Thread Tools
Old 23rd June 2008, 19:56   #31 (permalink)
gemithomas's Avatar
Originally Posted by drpullockaran View Post
I did not read the complete thread and hence wasted your time and mine too (Sorry) as I was aghast at the notion that the throttle body cannot be cleaned and wanted to pen down my 2 paisa information before he changed the throttle body. I gather its too late though. Gemi if you do not mind please keep all the exchanged parts with you as I would like to get my hands dirty on the old throttle body that you are probably going to throw away. I am serious.
Sorry.
THey did not give me any parts since i was under warranty. They said they needed it for claiming warranty. THanks for your help. It was not a waste of time
Just wanted to ask one more thing. I recently shfted to Castrol Magnatec 10W40 engine oil. I have a feeling that the car stains a little more than earlier before it reaches speeds above 100. Earlier 100 could just come without any strain at all. Not sure its its just a mental barrier but wanted to confirm if the change in oil could cause this. FIAT recommends 15W40.
__________________
"Our world is in its current state because of the choices WE made ...or failed to make"
Old 23rd June 2008, 22:29   #32 (permalink)
Jaggu's Avatar
Its a mental barrier coz technically car should feel more at ease with the better oil.
__________________
The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin
Old 24th June 2008, 00:34   #33 (permalink)
drpullockaran's Avatar
Default I doubt it is the oil.
Before you put the oil in bad light I suggest you find out the viscosity values at 90-100degrees centigrade and above for both the oils. At low temps/start up the 10W40 oil is thinner without a doubt but what its value is at 100degrees and above when the engine is warmed up is what matters.
I too used Castol magnatec 2 years ago but was not happy with it as it did not match up to the cheaper but definitely superior Total/ELF oil which I have been using for a long long time now. I used the Magnatec and the Idemitsu oils in my GTX and Junkindica but they are not a patch on the oils from Total/Elf. Please note these are subjective assessements and not at all scientific. Moreover if you rip the car for a minute or 2 you can smell burnt oil when using castrol but not so with the other brands. I find TOTAL/Elf to be superior to Idemitsu too.
__________________
Bye and wear your seat belts.
drpullockaran is offline   Reply With Quote
Old 24th June 2008, 00:41   #34 (permalink)
Jaggu's Avatar
Idemetsu is a very average frequent change oil, Magnatec is definitely superior and very apt for our climate.
__________________
Old 24th June 2008, 12:46   #35 (permalink)
hrsraghav's Avatar
Sorry.
Nothing to be sorry dear. We wish to have more of your knowledge. Its just that the problem of Gemii was solved, so i wanted you to comment on my problem
hrsraghav is online now   Reply With Quote
Old 24th June 2008, 13:08   #36 (permalink)
Rahulkool's Avatar
if you are buying castrol, be careful because there are many fakes available for this brand ..... this is the reason i stay away from castrol
Rahulkool is offline   Reply With Quote
Old 25th June 2008, 23:17   #37 (permalink)
Default Whether its rising or falling the culprit is the throttle body
If the acceleration of the vehicle above idle seems normal then its got only to do with the idle actuator, stepper motor of the throttle body.
If the power also seems to be down then you have got to check the fuel flow up to the injectors. My hunch is that its got to do with the byepass valve and stepper motor of the throttle body.
Originally Posted by hrsraghav View Post
I too got some rpm problem.
It happened at one traffic light, as the car was idle, the rpm by itself starts dropping from its 800 (i suppose thats 800) to 200, and then it keep on moving in between. This happened around a week back, then nothing happened till today.
Today same problem, and once even rpm dropped so low that once the battery light on the display panel glowed for a moment. every time the rpm dropped the car use to jerk similar to like knocking.
Also i had to press accelaertaor a bit hard to move the car.
I always go to same petrol pump, and use HP power. So i dont think fuel adulteration could be the cause. Also its not regular, and everthing is normal at higher speeds. Its only when car is standing this dropping of rpm occurs.
Clueless about what could be the cause.
Gemi I suppose in your case the rpm was rising above default level, but here its dropping.
__________________
Old 28th June 2008, 05:56   #38 (permalink)
hrsraghav's Avatar
Hi Drpullockaran,
The problem is not at all periodic, nothing happened after that day. Car is running fine. I don't know how to convince the Service Center Guys that it needs the replacement of atleast the throttle body.
Old 30th June 2008, 20:53   #39 (permalink)
Default ISA may be the culprit !
It should be the throttle body problem. You can get is replaced under warranty.
Hi , maybe it should not come to replacing the throttle body , just decarbonizing it ought to be enough , also with servicing of the ISA ( Idle speed actuator ) as some of th BHPIANS suggested.
Most likely that should solve your problem.
regards
HIGHNOON is offline   Reply With Quote
Old 17th September 2008, 20:58   #40 (permalink)
Default Need help for a similar problem
hi to all
this is my first post (ever) in any forum so pardon me if am not all that savy to things automotive.
I have a Palio GTX and the problem am facing is that the car slows abruptly in lower gears (1st,2nd &3rd gears) when i take my foot off the gas pedal. It almost brakes suddenly. I notice that the RPM fall rate is not very rapid but i really cant say about this (frankly i dont know which is the normal fall rate). But am almost pushed forward in my driver seat as i shift gears..i need to maintain throttle to some extent or else this braking will occur.
