Old 7th April 2008, 13:06   #31
Jaggu's Avatar
Thanked: 8,674 Times
Wobbling at speeds = balancing issue
Independent suspension on front wheels only = balance 2 wheels
Fully independent suspension on all 4 wheels = balance 4 wheels
Side pull, uneven wear of tyre, in some cases tyre squealing at high speeds = Alignment issue
Hope this helps
Old 7th April 2008, 14:48   #32
Rahulkool's Avatar
Thanked: 591 Times
Originally Posted by supremeBaleno View Post
They changed the oil without changing the oil filter ? I would think that these 2 need to be changed simultaneously.
yeah thats right but this oil change was not necessary, they have to do it just i asked for it. otherwise first oil change is at 7500kms and i got it done at 1k kms in first service. so i didn't asked them to arrange the filter. anyways in second service i will get the oil and filter and ask them to change it.
Hope this helps
thanks for the info
Rahulkool is offline   Reply With Quote
Wobbling front tyre of palio 1.2 2002 genesis Technical Stuff 4 9th August 2009 09:55
Clutch replaced but still having vibration problem prasannapatil Technical Stuff 13 12th May 2009 11:27
Wobbling Palio psp62in Tyre & Alloy wheel Section 4 21st March 2009 16:33
Help!! Alto facing a weird vibration problem wanderluster The Indian Car Scene 0 8th September 2007 01:15
