Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al).
Thread Tools
Old 26th March 2008, 12:57   #1 (permalink)
Default My Experiences with a Scorpio 2.6 (Non CRDE) and some Technical Questions
Hi all,
It's great to be here. This site has been like a hidden Gem for me, just discovered 2 days back. I have spent hrs browsing through this site now.
I have a Green Scorpio 2.6 DX Sept, 2003 (Non CRDE, Chain Drive SZ2600 PLUS Engine). This is the first new Vehicle i bought in my life. Before that my first car was a Contessa Classic and my second car was a Cielo, both second hand.
Ive had a love hate relationship with the Scorpio for the last 4.5 Yrs. It's done around 48000 Kms, and mostly on the highways, and the hills. It's done the Simla Lahaul Spiti, Manali Circuit. It's done the Manali - Leh route, and it's done the steep Jalori Pass.
I have a few minor issues for which i'm looking for answers.
1. My Vehicle has done 48000 KMS on Original Tyres (Bridgestone Dueller with Tubes). After i cross changed the tyres at around 40,000 kms the Scorpio started giving a vibration onto the Stearing at high speed (Over 90). I have got the Wheels Balanced from 3 places but the problem persisits. Ive been told by some people that the only solution would be to change the tyres. My tyres still have enought tread for another 30000 kms and i'm not going to change them till they wear out. Will i have to live with this Vibration ??
2. Since the begining i have noticed that When the Ac Cooling Knob is turned to less than full cooling, the rear vents start to blow out warm air, whereas the front ones are still blowing out cool air. I asked a mechanic and he told me that this was normal, and the best way is to leave the cooling to full always, as it uses the curtains system. Is this behaviour normal.
3. The Speed Needle of the Speedometer has started Vibrating at all speeds over 50. My Meter had the Manual KM Counters not the Electronic ones. The Fuel Meter shows a false reading (more fuel, specially when the needle is near the E) when the vehicle is cold and after a couple of minutes of driving the needle falls back. Will i have to get the complete console changed to sort out these problems. And will the Millage in the new meter be reset to 0 in that case ? I don't want that to happen.
I love the scorpio a lot because the Engine is becoming smoother by the day, it's really powerful and has not had any major issues.
I've had some small quality Control issues regularly, but most of them got sorted out in the Warranty Period in the first 2 yrs itself. I would not like to list them here, because it's better to talk of the accomplishments of your child than his faults...Right !!
Here's a picture of my scorpio stuck in snow in the mountains last March. And some pictures of some heavenly places my scorpio has been to.
Styler
Styler is offline   Reply With Quote
Old 26th March 2008, 18:01   #2 (permalink)
Since there seems no way to edit the previous post. I'm adding the querry that i forgot there.
My Scorpio (Non CRDE) has Tyre size 235/75/R15. When i eventually plan to change my tyres can we fit the bigger 235/70/R16 Tyres on this vehicle. If yes what needs to be done to accomplish this ?
What Tyres would the experts here recommend for me considering that i do a lot of mountain and offroad driving.
One Choice would be to go in for Michellen Tubeless Tyres. Are these available for the Scorpio and does anybody have any experience with these?
Old 26th March 2008, 18:19   #3 (permalink)
Hi Styler,
Just a few thoughts -
1. For the wobble you might also want to get the rims checked as if there is a dent it might lead to a wobble especially at high speeds. My Scorpio had the same issue
2. For the speedometer cable the only option is to change the same and this is a quality issue as I have changed this about 4 times by now!!!
I have the Michelin tubless AT on my Scorpio but have not upsized them. I have used them for abt 6k km am happy with these. I have used them for off roading as well and these do have a better grip then the regular Bridgestones. You might also want to try out the Yokohomas as well.
As regards upsizing you can check out this website Tire Size Calculator - tire & wheel plus sizing
Rgds
indianrunner is offline   Reply With Quote
Old 26th March 2008, 19:53   #4 (permalink)
Thanks your post was helpful.
So what Sorted it eventually - Changing the Tyres or repairing the Rims ?
Oh so it's not a problem with the meter itself, it's a problem with the Cable ??
I think i will also be going in for the factory size Michelin Tubeless....
Styler
Old 27th March 2008, 07:44   #5 (permalink)
gd1418's Avatar
All scorpios including the recent ones come with these Bridgstone Dueller H/T stock tyres. Mine have lasted till now with the odo reading 67K and are still good for another 10K.
I would be going in for the Goodyear Wrangler A/T when I change. Will give you the tyre size later as it is not the stock specification. I do not know if you have alloys or steel rims; if they are steel, then look out for dent etc., on them as they can result in vibration. What is the tread pattern on your tyres? Have you tried changing the face of the tyres inside out. This might solve your problem.
