Old 1st April 2008, 15:07   #1
PVS
Thanked: 121 Times
Default Inward Camber for rear wheels of 3 wheelers
Hi All
Many a times I have observed that the rear wheels of a goods-carrying 3 wheelers (like Piaggio Ape and 3 wheelers from Mahindra & Bajaj) have an inward camber. Any particular reason why?
PVS is offline   Reply With Quote
Old 1st April 2008, 15:10   #2
Hemanth's Avatar
The same technology was used in Standard Herald cars if I am not wrong. Car gurus.....reply please.
Hemanth is offline   Reply With Quote
Old 1st April 2008, 15:22   #3
Sankar's Avatar
Thanked: 4,637 Times
You must've seen this in Ape three wheelers.
When the vehicle is fully loaded the rear wheels will become true to the ground with a parallel contact patch. With zero or near zero camber.
If the wheels didn't have any camber then once the vehicle is loaded the wheels would have a negative camber. Which is not good for the life of the tyre especially when it is loaded.
Since these vehicles are designed to run with load most of the time their suspension is setup to offer maximum benefits in that scenario.
Old 1st April 2008, 15:26   #4
Thanked: 706 Times
thanks for posting this, I was seeking answer for this for long.
sukiwa is offline   Reply With Quote
Old 1st April 2008, 15:44   #5
condor's Avatar
Thanked: 4,896 Times
Sankar : Since these vehicles are designed to run with load most of the time their suspension is setup to offer maximum benefits in that scenario.
Actually, these vehicles are most times over-loaded. The manufactureres too would have taken note of how these would be used and provided a suitably over-compensated camber setting. This way, the vehicle is ready for over-loading, thus reducing break-down of the rear suspension. And the vehicle owners are happy too !
sic.
Old 1st April 2008, 19:35   #6
1100D's Avatar
Thanked: 2,503 Times
Its not that there is any high tech something in them, its just that these employ swing arm axles.
1100D is offline   Reply With Quote
Old 1st April 2008, 21:23   #7
PVS
Thanked: 121 Times
Thanks for your replies Sankar and Condor
Piaggio 3 wheelers - Camber angle of the rear wheels? sivadas Commercial Vehicles 4 5th June 2014 16:22
Service on Wheels: New initiative from Honda 2-wheelers Aditya Motorbikes 3 26th February 2014 16:59
Camber Adjustment query & Camber Adjusting Bolts? hell_rider Technical Stuff 18 2nd January 2009 22:43
Negetive Camber in Rear Wheels: Indica extreme_torque Technical Stuff 4 12th December 2006 20:39
Help With Camber / Castor readings moralfibre Technical Stuff 7 22nd October 2005 10:34
