Old 12th April 2008, 01:04   #91
nitroxx's Avatar
Thanked: 26 Times
I agree with the closed loop feature, however we can have a map that runs closed loop to a certain point and then goes into open loop mode right?.. my other question relates to the fact that..the performance map would handle fuelling,but how would It improve efficiency (only with a map)?Or is this where part throttle tuning comes in?
nitroxx is offline   Reply With Quote
Old 12th April 2008, 01:18   #92
PatienceWins's Avatar
Thanked: 285 Times
Thanks for the clarification Shan2nu.
If that is the case, then custom map should give good FE with normal city usage. Are guys with custom map experiencing the same?
Seems to be a good proposition, more torque at disposal and better FE with normal usage.
PatienceWins is offline   Reply With Quote
Old 12th April 2008, 02:21   #93
Shan2nu's Avatar
Thanked: 89 Times
a custom map doesn't posses the ability to vary it's AFR to an extent, to which a custom map is capable of.
Read that as : a stock map doesn't posses the ability to vary it's AFR to an extent, to which a custom map is capable of.
Shan2nu
Old 12th April 2008, 08:47   #94
Ford Rocam's Avatar
Thanked: 16 Times
You need to tune in open loop first, get as much readings as possible on different road conditions like in traffic, while cruising & wot runs.
Take readings in hot climate in afternoon & in late night when its cold,
also if possible take the car to some high altitude & take readings and tune accordingly. This is where wideband comes in to picture.you need to have that installed in your car hooked up to a standalone to get readings.
once you are done tuning your fuel/ign map in open loop, then you should set back your ecu to run in closed loop, up to a particular load point decided best by your tuner. once it crosses that particular load point & RPM you can tune your same map for max perfomance to redline.
Ford Rocam is offline   Reply With Quote
Old 15th April 2008, 21:14   #95
Thanked: 20 Times
Is there any remapped ecu available for palio 1.6 from R.D ?
swathyd is offline   Reply With Quote
Old 21st April 2008, 10:57   #96
rdkarthik's Avatar
Thanked: 11 Times
swathyd - Yes we have ECUs compatible with the palio 1.6.
The other guys, hang on a day or two i will upload info on how mapping can be optimized for eco and performance.
rdkarthik is offline   Reply With Quote
Old 2nd May 2008, 19:49   #97
Psycho's Avatar
Thanked: 95 Times
Ding Dong time to share the info, looks like you forgot all about it.
Old 13th May 2008, 09:13   #98
Thumbs up
Nice review Psycho, Keep up the GOOD WORK RD & team, ALL THE BEST.
CHERS,
G D
P180V1 is offline   Reply With Quote
Old 19th July 2008, 22:50   #99
Rehaan's Avatar
Thanked: 25,043 Times
Default crosslink
Take a look at Viper's RD-0601 reivew here : http://www.team-bhp.com/forum/modifi...-race-ecu.html
cya
R
Old 19th July 2008, 22:55   #100
theMAG's Avatar
Thanked: 1,574 Times
Karthik,
You got anything for diesels in the pipeline - Indian ones at that ?!
Old 20th July 2008, 08:54   #101
vikram_d's Avatar
Thanked: 940 Times
The diesel ECU is under testing as we speak. It should be out quite soon.
Old 20th July 2008, 14:48   #102
rdkarthik's Avatar
Thanked: 11 Times
theMAg, our diesel systems have just completed all the on-road endurance testing, so you can expect them very soon. The CD0801 series of ECUs for common-rail diesels are designed to work on any crd system.
We havent decided on releasing the tuning software for this.. What do you guys think? Should we or should'nt we release the software ?
Old 20th July 2008, 21:46   #103
vikram_d's Avatar
Thanked: 940 Times
I think you should release the software
Old 20th July 2008, 21:54   #104
binz's Avatar
Thanked: 412 Times
Release it on request and get it in writing that RD will not be responsible for any eventualities due to unsupervised tuning .. or something to that extent.
Old 20th July 2008, 22:57   #105
Awaiting Email Confirmation
Thanked: 20 Times
that is the best way to keep all camps satisfied.
With this new diesel ECU, it should be relatively safer to use the boost controller that is also being tested by others on the forum , right?
Help-Petes box or Race Dynamics piggyback ECU for Optra Magnum dockap Modifications & Accessories 66 9th December 2017 12:22
My Getz CRDI with Race Dynamics XM400 Edit: updated with 0-60, 0-100 figures Furman Test-Drives & Initial Ownership Reports 62 12th October 2009 06:24
Race Dynamics: Honda City VTEC rdkarthik Modifications & Accessories 93 11th August 2009 20:20
ICE Upgrade in Hydra's Hatch II (Swift Zxi) - Alpine, Image Dynamics, TRU Tech hydrashok In-Car Entertainment 239 26th July 2009 11:54