The answer to your query on aircon is no. Atleast I've not experienced this. You may like to have a second opinion on this. The speedo cable seems to be frayed hence the needle vibration. Diesel is denser when cold, that's why the fuel needle shows more. The new meter reading can be set to whatever you want. Indians are very capable in doing this..
Originally Posted by Styler View Post
Hi all,
Styler
__________________
Royal Enfield Bullet 1962
All Black 1998 Safari 4x4
All Black 2004 Scorpio GLx
Old 27th March 2008, 09:55   #6 (permalink)
Shashank.A's Avatar
If the rims have dents it shows in balancing...and styler has said that he has got them done several times...
@ Hey Styler, welcome to T-bhp..I hope you remember me
Did you get it done through computerized balancing ? Did you check it yourself ?
Shashank.A is offline   Reply With Quote
Old 27th March 2008, 10:45   #7 (permalink)
About the AC, i meant if we leave the Thermostat Knob (On the Left) to less than full cooling (not the fan speed) the rear vent blows out warm air.
I will get a second opinion on this.
About the Speedo, thank got it would just be a speedometer cable. I didn't want to change the complete Spedometer.
Thanks for all your help
Styler
As for my Tyres, they are the stock Bridgestone Dueller, and have enough tread to last 30000 kms more. It's just the wobble which is troubling. I will try to do what you all have advised. But i've noticed as time is passing and the tyres are adjusting to the new positions, the wabble is decreasing.
Old 25th May 2008, 17:16   #8 (permalink)
Hi Shashank,
I sure do remember you from the Indiamike meet up.
I remember seing you at a foodie site also...what is the name of a foodie site that you frequent ?
I get my wheels balanced at a local guy, but now i'm getting a feeling that his machine is not accurate.
Anybody know of a good and reliable place in Delhi to get Wheels Balanced ?
Is there a Bridgestone Company Service Center in Delhi ??
Styler
Old 26th May 2008, 13:17   #9 (permalink)
gd1418's Avatar
Visit this - http://www.team-bhp.com/forum/tyre-a...y-scorpio.html (New footwear for my Scorpio) for some answers..
Go to Anil Tyre alignment services located at the HP petrol pump just after Ansal Plaza near andrews ganj on the Siri Fort Road. He is the best as far as tyre alignment/balancing is concerned.
__________________
Old 26th May 2008, 14:29   #10 (permalink)
tsk1979's Avatar
I get Wheel balancing etc.,done from Tyre Shoppe noida. They have a rim straightening machine too, and I have paid countless visits to the same after Himalayan (mis)adverntures.
If Noida is close to your circuit, then this is the place to go. They are very professional, and take your car on a test drive after alignment/balacing etc., to check for vibrations.
If it is a tire issue, the company will replace tires under warranty.
__________________
Reclaimed, wrung dry and recycled....!
Old 13th July 2008, 18:33   #11 (permalink)
In the meantime, i found a good person to do Wheel Balancing. He found fault in one of the Front Tyres and shifted it back. And after the balancing the vibration has gone for now.
Thanks GD1418, tsk1979 .
I will try the Sri Fort road next time, it's closer.
Old 13th November 2008, 01:24   #12 (permalink)
badboyscad's Avatar
Guys, i was just going through K&N website and i found this:
they have listed mahindra and maruti suzuki in their filter search.
And can i install this filter(recommended by k&n) in my scorpio(non-crde)?
E-2984 - K&N Replacement Filters, Replacement Air Filter
pour in your views.
PS: especially BEHRAM sir.
__________________
Im not the Best but im not like the rest
badboyscad is offline   Reply With Quote
Old 13th November 2008, 11:04   #13 (permalink)
gd1418's Avatar
Visually and dimensionally it looks the same as the OEM filter. I don't see any reason why can't you use this. I would've but I've Green Cotton thunderstorm installed...:-)
pour in your views.
__________________
Old 13th November 2008, 11:44   #14 (permalink)
badboyscad's Avatar
thanks for the input gd sir. please let me know the price of the green cotton thunderstorm filter (any links would also do good).
__________________
Old 13th November 2008, 12:55   #15 (permalink)
gd1418's Avatar
Please visit - http://www.team-bhp.com/forum/modifi...orpio-glx.html (Green Storm Filter in my Scorpio GLx)
__________________
Thread Tools
Scorpio 2.6 T vs Scorpio 2.6 CRDe engine comparison Mohnish SUVs, MUVs & 4x4s 19 19th October 2009 19:20
The IT technical questions thread. DCEite Shifting gears 19 23rd September 2009 01:15
Technical Questions: ASP.NET Gordon Gadgets, Computers & Software 0 24th September 2008 11:26
Help me choose a used Scorpio 2.6 SLX / Scorpio 2.6 DX CRDe gbpscars SUVs, MUVs & 4x4s 33 28th July 2008 17:17
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
