Old 2nd February 2005, 10:14   #16
gkrishn's Avatar
Thanked: 37 Times
Originally Posted by ajmat
ditch the bridgetones- they are made of hard rubber for fuel conomy and durability.
Could be. I have the same S322 on my sail. There has 3,4 instance so far, in near panic sit, the barkes have locked up and car keeps screeching forward. This is true esp with the front wheels. Guess its also due to my front heavy hatch.
gkrishn is offline   Reply With Quote
Old 2nd February 2005, 10:37   #17
Shan2nu's Avatar
Thanked: 89 Times
In absolute panic situations your foot hits the brakes so quick and so hard that theres no question of even having time to think of downshifting.
Well, i've been in emergency situations and i still haven't slammed the brakes, ever. But you have, haven't you Rehaan "At the expressway toll gate", scaring the hell out of all the guys sitting in the Vtec. Hehe
I agree that down shifting isn't possible when it suddenly happens and that is what you're trying to say. But i never slam the brakes, it's either engine braking or threshold braking with only the brake pedal doing duty.
Main motive being, to prevent the tyres from locking.
Shan2nu
Old 2nd February 2005, 11:10   #18
Rtech's Avatar
Thanked: 221 Times
I think they are refering to emergency braking Shn2. You don't have time to use engine braking in a panic stop.
BTW, just a few posts ago you mentioned you pump the brakes while making panic stops. Good to see you've moved onto threshold braking now lol
Old 2nd February 2005, 11:16   #19
Rehaan's Avatar
Thanked: 25,037 Times
Yeah... i guess when i say "absolute panic situations" i mean when a dog/cat/person/car jumps into your lane just ahead of you.... its more a reflex action than anything.
cya
R
Old 2nd February 2005, 11:34   #20
Shan2nu's Avatar
Thanked: 89 Times
I never said i did it. I just said "Get into the habit of pumping the brakes, it'll save u a lot of trouble". Pumping the brakes is good to begin with, but it isn't the fastest way of stopping a car.
I use threshold braking with some help from the engine.
Shan2nu
Old 2nd February 2005, 16:25   #21
speedsatya's Avatar
Thanked: 712 Times
in a panic stop u have to use the brakes.there is no other option.at high speeds there is no other option .but at moderate speeds ,u can manouver around the obstacle if there is space.
speedsatya is offline   Reply With Quote
Old 2nd February 2005, 16:32   #22
Shan2nu's Avatar
Thanked: 89 Times
Everybody uses the brakes, be it engine braking or threshold braking. No one stops a car without using the brakes. How you apply the brakes is what matters.
Shan2nu
Old 2nd February 2005, 21:57   #23
amitverma's Avatar
actually theres nothing wrong with the car. its just that non-ABS vehicles do lock up in the event of panic-brake.
a couple of days back i was doing abt 80 on my palio and almost overlooked a speedbreaker. it was all panic and slammed on the brake pedal but to no help, front discs locked up and my ride just skidded over the speedbreaker at abt 40 km/h :ouch:
amitverma is offline   Reply With Quote
Old 5th February 2005, 09:27   #24
Domnic's Avatar
Get brake balancing done, and see if any air trapped in the lines, this can cause erratic braking.
Dom
PS: and yep if you slam it, its eventually going to lock up
Domnic is offline   Reply With Quote
Old 5th February 2005, 10:54   #25
Shan2nu's Avatar
Thanked: 89 Times
Well, Dom, the car has very powerful brakes. I bit too much power i'd say. It just doesn't have the feel of the older gen citys.
It either brakes or it doesn't, there's nothing in between. There's absolutely no feedback from the brake pedal.
Shan2nu
Old 7th February 2005, 14:44   #26
Thanked: 64 Times
Originally Posted by Domnic
May not be a problem with brake balancing. His driver is always able to brake it properly.
RX135 is offline   Reply With Quote
Old 9th April 2007, 22:28   #27
Thanked: 1,172 Times
I have experienced this locking on my NHC on curves.
Almost intutively, I developed a habit of pressing and releasing the break (frequency of doing this being intutively propostional to the level of emergency!) instead of keeping it pressed...
This seems to be a safer workaround. Not sure if that's what you are calling as "pumping".
What's threshould breaking ? If possible, i would like to learn from you.
anandpadhye is offline   Reply With Quote
Old 10th April 2007, 10:35   #28
msdivy's Avatar
Thanked: 885 Times
Here is some detailed info: Braking
Worth reading to learn about braking.
msdivy is offline   Reply With Quote
Old 10th April 2007, 10:42   #29
yogi1771's Avatar
Originally Posted by Shan2nu View Post
Found a good article on "How to stop a non ABS car in an emergency".
This is an important braking tech which we overlooked.
Shan2nu
hi shan2nu the link is not working
yogi1771 is offline   Reply With Quote
Old 10th April 2007, 11:01   #30
Jaggu's Avatar
Thanked: 8,670 Times
upgrading the tyre will definitely help, dont go overboard with this though, 195 or 205 max
Gave my Honda City for an oil change. Now, the remote locking system won't work vu2pmc Technical Stuff 7 15th March 2015 14:38
Alto Xcite - Upgrade Manual Central Locking to Remote Central locking Laxminarayan Technical Stuff 1 28th December 2009 15:02
Central locking versus remote locking mb_jg Technical Stuff 40 2nd January 2009 20:08
