Old 28th March 2008, 09:32   #1
Unhappy Brake lights cutting power to ICE???
Guys, am facing a strange problem. Since the last two days whenever I use the high beam in the morning or hit the brakes, my ICE powers off and on again.
This happens only in the mornings and not at night when I drive with the lights on. Also, the symptoms surface only after I drive some distance on the highway. In normal stop and go traffic, things are fine. If I try the high beam while stationary the rpm indicator does a small jump while the ICE goes off and if I do it while the car is running, there is a slight jerk in motion.
Doubt that the battery is the problem as the lights, horn and other electricals work fine. Could someone please throw some light on this issue?
tmanish76 is offline   Reply With Quote
Old 28th March 2008, 11:09   #2
clevermax's Avatar
Thanked: 401 Times
Check your battery, and the dynamo.
All cells in the battery, The charging voltage etc. Seems like the battery is not getting properly charged.
And if you have to change the battery, take good care of the new one, do not allow any local mechanic to top-up the battery with water every now and then. This is a bad practice and it surely reduces the life of the battery. The battery in my car was working fine for 6 years, until a mechanic opened it up for top-up. Within 2 weeks, one of its cells died.
clevermax is offline   Reply With Quote
Old 28th March 2008, 14:00   #3
Thanks Max...but I had the batter checked recently and it was fine. Additionally, the car runs ICE and headlights without the engine on quite well. Would this not indicate that the battery was fully juiced?
Old 28th March 2008, 14:58   #4
hi manish,
i think you might have to check the battery and the alternator. the battery is not getting charged properly due to some reason. how old is your battery?
- Harsha
harsha.cs1 is offline   Reply With Quote
Old 28th March 2008, 17:25   #5
Hey Harsha....how's you man.....?
The battery is about 2 years old. But if the battery was the problem how is it functioning all right at night is what is puzzling me.
Originally Posted by harsha.cs1 View Post
hi manish,
- Harsha
Old 28th March 2008, 19:33   #6
clevermax's Avatar
Thanked: 401 Times
Now I'm getting it.. It might probably be a relay problem, and because of which, the Head unit is not getting power for a split second or so. So it turns off and turns on again. the relays of the high beam or the break lights might be momentarily hindering the power supply to your head unit.
From your description, the battery and the alternator seem to be okay...
Old 31st March 2008, 10:30   #7
Finally...we seem to be getting somewhere. Now, would you have any idea where this relay is located. Am scared to give the car for repairs to Hyundai lest they give some other analysis and fleece me for a simple relay problem.
And just for the record, drove the car today morning after leaving it parked over the weekend and there was no problem even on the highway.
I feel that when I speed up something is getting overcharged and tripping the relay you mentioned.
Old 31st March 2008, 11:28   #8
Hi Manish,
I am fine, thanks. Your problem is unique, as are most auto electrical problems! Do check out my defogger issue! http://www.team-bhp.com/forum/newrep...reply&p=775442
Anyway, i too guess your problem might have something to do with the relay. Not sure where it lies, but i guess it would either be in the fuse box under the hood or the one in the passenger cabin just to the right of the accelerator. I once had a burnt relay and it did give a burnt smell in the passenger cabin. so i guess this would be in the fuse box near the driver's right foot. Yes, it is important to go to some good auto electrician. Many big garages don't know their auto electricals well. As regards A.S.S., i have been told that they fleece because they prefer to replace than repair. If some wiring has gone wrong, they just order replacement of the whole loom!
Do keep us posted!
Compromise on basic safety features for cost cutting? akash_m The Indian Car Scene 70 24th July 2015 17:19
Road cutting-some clarifications needed mooza Street Experiences 7 1st September 2010 17:11
Cutting open a bass tube? arpandiv In-Car Entertainment 8 16th April 2008 16:18
Something unusual......a B.E.S.T. driver charged for lane cutting autozealot Street Experiences 15 12th September 2006 18:00
Engine Porting, Ploishing & Valve Cutting Kaizer Sozay Modifications & Accessories 6 15th March 2006 23:36
