Old 1st February 2005, 19:19   #1
Angry Brake Locking in New Honda City
Hi Guys:
Have a new honda city for about a year... My problem is that in panic stops the brakes just lock up and the entire car skids quite freely. Nearly missed a couple of accidents... and even had a fender bender because of this.
Mine is a stock car -- no mods; Bridgestone S322 tubeless tires.
Any suggestions?
Am I the only one that is facing this problem?
Is it a flaw in the car or in my driving style? (Never have this problem on my Accent though)
(Somehow my driver doesnt seem to have this issue... though I guess he uses engine breaking mostly )
Cheers,
V
vitriol is offline   Reply With Quote
Old 1st February 2005, 19:30   #2
Shan2nu's Avatar
Thanked: 87 Times
That's your problem. Always use engine braking, never go all out on the middle pedal, especially on a car without ABS. The moment you feel the tyres are gonna lock up, let go of the brake pedal and press them again. Get into the habit of pumping the brakes, it'll save u a lot of trouble.
The thing is that the NHC has very powerful brakes and the tyres aren't very grippy. Upgrading to 185 or 195 will surely improve it's braking capabilities.
Shan2nu
Old 1st February 2005, 19:40   #3
Thanked: 48 Times
Looks like he drives too close to other vehicles. Engine breaking is recommended but in case of extreme panick, it is simply not possible to break, shift down, break etc.
I suggest rather cautious driving assuming all others, on the road, are there to get you
RX135 is offline   Reply With Quote
Old 1st February 2005, 19:59   #4
Shan2nu's Avatar
Thanked: 87 Times
For people who are not used to it, yes. But for a person, who's been doing this for years will automatically do it.
Sometimes i watch the best motoring guys do the toe-heel braking and wonder.....how do they manage to do it so easily and quickly, but with time, it does happen.
Shan2nu
Old 1st February 2005, 20:02   #5
Thanked: 48 Times
Wish I could do it I can do it if I get just enough time to think and react, but if it's very sudden, chances are that I'll break it hard. So, I prefer to maintain safe distance.
Old 1st February 2005, 21:03   #6
Shan2nu's Avatar
Thanked: 87 Times
Found a good article on "How to stop a non ABS car in an emergency".
From the website - "threshold braking", and is the fastest and safest way to stop a car.
This is an important braking tech which we overlooked.
Shan2nu
Old 1st February 2005, 21:04   #7
iceman91's Avatar
Thanked: 22 Times
it could also be because you said its a new car...so u havent drive it much and the honda's have the shaarpest braking in the market today ...gotta get used to it..
iceman91 is offline   Reply With Quote
Old 1st February 2005, 21:09   #8
Shan2nu's Avatar
Thanked: 87 Times
Actually if you practice threshold braking from 60, 80 and 100kmph on a safe, lonely and straight stretch of tarmac, you will improve a lot, when it comes to emergency braking.
Shan2nu
Old 1st February 2005, 22:10   #9
speedsatya's Avatar
Thanked: 706 Times
hey vitriol,
check the air in your tires.if its more then also u san get less traction.try filling 2-3 psi less.and the fact that u have to do panic stops means that either you drive too fast for comfort or you drive too close to others.
try to change your driving.
speedsatya is offline   Reply With Quote
Old 1st February 2005, 22:48   #10
Shan2nu's Avatar
Thanked: 87 Times
I don't think that's a good idea. It's ok to reduce 2-3 psi provided the pressure is 2-3 psi more than the company recomended pressure.
Ideal pressure however is 29 psi. Anything below that will actually reduce traction. So a tyre with 25-26 psi will lose traction faster.
I fill 30-31 in the front tyres and 29 at the back, this helps provide traction to the front wheels, making the car take corners much faster with reduced understeer.
Shan2nu
Old 1st February 2005, 23:46   #11
.anshuman's Avatar
Thanked: 8,930 Times
maybe ur driving two different cars of different brake response,otherwise nhc has nice brakes ,maybe your tyres are too overinflated,try upsizing to 205 size you'll forget locks
Old 2nd February 2005, 00:09   #12
Shan2nu's Avatar
Thanked: 87 Times
Man with 205 on that car, you can forget everything. 205 is just too much for the NHC to handle. 195 is as high as you can go, unless you modify it's engine.
Shan2nu
Old 2nd February 2005, 06:42   #13
Rehaan's Avatar
Thanked: 22,586 Times
Exactly what i was gonna say......especially since you say your other car is an accent! (if its the old 1.5 accent) then the brake pedal sensitivity of the two cars is literally two worlds apart.
Also, make sure your tires are inflated to the reccomended pressure as speedsatya said.
If this still causes problems, get back to us and we can go on to the next stage of what might be wrong with ur braking system.
cya
R
Rehaan is online now   Reply With Quote
Old 2nd February 2005, 06:45   #14
Rehaan's Avatar
I would love to believe that, but sadly its not true....
In absolute panic situations your foot hits the brakes so quick and so hard that theres no question of even having time to think of downshifting.
R
Old 2nd February 2005, 08:18   #15
Thanked: 9,723 Times
ditch the bridgetones- they are made of hard rubber for fuel conomy and durability. I put goodyear NCT's on my Vtec and braking is a lot more controlled
Gave my Honda City for an oil change. Now, the remote locking system won't work vu2pmc Technical Stuff 7 15th March 2015 14:38
Alto Xcite - Upgrade Manual Central Locking to Remote Central locking Laxminarayan Technical Stuff 1 28th December 2009 15:02
Central locking versus remote locking mb_jg Technical Stuff 40 2nd January 2009 20:08
