Old 7th January 2014, 18:43   #31
DeepakMenon's Avatar
Thanked: 145 Times
Default Re: Detecting worn engine mounts
Originally Posted by DudeWithaFiat View Post
Thanks SirAlec That would be close to Rs.6000 here, but it doesn't say its for the W124s. I found these at Eurocarparts:
Lemforder Engine Mount (Left & Right) Part No.: 337220675
Lemforder Engine Mount (Left & Right) List Price 78.50
Our Price 53.40
Q-Drive Engine Mount (Left & Right, Right) Part No.: 337220140
Q-Drive Engine Mount (Left & Right, Right) List Price 59.30
Our Price 28.74
Q-Drive Engine Mount (Left & Right, Left) Part No.: 337220670
Q-Drive Engine Mount (Left & Right, Left) List Price 78.50
Our Price 29.94
Lemforder,Qdrive.. Out of these, which is the one that is used originally in a W124.
On W124 Engine mounts, prefer OEM Lemforder is good, however the OEM is better manufactured
But before you jump into buying, have you measured your engine mounts to see if they need replacement? unless they have already leaked out
E220 OEM Part number :A1242401717
The above is for cars with Air Conditioner
Cheapest on internet link below
http://www.ebay.com/itm/1242401717-M...-/110565665698
DeepakMenon is offline   Reply With Quote
Old 28th January 2014, 22:47   #32
phamilyman's Avatar
Thanked: 3,526 Times
I am planning to change the mounts for my swift VDI (2008) as well. The vibes are perceptible primarily on the steering wheel (only at idle). They aren't unmanageable, but they have come in the last 10k (car is now at 110k) km, and I'm thinking of changing it. Are there any other causes I should rule out before I ask MASS to make the change?
Old 28th January 2014, 23:41   #33
Thanked: 14,610 Times
Is this the first time the mounts are being changed since purchase?
How does the car feel on cranking, shut down and while steady pace cruising?
Anurag.
a4anurag is online now   (1) Thanks Reply With Quote
Old 29th January 2014, 00:05   #34
phamilyman's Avatar
Anurag.
First time indeed.
On cranking there is a definite vibration which is felt, much lesser on shutdown, and no vibration at all while on the move.
The vibes are only at idle.
Old 29th January 2014, 00:09   #35
First time indeed.
I guess they are on their end.
Anurag.
Old 29th January 2014, 08:30   #36
VeyronSuperSprt's Avatar
Thanked: 1,664 Times
You could also check the alternator / A/c belts. If they are loose or towards the end of their life / worn out, there would be similar vibrations.
VeyronSuperSprt is offline   (1) Thanks Reply With Quote
Old 29th January 2014, 11:07   #37
phamilyman's Avatar
Anurag.
So I rechecked and here's my observation -
Steering wheel - Clutch - Gearshift
Startup Slight Significant X
Idle Slight(like a low intensity hum) X X
Shutdown Slight Significant X
At shutdown, the vibes are felt in the seat/cabin as well.
Does that help diagnose better?
Old 29th January 2014, 18:03   #38
Yes your diagnosis does the engine mounts are off. Generally the vibrations are not to be reaching the cabin floor and seats so I feel the mounts don't have much left in them, please them when you can else the internals also will start vibrating (Anyway Maruti's are famous for rattles).
Anurag.
Old 29th January 2014, 18:48   #39
humyum's Avatar
Thanked: 2,503 Times
Hey, when was your last oil change ?
Secondly, get the steering wheel opened and get the clips and nuts adjusted.
Thirdly, the steering column has a fixing plate which attaches the steering rod to the body by a -U- type plate, get that tightened.
I am 100% sure you don't need mountings changed. Trust me.
humyum is online now   (1) Thanks Reply With Quote
Old 29th January 2014, 18:56   #40
Since he has vibration in the seat and cabin the steering can't induce so much and IMO it is the engine mounts.
Anurag.
a4anurag is online now   Reply With Quote
Old 29th January 2014, 19:01   #41
humyum's Avatar
Anurag.
That is only at shutdown, that's okay. I have a 90 thousand Km run Swift Diesel too and trust me, this is normal.
At idle the low intensity hum kind of vibration he is mentioning is creeping in through the clutch pedal. This is normal too.
The vibration at startup is due to engine being cold.
I 100% believe, all this is normal.
humyum is online now   Reply With Quote
Old 29th January 2014, 22:54   #42
phamilyman's Avatar
Anurag.
I think as much. By the way the trusted ex-GM of Apra, a large GGN dealer (200+ vehicles/day on weekends), told me as much. Let's see when i get the time to do it.
Humyum, your diagnosis doesnt agree with my experience. this low intensity hum is there in the steering even at idle after 500km in a single day (recent ooty drive).
The oil was changed about 500km or three weeks or so back.
Old 29th January 2014, 22:59   #43
Humyum, your diagnosis doesn't agree with my experience. this low intensity hum is there in the steering even at idle after 500km in a single day (recent ooty drive).
I am saying this because of my experience with my friends Ritz VDi ABS that has clocked 66K in 4 years also had the vibration issue at idle and it was felt on the seats more. The ASC guys said it is normal so I gave them my Ritz to cross-check which was at 1.05 lac kms without any vibrations so they agreed for the engine mounts changed. Now the car feels vibe-free.
Anurag.
Old 30th January 2014, 04:12   #44
phamilyman's Avatar
Anurag.
Thanks - how long did the engine mount replacement for his ritz VDi take?
Old 30th January 2014, 17:25   #45
He had given the car for regular service so the engine mounts were also replaced at the same time. The job was not specific for engine mounts replacement.
Anurag.
Hydraulic Engine Mounts vs Rubber Engine Mounts amalji Technical Stuff 16 29th October 2015 14:57
OS (MS XP Pro) not detecting 4gb ram!!! Shan2nu Gadgets, Computers & Software 16 12th February 2010 17:18
Nissan working on pedestrian-detecting cars ac 427 The International Automotive Scene 2 19th April 2007 14:39
Chassis mods for engine mounts. passionpurple Technical Stuff 2 20th April 2006 21:05
