Old 1st April 2008, 20:59   #1
Default car turning off while running
hi guys today i experienced a problem with my m800 it jerked when i accelerate and sometimes it turned off at high speeds. when i tried to restart car, it started but again stopped when accelerated . looked like fuel was blocked by something. checked fuel filter and fuel pump they where ok .than checked air filter it was also fine.what could be the problem please suggest
harry2223 is offline   Reply With Quote
Old 1st April 2008, 23:58   #2
humyum's Avatar
Thanked: 2,503 Times
Its either the ignition coil or a carb needing an overhaul.
Old 5th April 2008, 10:43   #3
mithun's Avatar
Thanked: 59 Times
harry2223 : Provide more info about your car !
Old 5th April 2008, 10:58   #4
pawan's Avatar
check your carb vacuum lines.
pawan is offline   Reply With Quote
Old 5th April 2008, 11:01   #5
car turns off while running. if i restart it stars, but shut off again when i accelerate
Old 5th April 2008, 11:11   #6
humyum's Avatar
Get your carb overhauled.99% its a carb issue.
Old 5th April 2008, 13:50   #7
Shashank.A's Avatar
I was facing the problem at low RPMs ...got the carburetter cleaned and VOILA...its running like a dream...
Shashank.A is offline   Reply With Quote
Old 5th April 2008, 22:46   #8
gd1418's Avatar
Thanked: 656 Times
If you have a mechanical fuel pump then due to heat the diaphragm creates a vaccum and stops pumping fuel. It was very typical problem during summers in old Ambys & Fiats. Pouring water on the pump used to solve this problem.
I dunno what car you own, but since you mentioned it is a carb driven vehicle, this also could be one of the causes..
Sound from front wheels while turning the steering at standstill narasimha raju Technical Stuff 17 12th December 2014 00:55
A sound while turning the steering wheel. InternetUser Technical Stuff 8 19th December 2012 09:21
Baleno - Head light not turning off naveendhyani Technical Stuff 27 24th January 2012 22:16
Wagon R, Noises while turning: Struts?? lsjey Technical Stuff 7 21st July 2009 17:33
Screeching sound in Santro while turning Lalvaz Technical Stuff 8 26th June 2008 13:35
