Old 8th April 2008, 19:02   #16
viper's Avatar
Thanked: 9 Times
Ramieanna,
Handbrake is only for rear wheels.
Viper
viper is offline   Reply With Quote
Old 8th April 2008, 23:14   #17
Thanked: 660 Times
@ Viper! thanks for the diagram. I had similar thoughts in my mind.
but is ABS affected.?
do you have some actual diagram/ebooks.!?
Old 9th April 2008, 09:30   #18
viper's Avatar
Thanked: 9 Times
Sorry this is the only diagram I have provided by D2 Racing. AM not sure about the ABS part as have not fitted the same on any vehicle in India yet.
Viper
Old 9th April 2008, 20:55   #19
1100D's Avatar
Thanked: 2,503 Times
What would be the diagram for a diagonal/dual-circuit arrangement?
1100D is offline   Reply With Quote
Old 10th April 2008, 04:14   #20
Ignazio's Avatar
Default my 2 cents
Hi all
I think that as per diagram, it can not be fitted in a abs equipped car. The reason is simple, if you have a look at an abs distributor, you have an hydraulic hose per wheel, otherwise, how can you control a single wheel locking? The only way to do that is to have an abs that can be switched off and use a second calliper on the disc or one designed to be operated double hydraulic. You can intercept also the two hoses going to rear wheels, and put a double pump lever, but abs has to be off or the hose pressure, will be reduced as soon as the sensor measure a wheel lock...
Ciao
Ignazio
Ignazio is offline   Reply With Quote
Old 10th April 2008, 05:10   #21
ram_hyundai's Avatar
Thanked: 48 Times
Is it worth the trouble to fit a hyd hand brake.Viper whats your opinion buddie?
ram
ram_hyundai is offline   Reply With Quote
Old 10th April 2008, 11:06   #22
Rehaan's Avatar
Thanked: 25,043 Times
Another use / name for the handbrake is "Emergency brake" - and it works as exactly that in case the main braking system fails (including the built in redundancy that most systems have).
If the handbrake/e-brake was hydraulic as well - it would not be a true e-brake right?
I think the advantage of this hydraulic handbrake is that comparatively very little travel/effort is required to lock the rear wheels - useful for tight road courses, rallies etc ... correct me if i am wrong.
...and if you want to push it further, it would also be "weight saving" since you would not need those rear drum shoes anymore for the handbrake (on cars with discs all around) etc
cya
R
Old 10th April 2008, 14:35   #23
Thanked: 660 Times
ram
it not the trouble, but a necessaty to fit it after the rear disk conversion.
help regarding making my own hydraulic handbrake!! abhishek564 Modifications & Accessories 8 23rd August 2009 00:34
Relocating the Handbrake. Possible? Tejas@perioimpl Modifications & Accessories 5 30th January 2009 14:52
Careful - Handbrake Lever!! getsurya Street Experiences 20 28th January 2009 14:07
Doing a handbrake turn to avoid an accident in an ABS vehicle? gopinathann Street Experiences 9 7th April 2008 01:30
Bill of materials for a handbrake assembly? ag501 Technical Stuff 0 29th November 2007 22:35
