 60 KMPH to 5th. With this new style what I have observed is until half tank empty I am covering over 250 KMs which is like 11 KMPL. As I continue without refilling I see the final KMPL coming to around 9.5+, I am tightening vigil because of suspected pilferage. Do you think there can be a technical reason for this ?
sreenivass is offline   Reply With Quote
Old 16th March 2008, 21:26   #2 (permalink)
Eddy's Avatar
I think that the top half of the fuel meter is calibrated differently from the second half. In other words, from "F" to halfway the needle moves slowly compared from halfway to "E".
__________________
Car is no longer a luxury; parking space is.
Swift VDI(ABS) Sep 07 - 53K Kms
Ford Ikon Flair Sep 04 - 70K Kms
Eddy is offline   Reply With Quote
Old 17th March 2008, 00:03   #3 (permalink)
Unlike the speedo- and odo- meters, the fuel indicator is just that - an indicator. It is NOT a meter. Never count mileage by position of the needle. If you want to check FE, use the topup-to-topup fuel consumption divided by distance as per the trip meter.
__________________
ɹǝʌıɹpʇɐǝsʞɔɐq
Old 17th March 2008, 00:46   #4 (permalink)
Sagittarian's Avatar
Eddy is correct. In Aveo also, I have noticed that the movement of the needle is not in linear correspondence with the petrol level. Beyond H(alf), it moves down slowly, then after some descend, it starts sinking real fast.
__________________
There is more to life than increasing its speed - M. K. Gandhi
Sagittarian is offline   Reply With Quote
Old 17th March 2008, 01:14   #5 (permalink)
Rehaan's Avatar
Eddy and Backseatdriver have got it right on this one i think.
Originally Posted by BaCkSeAtDrIVeR View Post
If you want to check FE, use the topup-to-topup fuel consumption ....
http://www.team-bhp.com/forum/indian...-your-car.html (How do you calculate mileage for your car)
cya
R
__________________
The memory of you will ride by our side forever.
Old 18th March 2008, 05:42   #6 (permalink)
sreenivass's Avatar
I agree with Fuel indicator part, why was it different earlier. I used to cover only around 200-220 KM earlier for half way mark in indicator.
Old 18th March 2008, 09:32   #7 (permalink)
S@~+#0$#'s Avatar
Since you are aware of the above suggestions, I recommend you reset the ECM. Follow the steps below:
1) Go to an empty stretch
2) Disconnect the -ve terminal of your battery.
3) Wait for 5 minutes and connect the terminal again.
4) Then drive the car in your new style of driving ie., late shifts.
The ECM learns and gets adapted to your new style of driving and then stores the best values for this kind of driving. Try it, I am confident it will work.
__________________
Santhosh
S@~+#0$# is offline   Reply With Quote
Old 18th March 2008, 09:36   #8 (permalink)
gemithomas's Avatar
Originally Posted by sreenivass View Post
Gurus,
Its simple. You are running at higher rpm's. Thus the mileage figures are getting a hit while you are being given enough and more power. Earlier you used to shift before the 2K rpm mark and now you are shifting way above that mark. Thats the difference between 10.5 km/l and 9.5km/l i guess.
The fuel gauge needle is just an indicator. But not sure wh it behaves differently now.
__________________
"Our world is in its current state because of the choices WE made ...or failed to make"
Old 18th March 2008, 11:59   #9 (permalink)
Su-47's Avatar
Are we serious about the ECM "learning" something from the driver's driving style? I had no clue that something like this is happening under the hood, until I read it here.
So, if I and a friend have the same car and his *normal* driving is more aggressive than me and we decide to race one day, would the ECMs of our cars respond differently. Would my car's ECM respond with "You've usually been a good boy, what has happened to you? Let me respond with my usual laziness, so that you don't win this race and stay away from such misadventures."
__________________
I thought this is a free world! Outta here...
Su-47 is offline   Reply With Quote
Old 18th March 2008, 12:28   #10 (permalink)
Zappo's Avatar
haa haaa haaaa... Su, that was hilariously put through.
Well, coming back to reality there are indeed such technologies available where the car's ECU module is a self-learning one. Honda and other car majors do have such technologies available. I do not know if the Indian cars though have such a feature. At least not the mass cars I suppose. I am not sure of this but I think the Laura has something like.
Coming to what you said, the car won't punish you for driving aggressively but it will return poor fuel efficiency than what your friend's car will for the same kind of driving.
__________________
Announcements are important.
  • Read the Advertising Announcement here.
  • Classifieds section has its rules. Read here
Zappo is offline   Reply With Quote
Old 19th March 2008, 02:02   #11 (permalink)
chetanhanda's Avatar
Gurus,
There is a technical reason - you are driving it more aggresively as compared to earlier.
Even if you had a carburettor instead of an ECU you will notice the same thing.
You are revving the car higher and shifting late so you will consume more fuel.
What's the mystery dude ? ECU is just doing its job - you asked for more fuel by revving higher, the ECU didnt do that on its own.
You basically answered you own question when you said you are shifting late.
All ECU's have that, every ECU keeps updating values based on the engine's health and how you drive it.
chetanhanda is offline   Reply With Quote
Old 19th March 2008, 02:10   #12 (permalink)
v1p3r's Avatar
Yes, that's exactly what will happen. Been there, done that.
__________________
"We Could Fly So High
Let Our Spirits Never Die..."
- Michael Joseph Jackson
Rest in peace.
Old 19th March 2008, 08:58   #13 (permalink)
moralfibre's Avatar
And v1p3r is right here. There is something called "Self adapting parameters" on your ECU that collects data depending on your driving style. That is the reason why you have "Zeroing of self adapting parameters" option on the examiner (at least in Fiat there is). Once reset you are supposed to start the car and leave it on idle for a while to collect data after which you drive around for a while and the ECU collects information based on your driving style. I don't have technical details on this one.
__________________
/F/I/A/T/
Old 23rd March 2008, 00:03   #14 (permalink)
sreenivass's Avatar
Default mystery is the fuel indicator
Well the question is more on why the indicator behaves this way. Higher revs and lesser FE is obvious, but the average FE is not a whole lot different. Why does it show as if there is higher FE for the first half tank, can it change with weather ?
Old 27th March 2008, 21:52   #15 (permalink)
The title of the thread says "Is this ECU learning my FE ?" ..thats why.
Anyways..theres something wrong with the fuel indicator.
Same with my car, it comes down quickly to the 1/2 way mark and goes down to empty pretty slowly in summer/winter ,maybe its not calibrated very accurately.
Thread Tools
Learning to drive infinitesadness Introduce yourself 15 23rd September 2009 20:43
Two scary incidents on GQ and a possible learning for all thiyags22 Street and Travel Experiences 15 7th September 2009 18:19
swift audio setup without affecting boot space ronk Ask the Gurus 22 15th October 2007 11:47
Manish here on learning license ;) manish7 Introduce yourself 5 24th April 2006 20:11
Factors affecting Thermal eff vs FE and diesel vs petrol etc jat Technical Stuff 3 21st February 2006 23:09
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
