Thread Tools
Old 27th March 2008, 11:47   #31 (permalink)
Naah! I have known the tulsient name for many years now since they are into NAS/ storage solution.
DM is another branch of their business. Check here
But you can write to them and ask for payment on delivery method, it might be available.
Originally Posted by Steeroid View Post
And I suppose you have to pay in advance before they courier the 'Magic Pill' to you.
Dadu, no offense meant, but this does sound like a Nigerian 419 Scheme.
__________________
Remember, its a machine
Old 28th March 2008, 19:23   #32 (permalink)
The blister pack was delivered to me within 2 days of order & payment, so the Nigerian angle is ruled out.
In the meantime I researched/digged deep into this pill to find out whats the background. So here's my findings.
This pill is sold across the world and moreso in the EU and AP region. I also found that they call it as a Fuel conditioner than an additive.
Manufactured and packaged in New Zealand by Bioactive Technologies ltd. for New Image International Ltd and Ubiee Corporation and sold through its distributors in each region.
You can find this pill by many names in the regions like dyno-tab , Firepower , MP6ty , powerpill etc etc. But they are all the same with similar marketing, graphs and statistics. For EU/AP distributor is RingSMS - UBiee powerpills.
Now I can understand why they sell in different packaging and brands in various regions, although selling under a single brand name would have given them more leverage but I guess thats what DM is all about. And yes, it doesnt have a brandname as STP and Elf.
Now more on the technical part, Power Pills contains:
  • Ferrocene to raise the power output from a given volume of fuel, provide additional lubricating properties and thus reduce the overall emissions.
  • A detergent to clean the fuel system, break down and remove carbon deposits and thus restore the overall efficiency of the engine and fuel system to that of a new vehicle.
  • A binding agent to enable the production of Power Pill in a safe, stable and easily handled product.
Read the technical specifications here.
Chemically talking in its native state, Ferrocene has many applications(the ones from our point of view):
  • Used as fuel catalyst for rocket (aeroplane) propellant, it can improve combustion speed by 1-4 times, lower the temperature of exhaust pipes, and avoid infrared chase.
  • It can be used as petrol antiknock (in place of tetrasthyl lead) to produce unleaded petrol.
  • Used in fuel oils such as diesel oil, heavy oil, light oil etc, It can eliminate smoke, save energy and reduce air pollution.
  • Adding 0.1% Ferrocene to diesel oil can cut down the consumption of oil by 10--14%, eliminate smoke by 30--70%, and improve power by more than 10%. And no deposit is left at the spray.
So it plays a dominant role in the development of fuel oils and improvement of their moderate conditions. The above are published by a chemical manufacturer in USA.
Also read some more FAQ's on this, if you are in doubt.
I think it will benefit those smoking diesels more than anyone else due to the chemicals inherent properties and in combination with the other agents of the pill.
Although its existence is not without controversies with some people claiming that it doesnt work, marginal increase etc etc but just like any of such product you cannot hit a 100%.
Just like some premium fuels brand that work in some engines but not with others.
Old 28th March 2008, 22:14   #33 (permalink)
tsk1979's Avatar
So its something you add to diesel to make it better.
Does not really make it different from things like STP/SystemD/HP Power/BP High speed diesel etc., right?
__________________
Reclaiming.....!
Old 29th March 2008, 13:23   #34 (permalink)
It does see here
Primarily, you will not find Cetane/ Octane boosters and anti-knock agents in most of these detergent based cleansers.
__________________
Old 22nd April 2008, 13:11   #35 (permalink)
condor's Avatar
@dadu, how is the pill ?
And for the petrol burners, check this out: 5ml per 10 litres. 20ml pack.
__________________
Life is Analog. Digital is an approximation.
Old 22nd April 2008, 15:50   #36 (permalink)
Waiting for the needle to touch half-mark, atleast then we can some reasonable level of stats based on that.
__________________
Old 22nd April 2008, 15:54   #37 (permalink)
condor's Avatar
dadu : Waiting for the needle to touch half-mark ..
What have you been doing with the truck ? She's not meant to be sitting idle like that. ... Unless the FE has improved phenomenally !
