Old 27th March 2008, 13:48   #16
simplythebest's Avatar
Originally Posted by kapilsharma80 View Post
most likely the curlprit is tacho cable..... also look for any loose joints on either ends of the cable.
Even though he has clarified that its the speedo which he has problems with,
for a tacho, generally, if it is mostly at high rpms, its your plugs/coils/coil wires etc.
Tacho's don't have rotating cables like speedos. So I don't see how a problem with the tacho wire will cause needle vibration, that too at select rpms.
simplythebest is offline   Reply With Quote
Old 27th March 2008, 16:38   #17
thanks guys ,
again sorry for all that confusion ,its the speedometer needle i was talking of at selected rpms. i think ill get the speedometer wire checked and changed.
amannarwal is offline   Reply With Quote
Old 28th March 2008, 11:02   #18
speedomter cable changed. free from all issues .
THANKS FOR EVERYBODY"S TIME
Zen exhaust spitting lots of carbon powder at high revs after cold start!! devrajman Technical Stuff 32 20th June 2010 08:28
HH Hunk, Bike revs high on it own amtak Motorbikes 20 29th April 2009 16:23
Car Vibrates at high speeds neo316 Technical Stuff 1 4th September 2007 11:56
revs too high during fst 5 mins... babe_on_wheels Technical Stuff 4 16th March 2006 17:09
Clutch Problem - Revs shooting up (Baleno) zaphod Technical Stuff 18 1st April 2005 13:49
