Old 3rd April 2008, 13:29   #1
bkm
Default Fuel indicator in spark whether a correct measure of amount of fuel
How far fuel indicator on in the central console give correct idea of amount of fuel left in the tank. Normally I fill Petrol when the needle is quite close to the 'E' mark on the meter. Yesterday i had put app 20 liters of Petrol . Initially the needle went quite far on the right side close to 'F' mark, but just after a drive of say 20 kms , it drifted back significantly . Going by the indicator calibration , it appears almost 4/5 liters of Petrol is consumed , which can not be the case .
can others share his experiences.
bkm is offline   Reply With Quote
Old 3rd April 2008, 13:36   #2
Thanked: 708 Times
Do not rely on fuel indicator too much, it's just an indicator not a true measure.
If you witness such sudden needle drops again, have it checked in ***.
sukiwa is offline   Reply With Quote
Old 3rd April 2008, 14:24   #3
Thanked: 146 Times
the fuel indicator is just that - a indicator.
the position of the indicator also depends on the slope your vehicle is on - ie either slanted left / right.
based on what you say, it is not possible for such a huge shift. maybe when you filled in the fuel your vehicle was tilted on a specific side which made the needle move to 'F'.
Best case is to check the fuel gauge on a level road, even better, on your parking slot. This was, you always have the same 'error' when making the reading.
HappyWheels is offline   Reply With Quote
Anti-Theft Measure : Etching registration number on the windows F50 Street Experiences 62 1st February 2014 13:49
Dealer quoting astronomical amount for technically correct IKON headlights!!. dhanushs Technical Stuff 32 10th January 2011 15:01
Perfect way to measure Fuel efficiency sidd25 Technical Stuff 28 2nd June 2010 16:43
Credit Card:Converting Outstanding amount to EMI/Pay only minimum amount due?Advise ashwinsid Shifting gears 26 11th September 2009 15:24
how do i measure the real HP of my bike ? ac 427 Technical Stuff 15 13th June 2007 14:51