__________________
Old 24th April 2008, 07:33   #38 (permalink)
Hi, dont know about the chemistry behind it but I have been using the pill in my santro and tavera since last 6 months and have found the following difference
1.) In the tavera, there was a definite lowering of engine clatter / sound and the pickup has improved a lot. Overall the vehicle feels a lot smoother to drive needing less gear change than before (Increase in Torque ??). Mileage too has improved but not much maybe to the tune of 10-15%.
2.) The santro feels like a verna - huge improvement in pickup and smoothness of the engine (MAKHAAN !!!). Feels so smooth to drive. Mileage has improved by around 2-3 Km / lt.
Now I am not connected to TULSINET in any way, these are my observations after using their pill. Their sales guy visited my tea garden and convinced us to buy 100 pills (10 X10 strips) for use of the Gensets (580 KvA) and even gave a demo on these monster engines. Fuel consumption reduced by 25 % and there was a huge reduction in engine sound and visible smoke. Unfortunately these engines were modified to run on GAS, so I thought why not use it in my cars.
I am happy with it.
Lifewater is offline   Reply With Quote
Old 24th April 2008, 09:43   #39 (permalink)
I do not differ with lifewater on the engine performance.
For the Safari:
- Engine is quiter and lesser of the 'krrr' knocking noise, while pickup
- Low end torque seems to have improved, power delivery feels crisper.
- FE values will have to wait till half tank for the calculations.
PS: Perhaps it would have been a good thought to distribute the pill (still 9 left with me) in the bangy team meet for some more genuine feedback from ppl willing to try.
__________________
Old 24th April 2008, 11:14   #40 (permalink)
Kaizer Sozay's Avatar
Default Contact Details
I wasnt able to find any contact details ont he website. can anyone post them
__________________
"The greatest trick the devil ever pulled was convincing the world he didn't exist ."
Kaizer Sozay is offline   Reply With Quote
Old 24th April 2008, 11:28   #41 (permalink)
See post #24
__________________
Old 25th April 2008, 14:52   #42 (permalink)
I went to their office at East of Kailash, and purchased it.
I broke one tablet into 4 pieces and put it in my tank (Approx 25 Litres remaining in the tank) drove to Noida no immediate difference, guess will have to wait for the drive back and then post again.
__________________
Old 26th April 2008, 17:37   #43 (permalink)
Okay, following is the FE.
With Normal Diesel + System D(only 20-30% AC) : 9.4 kmpl
With Normal Diesel + MP6ty (100% AC) : 10.7 kmpl
If you negate the AC usage %, FE increase is about 14%
If you assume that the Increased AC usage ate up 1 kmpl, FE increase comes to around 24%
This is in peak hours city driving, no highways.
I also forgot to mention that the cranking time also reduced while starting and so did the stopping shudder too.
__________________
Old 26th April 2008, 19:10   #44 (permalink)
kailashnj's Avatar
Hi Dadu,
I am interested in getting this magic pill. I also wrote to the email address that you had given but to no avail. Can you help me buy this product in Mumbai. I want to use it for my Baleno.
__________________
Bajaj PULSAR 220 DTS-Fi 2007
Maruti Baleno VXi 2006
Tata Indica DLG 2005
Bajaj Avenger 2005
kailashnj is offline   Reply With Quote
Old 27th April 2008, 09:29   #45 (permalink)
Initially I had also contacted one of their agents in mumbai but he replied very late and I had already bought it by then. He is based out of mumbai only so you can save the postage etc.
gopala krishna murthy karamcheti, biofuels india-mumbai, gopala49@yahoo.com
Originally Posted by kailashnj View Post
Hi Dadu,
__________________
Thread Tools
TechSpec® : Diesel Fuel and the role of Cetane in Engine performance dadu Technical Stuff 13 13th April 2008 21:11
Sprint Booster Sahil Modifications & Accessories 0 18th March 2008 19:35
Power Booster!!!! stevie Modifications & Accessories 2 10th January 2008 23:43
Hydro Octane Booster HAFI Modifications & Accessories 1 25th December 2006 01:28
STP octane booster?? panky12345 Technical Stuff 1 7th April 2006 03:51
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459
