Old 13th April 2008, 14:33   #16
The dead give away is constant vibration from the engine(rythmic if you will). The way youd distingush this from a bad plug(misfiring) is that misfiring essentially causes an Imbalance in the engine and the exhaust and engine noise are not constant. Its as if there are "hiccups".
sudarshansarma is offline   Reply With Quote
Old 13th April 2008, 16:05   #17
V-16's Avatar
Thanked: 862 Times
Took the 124 out after a very long time. As soon as I cranked her, she came to life with a shudder, which I felt through my feet and the steering on my hands. This mounts gone for sure. Am replacing all three mounts tomorrow. My cars done a very sparingly used 72K from the time I bought her new in 1996. Time to repay her loyalty with some new mounts at least.
V-16 is offline   Reply With Quote
Old 13th April 2008, 18:39   #18
gd1418's Avatar
Thanked: 656 Times
By the third mount you mean the rear engine/gearbox mount? Most, don't change this and then complain of a strange hum in the gear lever area..
Originally Posted by V-16 View Post
TThis mounts gone for sure. Am replacing all three mounts tomorrow. My cars done a very sparingly used 72K from the time I bought her new in 1996. Time to repay her loyalty with some new mounts at least.
Old 14th April 2008, 12:08   #19
gendarmee's Avatar
Thanked: 22 Times
Also, The engine will will seem to be off its position, drooping on one side.
this happens when mount gets worn out quicker than the other.
Eg)On my 118ne the left mount needs to replaced more often than the right side mount.Similar thing with the FIAT 1100.
gendarmee is offline   Reply With Quote
Old 18th April 2008, 07:53   #20
navin_bhp's Avatar
Thanked: 28 Times
Originally Posted by arpandiv View Post
what about judder when you switch on the AC. ?
I too have the same question...any ideas on this?
navin_bhp is offline   Reply With Quote
Old 20th April 2008, 02:55   #21
V-16's Avatar
Thanked: 862 Times
You youre right. When changing mounts after such a long time, best is to change all of them.
Old 11th May 2012, 15:33   #22
Thanked: 69 Times
Default re: Detecting worn engine mounts
Adding to an old thread.
I drive a 2009 model verna CRDi. From the last few weeks, I started feeling a vibration in the engine and took it to ***. They have suggested an engine mount replacement as they found it to be faulty.
Is it better to change all the 3 engine mounts? As of now they have suggested to change the one on left side near the water tank for windshield spray
Do they lift the engine and disconnect everything when they replace the engine mount? I am worried if this will cause more problems
ArunV is offline   Reply With Quote
Old 11th May 2012, 15:50   #23
infotech58's Avatar
Thanked: 217 Times
they would not have to disconnect/lift the engine. what is the mileage on the Verna? it seems too early for engine mounts to be worn for a 2009 make car - only exception i know of is early Civic which were known to have problems with engine mounts post 50k mileage.
infotech58 is offline   Reply With Quote
Old 11th May 2012, 15:58   #24
Thanked: 69 Times
It has covered only 32k till now.
The car was rarely used for almost 1.5 years. Covered only 3K kms in this time. Can this be a reason? Most of the time it was parked and started once in a while or driven once in 2 weeks or so.
Edit: I was at the *** and i could see that the vibration reduces when they put a small iron rod near the mount and tighten it. Otherwise it vibrates much more while starting and stopping.
Old 11th May 2012, 17:20   #25
Thanked: 23 Times
My Alto (2008 December) has done close to 32000 kms. I experience the following.
1. A deep throated hum when I try to accelerate at any gear. The hum dies down as the speed increases
2. The first time I start the car after a, say, 6-hour break, there is a sudden jerk and the car lurches forward when I slot it into 2nd gear from 1st.
Does this warrant an inspection of the engine mounts? And any idea on how much it might cost to replace them at an authorized Maruti Service Station?
travelwriter is offline   Reply With Quote
Old 11th May 2012, 17:34   #26
Thanked: 69 Times
Even i used to feel a slight vibration when i accelarate. During last service they have applied grease in the differential spline(I am not sure if this is the correct word. What i meant is the connection from differential to the wheel hub) and it has gone.
Old 13th August 2013, 20:35   #27
DudeWithaFiat's Avatar
Thanked: 379 Times
Default Re: Detecting worn engine mounts
Bumping up an old thread .
V-16, how much did the engine mounts cost? And how long did it take for replacing the old mounts with the new ones? My W124 has done 1,25,xxx and in a few thousand km more, it will need new mounts. Do the E220 and E250 have different mounts?
DudeWithaFiat is offline   Reply With Quote
Old 13th August 2013, 20:58   #28
Thanked: 660 Times
Hope this helps
http://www.ebay.co.uk/itm/MERCEDES-W...-/330762974843
SirAlec is offline   (1) Thanks Reply With Quote
Old 13th August 2013, 21:16   #29
Thanked: 379 Times
Originally Posted by SirAlec View Post
Thanks SirAlec That would be close to Rs.6000 here, but it doesn't say its for the W124s. I found these at Eurocarparts:
Lemforder Engine Mount (Left & Right) Part No.: 337220675
Lemforder Engine Mount (Left & Right) List Price 78.50
Our Price 53.40
Q-Drive Engine Mount (Left & Right, Right) Part No.: 337220140
Q-Drive Engine Mount (Left & Right, Right) List Price 59.30
Our Price 28.74
Q-Drive Engine Mount (Left & Right, Left) Part No.: 337220670
Q-Drive Engine Mount (Left & Right, Left) List Price 78.50
Our Price 29.94
Lemforder,Qdrive.. Out of these, which is the one that is used originally in a W124.
Old 7th January 2014, 18:23   #30
Thanked: 606 Times
I have Xylo mEagle, 3.5 yrs with ~90000 KMs, all services & repairs done only at MMASS.
Though I didnt notice any major problem in this respect, but I have planned to change the engine and gear mountings, which Im sure would reduce the overall vibrations. but at my last visit the necessary parts was unavailable at workshop. the total estimated cost would be below 4000.
today I came across this thread, and then randomly googled about engine mountings. Found this company http://www.parulrubber.com/product-xylo-74.htm offering various parts of different vendors. (Im no way associated with them!). Im sure there are many other local companies.
regards,
pcpranav is offline   Reply With Quote
Hydraulic Engine Mounts vs Rubber Engine Mounts amalji Technical Stuff 16 29th October 2015 14:57
OS (MS XP Pro) not detecting 4gb ram!!! Shan2nu Gadgets, Computers & Software 16 12th February 2010 17:18
Nissan working on pedestrian-detecting cars ac 427 The International Automotive Scene 2 19th April 2007 14:39
Chassis mods for engine mounts. passionpurple Technical Stuff 2 20th April 2006 21:05
