Old 9th April 2008, 11:46   #76
Shan2nu's Avatar
Thanked: 89 Times
The RD0601 also comes with a launch control. All one needs to do is ask Karthik to enable it. I got to get mine set too.
But don't you need wheel rpm sensors to detect a wheel spin for the ECU to activate launch control? Do RD have their own sensors?
Shan2nu
Old 9th April 2008, 12:44   #77
Rehaan's Avatar
Thanked: 25,043 Times
I'm guessing it is more like a "launch mode" where the ECU just holds the car at X rpm, and not a full fledged launch control (= coupled with TCS) ?
cya
R
Old 9th April 2008, 14:42   #78
Shan2nu's Avatar
Thanked: 89 Times
But even for that you need a car with TCS. Cars like the OHC, Baleno etc don't have TCS, so in such cases you will need to fit aftermarket sensors.
Shan2nu
Old 9th April 2008, 15:22   #79
condor's Avatar
Thanked: 4,907 Times
Ford Rocam : Economy in sense throttle < 40% or < 4000 RPM, you can tune your map up to a particular load point to run 14.7 A.F.R in closed loop or even slightly leaner 15.1 AFR, depending upon engine combination, c.r etc, ...
Is this practical - in terms of putting it to actual use ?
I ask this in the context of engine speeds vs gear used. In city traffic, one will not be able to get into higher gears. So one can still be in the same engine speed (range) even if driving at 20kmph in 2nd - or 35 kmph in 3rd - or 50 kmph in 4th.
While my own case is not a good example - but I am often at same / higher rpms in city than when on the highway.
Old 9th April 2008, 18:00   #80
Ford Rocam's Avatar
Thanked: 16 Times
Thats thing is called as Part Throttle Tuning. Its more difficult than w.o.t tuning especially if you are running larger injectors.
I am using it on a daily basis, infact i was running 750CC injectors in N.A mode without even turbo installed with the old 4-1 headers to set my part throttle tuning correctly,check my garage for details.
Ford Rocam is offline   Reply With Quote
Old 9th April 2008, 18:08   #81
Psycho's Avatar
Thanked: 95 Times
A couple of points at my end
1. Still feel that closed loop support can drive it way better than having a tuner sitting and struggling with 3 maps.
2. closed loop in link with a wideband sensor can allow for more accurate afr based tuning which is way better than multiple maps.
3. the stock ecu is any way the best mileage map that one gets so if one practices restraint on the right foot the mileage actually goes up with a performance map.
Old 9th April 2008, 19:49   #82
Jaggu's Avatar
Thanked: 8,693 Times
I was also thinking on these terms, point is: The new curve is optimized for torque delivery right? so with a gentle foot the FE should show improvement ??
Old 10th April 2008, 04:51   #83
Psycho's Avatar
Thanked: 95 Times
Yes Jaggu that is exactly what i was getting at. The best maps are designed to increase the ve of the engine hence increasing driveability and mileage on na and off boost on forced induction engines.
With free revving engines our right feet also tend to go pedal to metal more often making us loose mileage in return.
Old 10th April 2008, 21:52   #84
rdkarthik's Avatar
Thanked: 11 Times
Coming soon
Yes, but cost goes high to have a permanent wideband lambda sensor.
No
rdkarthik is offline   Reply With Quote
Old 10th April 2008, 22:02   #85
nitrous's Avatar
Thanked: 285 Times
Yeah,man. The best deals I've come across cost around $300.
Old 11th April 2008, 07:27   #86
Psycho's Avatar
Thanked: 95 Times
Hey Kartik,
Please read point 3 in the earlier post as the stock ecu isnt, there was a typing mistake as i have been posting from my phone.
Old 11th April 2008, 12:35   #87
Shan2nu's Avatar
Thanked: 89 Times
But how can a performance map make an engine more FE than stock?
Shan2nu
Old 11th April 2008, 23:55   #88
PatienceWins's Avatar
Thanked: 285 Times
Shan2nu
I am having the same doubt.
My understanding is that more fuel is required to handle the new custom map. How is a lighter foot help in getting FE compared to stock ECU as the custom map would be straining the engine more?
PatienceWins is offline   Reply With Quote
Old 12th April 2008, 00:15   #89
Shan2nu's Avatar
Thanked: 89 Times
Spoke to Psycho and Wolf about this today and from what i can rem, a custom map doesn't posses the ability to vary it's AFR to an extent, to which a custom map is capable of.
So in cruise mode, it is possible that the custom map is actually running leaner than a stock setup, which helps it achieve better FE (which is similar to what Rocam was saying).
Maybe Karthik can give a detailed explaination as to how this works.
Shan2nu
Old 12th April 2008, 00:33   #90
ported_head's Avatar
How does a map change VE of an engine? Only change in quantity of volumetric flow because of fuelling? Or something else?
ported_head is offline   Reply With Quote
Help-Petes box or Race Dynamics piggyback ECU for Optra Magnum dockap Modifications & Accessories 66 9th December 2017 12:22
My Getz CRDI with Race Dynamics XM400 Edit: updated with 0-60, 0-100 figures Furman Test-Drives & Initial Ownership Reports 62 12th October 2009 06:24
Race Dynamics: Honda City VTEC rdkarthik Modifications & Accessories 93 11th August 2009 20:20
ICE Upgrade in Hydra's Hatch II (Swift Zxi) - Alpine, Image Dynamics, TRU Tech hydrashok In-Car Entertainment 239 26th July 2009 11:54