The mech diagonised this a throttle body idle accuator problem and the sensor not functioning as well. We tried getting the sensor alone but i guess its part of the throttle body in Palio GTX. So we did manage to get one from a total broken down car and fitted it. There is only a very slight improvement..(maybe I am imagining this too). I am a little worried if the car that coming behind will not expect this braking thats happening as i shift through lower gears. Should I change the entire throttle body unit which costs about 13k or this could be any other problem. the idle RPM with and without AC remains at 800 all the time and the engine does not cut off at all..so thats not a worry.
Any ideas from any you would be a big help.
jay116 is offline   Reply With Quote
Old 18th September 2008, 11:26   #41 (permalink)
planet_rocker's Avatar
are you talking about engine braking? lets say you shifted to 2nd from 1st - take it to 40kph at 2k rpm and let go of the gas pedal - the car behaves as if someone is hitting the brakes?
planet_rocker is offline   Reply With Quote
Old 19th September 2008, 14:23   #42 (permalink)
hrsraghav's Avatar
Well the RPM dropping problem got a severe shape last week.
It happened in the evenin when i was reurning back from office. Firstly in idle state the RPM use to drop below 800 mark, the car use to shudder, and at times it went off. And as soon as i engaged 1st gear and release the clutch, the RPM almost use to went to zero and car would turn off. I have to press the accelrator so that rpm increases above 2000 and then release the clutch. In a stretch of around 4 kms the car went off around 5-6 times. I immediately took it to the Dhingra Motors, but as it was too late(6 PM), so the advisor told me to bring back the car next day morning. I showed him the problem, and he said it has to be seen through Examiner and check whats the problem. Somehow I managed to reach home. NExt day morning I again went to Dhingra motors. Just to drive the car from outside the shed to inside the shed of workshop, the mechanic himself has to work hard and Rev the engine at high RPM, even with him the car went off three times for a distance of merely 20 meters.
Also i observed the car was giving a lot of black smoke.
Now as one guy connected Examiner, the car started behaving normally.
I asked him what has he done, he said nothing, he was just trying to see whats wrong. After that I took test drive of 6-7 Kms and cae was running perfectly normal.
I was utterly confused as to what is happeneing. When i asked the service manager, he said maybe some adulterated fuel have altered some setings and examiner may have corrected it by itself. I am confused whether mere connecting to examiner can correct the wrong settings and no one have to instruct for that.
Anyhow i took the car back, and now after 4-5 days again the same problem is resurfacing with some midlness. Like the RPM drops at times but not always and not that drastically.
Fellow members kindly share your opinions and suggestions on this problem
Old 19th September 2008, 14:30   #43 (permalink)
@raghav - they didn't clean the throttle? they didnt say anything about the throttle body actuator? did it happen when the car is hot / stop & go traffic?
Old 19th September 2008, 14:55   #44 (permalink)
hrsraghav's Avatar
No to my surprise they didn't mentioned anything about it. I told them to check the throttle body and injectors, but since the problem was not appearing that time, so I suppose they were more happy to get releived from me, and everytime i asked them anything, they siad same thing that sir now everything is OK then no need to check anything.
Dhingra Motors in inherently a TATA dealer which started selling FIAT only a year back.
Old 22nd September 2008, 12:51   #45 (permalink)
mpescatori's Avatar
Hello to all, Maurizio Pescatori here from Italy.
While I (currently) do not own a Fiat, you will imagine Fiats are a "staple ingredient" in the average Italian's life, you'll not find one who, some time or another, didn't own a Fiat ! (and if it wasn't him/her, it was Mummy/Daddy's car...)
You all seem so concerned about the idle speed actuator and the throttle body, but...
...let's go back to the good old days of carburettors and condenser/points ignition.
What would/could make a car drop in revs, sputer and run erratically?
"Dirty fuel" one thinks, but... have you all checked your fuel filters?
Even if your fuel does seem clean, if the fuel filter has clogged over time, fuel will not reach the carburettor properly.
Second issue, dirty carburettor bowl & jets. In EFI terms, dirty injectors. So clean the injectors. How? Buy a industrial-sized bottle of injector cleaner, and pour it into the tank, then fill up. I'm not talking about the "one fuid ounce treats 20 gals", I mean one pint! It'll eat up the muck like you've never even imagined! And change the filter before and after this treatment.
Third, ignition.
If, after all thins cleaning up, the car still , then it's time you looked at ignition.
When I had your very same symptoms, I did all the above, and the car would STILL run erratically! I was desperate... because,. among things, I commute an average of 2000 miles/month, so my car's performance is important to me!
I'll spare you the tragicomedy of months and months of my car limping, then working fine ONLY as I would drive into the official dealership's workshop.
It turned out the engine had two loose spark plug cables.
It seems the mechanics would pull the spark plug leads from the leads themselves, rather than from the rubber booties that cover the spark plug contacts. The lead had become disjoined from the plug, so one, eventually two cylinders would only get their spark erratically, not properly as expected.
So, if all else fails, check your plug leads.
mpescatori is offline   Reply With Quote
Thread Tools
Fiat Adventure - Last piece. Arjun1010 Sedans 16 31st January 2008 14:14
Fiat Adventure stopped?? vinodbijlani The Indian Car Scene!! 1 12th August 2007 09:37
Missing on Fiat Adventure gemithomas Technical Stuff 35 18th June 2007 10:07
Fiat Adventure wanted raja_ys Shifting gears 0 1st November 2006 16:35
Used Fiat Adventure / Weekend Andre Sedans 4 3rd August 2006 22:23
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
