Old 24th March 2008, 13:37   #1
Thanked: 64 Times
Default Loose window glass
I have a WagonR duo .yesterday after washing the car , i noticed that the right side of the rear seat was wet, on examining i found that the window glass on that side was slightly down(very minute gap).
i rolled down the glass and found the glass to be very loose. checked the left side . same story.
This is a new car and has clocked just below 2000 kms.
the rear seats were never occupied save for 2-3 occasions and that time the windows were rolled up.
I would like to know how this glass can get loose? is it normal? can i fix it? is it dangerous driving with loose glass?
rajesh1868 is offline   Reply With Quote
Old 24th March 2008, 14:01   #2
amitwiz1's Avatar
Maybe this is normal for the WagonR. The rear windows in my Accent and Optra move a bit when pushed/pulled. What do you mean by loose ?
amitwiz1 is offline   Reply With Quote
Old 24th March 2008, 14:22   #3
rjstyles69's Avatar
Thanked: 795 Times
There's no reason to be so worried my friend, if you really think this a problem and is unusual please head over the service center and bring it to their notice.
Am sure they should be able to fix it without any hassles.
Old 24th March 2008, 14:41   #4
shrivz's Avatar
Thanked: 92 Times
Do you have a power window? If yes, is it original equipment, or aftermarket?
shrivz is offline   Reply With Quote
Old 24th March 2008, 18:20   #5
Thanked: 64 Times
no. its not a power window
it moves to the sides when pushed with slight force.
its not the same with my front windows.
Old 24th March 2008, 18:26   #6
rohan_fonseca's Avatar
The assembly holding the window is prone to rusting. Dunno exactly what its called. Get it checked. Will not cost too much to replace.
rohan_fonseca is offline   Reply With Quote
Old 24th March 2008, 21:03   #7
shrivz's Avatar
Thanked: 92 Times
Get it replaced under warranty! You should not pay a penny for this!
Old 25th March 2008, 11:06   #8
Thanked: 64 Times
Thanks !
will take to service center this weekend.
Old 25th March 2008, 11:57   #9
shrivz's Avatar
Thanked: 92 Times
one more thing, insist that they replace the whole assembly. Don't accept any repair work, unless its just some loose bolts.
Automotive window glass codes Sheel Technical Stuff 4 3rd January 2017 14:16
XYG Glass or Saint Gobain glass HappyRoadie Technical Stuff 10 2nd June 2011 19:50
Broken front left door window glass bkm Technical Stuff 2 23rd November 2008 22:00
Extra window glass mandeep Modifications & Accessories 0 8th September 2007 00:33
Window glass burst - Can this happen ? prince_alex Technical Stuff 15 26th July 2006 17:44
